Always restart when windows appear - Computers & Internet
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 58 Answers
Try start up repair by pressing F8 when your computer is booting, or try system restore. If these don't work, you may need to re-install Windows.
Posted on Oct 15, 2013
I'm using a Hp compaq nx9005. It has being working
did you try to restart from "last known good configuration"? if it doesn't solve your problem do this: on Windows Advanced Option Menu, pls select an option "Disable Automatic Restart On Your System Failure" then post here the error message.
Mar 03, 2013 | Computers & Internet
Tip
How to DISABLE programs in start-up
Usually, computer is slow and this is due to programs start when Windows start. and you have an option to stop them from starting. there is always an option to open the programs on the computer. Here are the steps to Disable programs:
  • Step 1: click on start
  • Step 2: click on "run" or "start search"
  • Step 3: type "msconfig" then hit enter
  • Step 4: on the system configuration window. click on startup tab: then click on disable all.
  • Step 5: click on apply
  • Step 6: click close : then click on restart..
In some cases a permission window pop up would appear, just click ok.. then after the restart , your system should be running a bit faster.. "in some cases a message on Vista and Windows 7 will tell you about Admin rights... and the option your need to is before hitting enter after typing msconfig on the run box, right-click on the message that appears on the right hand screen then choose "Run as Administrator" HOPE this would help you..Cheers..
on Aug 07, 2010 | Computers & Internet
Tip
How to Remove a Program .
From the Start Menu in Windows .Go to your Contol Panel.From your Control Panel choose Add/Remove Programs. This may take a few minutes for your Programs to appear. Scroll down until you find the Program you want to Remove. Click on Add/Remove .This will uninstall your program. Follow any prompts that may appear. After you have successfully uninstalled your desired program .Restart your Computer. Always Restart your Computer after you Add or Removed a Program.
on Jul 31, 2010 | Computers & Internet
My laptop always shutdown and restart and my monitor always appear a stripe or lane vertical position,pls help me to how to fix it...tnx
Hi, this may happens if the files of the Windows gets corrupted. Please re-install Windows to resolve Windows restarting issue. If the stripe lines still appears after re-installing Windows, then the issue might be related to hardware. In this case, please contact the manufacturer to initiate service.
May 10, 2011 | Computers & Internet
Vista says CANON MF4370dn printer always offline? IP addrs issue?
first of all, download updated driver from software.canon-europe.com and install ( before install, remove old drivers and programs)
and if appears again, change your network cable.
Mar 29, 2017 | Canon ImageCLASS MF4370dn Laser All-in-One...
Alway get error message cood116a
check that you have the latest graphics drivers for your card installed, as it sounds like a graphics problem.
to do that click start, then RIGHT click on my computer and then left click on manage. Click on device manager in the top left window, a list of all hardware will appear in the right window , click on the + to the left of the display adapters and then right click on the item that appears below the + and click update driver. Then restart your pc. That should solve your problem. If you have no device listed or it says standard vga then no drivers are installed and you need to go to your manufacturers site and download the driver. Hope this helps
Nov 13, 2009 | Microsoft Computers & Internet
Error in registry....
Maybe, you have registry problem.
  • Just restart the system
  • Press F8 while starting the windows
  • Select "Safe Mode" options
  • After restarting, a window will come up on screen
  • select No
  • Just select the past date from the date calender. You must select a past date from which you were not facing problem.
  • A restore process will start automatically.
  • press okey and finish
  • restart the computer.
Dec 10, 2008 | Microsoft Windows XP Professional
The Adobe Flash player can not be installed
Hi there Restart your computer--> black screen--> after the Bios check (is always the 1st step)--> start pressing the F8 key repeatedly--> Windows boot menu will apear--> use the arrows--> Safe mode
It will look different from you normal Windows (don't worry about this)--> Install your program--> restart your computer normally regards
Nov 12, 2008 | Adobe Photoshop 7.0 for PC
Drives are opened in other window
have you tried msconfig, if not then type in run msconfig then in startup tab disable all apply then ok, restart
May 29, 2008 | IBM ThinkPad R52 Notebook
Disc Cleanup and Defragment
hey try doing this in safe mode.
If your computer is running Windows XP or Windows Vista
  1. From the Windows Start menu, go to Turn off computer and click Restart.
  2. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second.
  3. Immediately press F8 before the progress bar reaches the right side of the screen.
  4. From the Windows Start-up menu, highlight Safe Mode and press Enter.
  5. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices).
  6. When the repairs are done, restart the computer, and allow it to boot normally.
Dec 20, 2007 | Dell Inspiron B130 Notebook
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
