Question about Frigidaire FRT18FS5A
Ice maker stopped working on Frigidaire Model FRS262NHW3...
It's probably 6 to 7 years old now. Had a 5 yr warranty through Worst Buy. Coincidentally, around the time the ice maker completely stopped working I noticed one morning that the frige wasn't working at all (first thought the light had burned out). Turned out it had blown the circuit breaker and it could be tied to this same ice maker problem. The circuit breaker kicked off once when I tried to reset it and then it stayed on after that. The side by side unit gets chilled water through the door as usual and the switches and the rest of the frige are working just fine. I checked the IM and apparently it's not getting any water to the freezing unit at all. The auger works -just no ice being made. Can I replace some unit in the front of the IM head, as stated in another post, provided that the tube to the IM is not frozen or clogged? TIA for any help.
  • palsal Oct 11, 2007
    Ice maker now working - solution & suggestion in case anyone's wondering.  I bought a replacement unit from Lowes for only 50$ ($75 for exact same unit at Worst Buy).  It was identical except for the power cord.  Short story:  DO NOT DO THIS!!!!  BUY THE EXACT SAME IDENTICAL UNIT INCLUDING POWER CORD CONNECTION EVEN IF IT COSTS MUCH MORE.  In my case I thought I could get by by matching up the wiring and swapping the connector from the old unit.  Wires matched up okay but unit did not work well.  It did make a little ice surprisingly but then seemed to stop and or was extremely slow.  New IM unit was just the ticket.  Water valves all must be okay because everything works great now.  I'm out about $80 but it's worth it!!!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
I would check the valve that provides water to the ice maker before doing any thing with the ice maker head. Check voltage to the valve when the ice maker is in harvest mode. (with a good volt meter). watch the meter for the whole harvest cycle or you will miss the reading. if volage is good 99% chance youve got a bad valve, assuming the inlet tube is not frozen. Best of Luck.
Posted on Sep 27, 2007
Ice maker problem
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
Jun 08, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire dishwasher model pdl4375rfc2 serial# th80537081 door weaks aat lower right corner user less than 6 months is there a recall on this model
if unit is less than a year old . call for service 1-888-203-1389. this unit has a one yr. warranty from the manufacture. recalls are usually not given on appliances unless it is a safety issue. however i have repaired alot of these under warranty for your same complaint. their is a splash kit u can get that goes on each corner of the bottom of the inside of dishwasher that will stop it from leaking, roughly 10-20.00 dollars depending on who u purchase it from .hope this helps out.
Oct 06, 2009 | Frigidaire PLD4375RFC Dishwasher
Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Oct 01, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
GE refrigerator is the worst product I have even
Well, i have to jump right in here and agree with you. I have been working on appliances since 1971 and GE is the most frustrating, highest priced replacement parts ( for the most part ) of all brands. Of all the brands, Whirlpool and Maytag have been the longest lasting, best priced and easiest to work on. I truly feel sorry for you....really.
May 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker has ice in lower back part of ice maker, rotation stopd
you say ice in back of ice maker??? only the rear 2-3 cubes are filled??? adn the front 5 or so are empty??? then yes its possible low water pressure from a faulty filter can be an issue, shoudl be replaced at least every year. so you cant go wrong by changing it , at least rule it out!
Nov 22, 2008 | Frigidaire FRS26R4A Side by Side...
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
Ice maker not working
Hello bnelson488,
Since the ice maker is erationally starting and stopping at it's own leisure.
1.We must first try to turn off the fridge.
2.unplug it or if you can not reach the plug you can turn off the breaker to the fridge also, for 5 minutes!
After this you restart the fridge and see if the system reset it self.
This is a common way to reset some units!
If nothing works then perhaps the ice maker needs to be replaced.
How old the fridge?
Let me know how it works and if you have any questions.
Please remember to give a rating before you finish..
bless you
Here is an interesting article I just read.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Sep 04, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRT18FS5A Logo
241 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
