CHASSIS INTRUDED My CPU was grounded. I removed it from the casing and placed a insulated cushion underneath the board. When I placed it back and connected all the peripherals. It showed a CHASSIS INTRUDED! error. I just pressed F1 to continue and it turns off at an average of 5mins more or less. Can anybody please help. When i was started my pc it shows an error that is chassis instruted.... every time i need to press F1 to escape from the problem... Is any solutions is there.....? help me.....
    President:
  • 1,383 Answers
Reset your bios settings .
put your cmos cell on mother bord for 15 minutes remove it from bord.
then it reset to factory defaults settings.
Posted on Apr 24, 2009
ASUS P5KPL-AM -> CHASSIS INTRUDED
Hi, have you got this board installed in a case, with all the connections made? Usually there's a two pin connector to a microswitch that detects if the case is open. If you can identify that on the board you can short the switch, fooling the system into thinking the case is closed, to get inot the bios etc.
Jun 05, 2014 | ASUS P5KPL-AM SE Motherboard
"the system intruded chassis opnened
The NRL_LS has a connector for a microswitch on the case, to detect if the case is opened.
Look for jumper J2, between the battery and the bios chip, at one end of a long connector CON1.
There should be 2 adjacent bare pins at one end of J2.
Place a jumper block on them, and the system should start normally.
The manual is here +NRL-LS Cover.P65 - ftp.asus.com.tw
Look at item 9 on page 2-22, referring to jumper J2
Feb 09, 2011 | ASUS NRL-LS Motherboard
The system intruded.chassis opened or tempered before please check the system. what shall i do ?
When you open the computer case, a switch is tripped and after the case has been closed and the computer boots up, you get this chassis intruded message.
To clear this message go to the BIOS configuration and then to the chassis intruder detect and then Reset this setting.
Oct 03, 2010 | ASUS P4SE Motherboard
My P4B will not boot. I am trying to install XP and all that comes up is "system intruded chassis opened or tampered before. Please check system. The installation is A-OK. what do I do. PLEASE!! Paul
This board has an Intruder protection sensor - practically it's a pair of pins (bottom right of the board) with a strap that when removed signals that the case has been opened. Put the strap back and it will be OK.
Jun 21, 2010 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Chassis Intruded
try take out the battery on board for one min. then put in battery see if that works jim
Feb 16, 2010 | ASUS K8N Motherboard
Cpu chassis intruded? can't continue installing windows
You can go to ASUS and find the pin out for your unit.
Or you will have to look hard at the board and find a open set of contact pin for a lid switch.
Oct 07, 2009 | ASUS P5VD2-MX SE Motherboard
How to fix chassis intruded ..fatal error..system halted...is it my cpu become damage?
It is unlikely that your CPU is damaged
You need to enter the BIOS and turn off chassis intrusion.
It is an option in the bios that is only useful if you have the switch on the computer case that supports it otherwise it will give you the error you see if enabled
Sep 14, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Chassis intrusion
You need to check the chassis intrusion pin setting located on the motherboard. See page 1-30 (Number 11) in your manual.
You need to add a jumper as shown.
The system should no longer halt.
Cheers!
Mike
May 04, 2009 | ASUS P5V800-MX Motherboard
Chassis Intruded
clear your bios, close very good your case, open bios disable chasisis open detected fro yes to no, (or in some model from enable to disable ) change saves exit booting and good work.
Apr 07, 2009 | ASUS A8R32-MVP Deluxe (A8R32MVPDLX)...
CHASSIS INTRUDED
You BIOS settings have been reset and you need to set it up again. Chassis intrusion needs to be turned off. You can download the user setup manual here: http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5S800-VM/e2419_p5s800-vm.pdf BIOS setup is in Chapter 2. There are alot of settings and it goes into detail on how to set them. This is truly an Awesome motherboard! I wish mine was like this. Follow the setup carefully and you can't go wrong.
Jul 07, 2007 | ASUS P5S800-VM Motherboard
Computers & Internet Logo
144 people viewed this question
David Payne
David Payne
