Jvc turntable JVC L-21a
Will not auto return how tocalibrate, no lift,noreturn
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
It can be any kind of mechanical problem causing the tonearm not to return to the rest. For more information, please visit my website at audioserviceclinic.com. Thank you.
Posted on Dec 09, 2013
Vinylking
  • 3 Answers
SOURCE: JVC - problem. The turntable does not move,
Most modern day turntables are semi-automatic. You move the tonearm from the rest post
over to the record and the platter will start turning. There is a small microswitch inside
either below the arm base or near. There should be a flat bar connected to the base of the arm
and this will actuate the microswitch. The switch is wired in series to the rotation motor.
Solution: 1. Obviously verify the belt is on. Take off the rubber mat and rotate the platter.
The rotation motor is on the left and it has a small brass spindle. The belt should
be visable through the holes in the platter. If not pull the platter gently up, there will
be some resistance. The belt wraps around a smaller inner ring on the underside
of the platter and the rotation motor spindle. If it is degraded it will be stuck to the
platter or fall apart. Generally there 3 common sizes. ( 21.4 / 23.6 / 25 inch) they
readily available on E-Bay, search term "turntable belt".
2. Obviously check power.
3. Check the microswitch, it should "click", verify with ohm meter.
4. Some turntables have a "cut" or stop function. The arm must return first to rest before
starting again, again the microswitch is the trigger.
Posted on May 17, 2009
  • 69 Answers
SOURCE: looking for manual for a JVC QL-A2 turntable
www.vintageaudiomanuals.com
if you email this company on there site there let you no avilability of it but i think itll cost you mate
Posted on Aug 09, 2009
  • 3 Answers
SOURCE: I have a JVC L-A11 turntable. I cannot get the
I just had my L-A11 in to 'the needle doctor' (Jerry Raskin's shop in dinkytown, Minneapolis) We had the same problem with the platter.
After pulling (hard) to no effect on the platter - using the holes near the spindle and pushing simultaneously on the spindle. The tech next got out a small hammer, and while pulling on those same holes in the platter, he gave it a sharp 'whack' on the spindle with the hammer, and it came right off (the platter). I would have been too feint of heart to do it, but it worked great.
Posted on Feb 23, 2010
jyackle5
  • 8197 Answers
SOURCE: Manual for JVC QL-Y55F
You can get the manual here on link below. at the bottom. You might need to open an account for free.
http://www.vinylengine.com/library/jvc/ql-y55f.shtml
Posted on May 04, 2010
Testimonial: "Thank you so much for the quick response. Indeed this will help me in setting-up the turntable again."
freetek
  • 5568 Answers
SOURCE: replace belt on a JVC L-A21 turntable auto return
Some years ago, I found only one supplier; now there are several:
Turntable drive belts
Posted on Nov 18, 2010
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    I have a jvc jl-a20 auto return turntable and the arm briefly returns then proceeds to travel across the album. What do I have to do to get it to stay at home after it returns? Thank you
    It's probably some kind of mechanical problem. Perhaps something bent out of place.
    I have found a photo which is the underside of the model. You can compare it with yours and see if it looks the same. If it doesn't (assuming it is the same model) then you have found the problem.
    http://www.vinylengine.com/turntable_forum/gallery/image.php?mode=large&image_id=30141
    Oct 12, 2015 | JVC Audio Players & Recorders
    What is the stylus weight adjustment and tracking weight for jvc ql-a2 quartz auto return?
    Balance the stylus, then calibrate the counterweight to 0. Then turn it counter clockwise to 2. For the antiskate knob, set to 2. Use the inner numbers for an elliptical stylus, use the outer numbers if you have spherical stylus. Hope that helps, feel free to ask about anything :)
    Sep 05, 2014 | JVC Vintage Ql-a2 Quartz Auto Return...
    Jvc turntable
    I believe I just answered this. Again, please visit my website at audioserviceclinic.com. Thank you.
    Oct 15, 2013 | Audio Players & Recorders
    How do I adjust the auto return on a JVC A-21 record Player? The auto return keeps returning to the holder after the record finishes but then adjusts itself back twd the record and drops just on the edge...
    Hi, this problem is caused by the cut off switch not depressing far enough to turn unit off. To remedy you need to do as follows.
    1. Disconnect from power supply.
    2. remove platter.
    3. Flip unit over to expose the underside and remove all screws.
    4. Remove base board.
    5. Look at the gearing beneath the tonearm and identify switch that tonearm depresses at the rest point.
    6. Loosen switch retaining screw and turn switch toward centre of turntable slightly until it clicks or closes. Tighten screw to hold switch firmly in place at that point.7. Reassemble and test.
    Good luck. John. Styluscity@gmail.com.
    Nov 01, 2011 | JVC AL A158BK Turntable
    How to replace the belt on jvc l-f130 turntable
    You will have to lift the platter section off the unit itself. Check for the spindle motor turing the table and lay the belt out around the spindle motor. Refit the platter and work the belt around the inside of the platter through the two large holes in the tray.
    Nov 22, 2009 | JVC AL A158BK Turntable
    Jvc turntable
    hi, please check first your fuse inside your turntable, replace it if possible
    Apr 04, 2009 | JVC AL A158BK Turntable
    Open Questions:
    79 people viewed this question
     Grubhead
    Grubhead
