Question about Sewing Machines
Thread come unravel while embroidery - Sewing Machines
  • Sewing Machines Master
  • 7,365 Answers
Try a new needle, needle may be damaged
Posted on Oct 16, 2013
3 Suggested Answers
  • 30 Answers
SOURCE: Bobbin unravelling on prolectrix 8 stitch sewing machine
did you put the bobbin thread in the tensioner? that would be the cut in the side of the bobbin case to pull the thread under the tensioner. if not it will cause problems. but if the top thread is looking good then the top thread is the problem, thread the machine with the presser foot up to let the thread into the tensioner, if it looks good on the top and not the bottom it is the upper thread if it looks good on the bottom and not the top it is the lower thread
Posted on Aug 22, 2009
SOURCE: pfaff 134 thread unravels
try changing the needle--make sure to use every thread guide
try a different thread
check for any burrs on the needle plate or on the bobbin case
clean under the needle plate & in the bobbin area for lint or loose
threads
Posted on Aug 17, 2012
Pfaff 134 thread unravels
threads
Aug 16, 2012 | PfaFF Sewing Machines
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
I have a ce 100 and the bobbin thread comes up and gets into my embroidery pattern. how do i loosen the top tension to stop this from happening. my purple flower has white in it from the bobbin :(
Just an FYI-the bobbin thread needs to match your top thread. The majority of the thread that appears in the top of your embroidery actually IS the bobbin thread. The machine is working correctly. Don't use a bobbin full of white thread-instead, thread a bobbin with the color your doing the embroidery work in to match and you will have a perfectly beautiful embroidery.
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
Bobbin thread is coming to top when embroidering. I have changed needle and re-threaded several times
Feb 16, 2010 | Singer CE-100 Futura Computerized Sewing...
Do I need the embroidery hoop? does it connect to the thing in the back of the machine and moves areouns?
  1. What do I need to get started at free machine embroidery?
    • A zigzag sewing machine with a drop-feed control. (In other words, you have to be able to lower the feed dogs so they don't try to feed the fabric.) It's nice if you can vary the width of your zigzag stitches too.
    • An embroidery foot or needle with embroidery spring. An embroidery foot helps by holding the fabric down against the throat plate while nevertheless being minimal - it lets you see what you're doing because it has very little surface area. You can alternatively get a needle that has a kind of spring built into it, and the spring holds the fabric in place. These can be nice in that they're even more minimal than an embroidery foot, but they're also relatively expensive and if it breaks you have to replace the whole thing instead of using an ordinary cheap needle with the special embroidery foot. If you use the needle with spring, you don't use a presser foot while you embroider.
    • An embroidery hoop. There are two primary kinds of embroidery hoops on the market. The old-fashioned kind, usually made of wood, has an outer ring and an innter ring. You loosen the outer ring, separate the rings, place the fabric over the inner ring, place the outer ring over the fabric, tighten the outer ring, and pull the fabric tight in the hoop. With the modern type hoop, you squeeze a pair of handles on the inner ring to remove it, place the fabric over the outer ring, place the inner ring (still squeezed) into place and release the handles. The more modern hoop is faster and easier. The old-fashioned hoop provides better tension on the fabric.
    • Stabilizer. This helps prevent puckering and slipping while you're embroidering. There are a variety of types out there. Some are papery and are torn away from the embroidery when you're done. Only use that on the back side of the embroidery, as it's almost impossible to get it all off. Others are also papery and also tear away but are dissolvable in cold water, leaving only a few easy-to-remove fibers in the embroidery. Your authors like this type of stabilizer. There is also a transparent plastic-like stabilizer which dissolves completely in water. Your authors have this but haven't tried it yet, but hear it's very nice. It's expensive though.
    • Fabric... of course. Make sure that your embroidery hoop fits on the piece you're going to embroider on. If the piece is to be small, you may want to embroider before cutting the piece from the fabric.
    • Thread. Contrary to popular belief, you can use ordinary polyester all-purpose thread to embroider, but it can weaken the fabric you're embroidering on. (If you do use polyester, you may want to fuse some interfacing to the back of your embroidery when you're done.) There is plenty of gorgeous 100% rayon embroidery thread available.
    • Thread for the bobbin. This won't be seen on the surface, so you can use anything you want. Trying to find a way to get rid of that day-glo orange thread you can't remember why you bought? Stick it in the bobbin when you embroider. Some embroiderers feel that it's best to use a softer thread (like 100% cotton) in the bobbin so as to reduce the possibility that the bobbin thread will break the embroidery thread, but your authors haven't had a problem with this to date.
  2. How do I prepare the machine and fabric for free machine embroidery? Drop the feed dogs and set the stitch length at zero. (If you can't set the stitch length at zero, don't panic, it's not that important.) Install the fabric in the embroidery hoop (with any stabilizer[s] you intend to use) so that the surface of the fabric is at the *bottom* of the hoop. (Note that if you're used to embroidering or cross stich by hand, this means you're putting the fabric in the hoop backwards.) When you place the hoop on the table such that the fabric surface rests on the table, the right side of the fabric should face up. Install the embroidery foot or special embroidery needle with spring on the sewing machine. If you're using the special needle, remove the presser foot. Place the embroidery hoop in the sewing area. (Some machines can't lift the presser foot enough to admit some hoops - you may have to remove the presser foot temporarily, position the hoop, and then re-install the presser foot if you're using one.) Set the sewing machine for a straight stitch. Reduce the upper tension until stitches interlock below the fabric instead of above or inside it.
  3. How do I lock the thread at the beginning and end of my embroidery so it doesn't begin to unravel? Make several stitches in place to lock the thread.
Nov 13, 2009 | Janome Memory Craft 9000 Computerized...
Jul 29, 2009 | Sewing Machines
Brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Mar 30, 2008 | Brother PE-150V Computerized Sewing...
Machine embroidery
You should always use proper Bobbin Thread for embroidery - not a bobbin wound from regular dressmaking thread. You are right, the special bobbin thread is thinner so that the embroidery thread will be pulled to the underside and you get a nice shiny embroidery on top with no bobbin showing through. Wind yourself 6 or more bobbins at a time of bobbin thread to always have some on hand, or buy the pre-wound L size ones.
All embroidery machines - no matter what brand - recommend using bobbin thread for embroidery. It is readily available at all sewing stores, probably even Spotlight would carry some. If you get stuck for a supply, try overlocker thread.
Dec 04, 2007 | Husqvarna Designer I
Sewing Machines Logo
13 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
