Question about Jenn-Air JSD2789GES Side by Side Refrigerator
Freezer leaking water floor - Jenn-Air JSD2789GES Side by Side Refrigerator
2 Suggested Answers
  • 5 Answers
SOURCE: water freezing on floor of
I have narrowed my similar problem (with a KitchenAid) down to a leak in the ice maker refill line. To test if this is your problem also, scrape the ice out, then turn off your ice maker (raise the lever as if it is full) and see if ice no longer forms down at the bottom over the next few days.
Posted on Feb 18, 2011
Need manual for kenmore model 28462---water on floor
Contact Whirlpool to see if a manual is available. Whirlpool makes Sears Kenmore.
Aug 15, 2015 | Kenmore Freezers
Water leaking under a fridge freezer
There can be 2 reasons for this ... the first is that the machine is causing condensation and is dripping on to the floor. Automatic defrosting fridge freezers do this but usually the quantity of water evaporates before any is on the floor.
If the Fridge / Freezer has an automatic Ice maker, or has a cold water supply, then I would suggest that there is a water leak to the system. In this case, find the water supply feed and turn it off to eliminate this as the source.
If this stops the leak, then either the supply is leaking or the problem is inside the fridge / freezer and you will need either a plumber or a repair man to fix the problem.
Aug 21, 2014 | Refrigerators
JENN AIRE LEAKING WATER ON FLOOR. NOT SUPPLY LINE PROBLEM. HELP
Open freezer, remove lower crisper & look for solid ice on freezer floor & area at rear of freezer. If present, defrost drain is restricted. Depending on make & model remove ice, remove rear wall and clear defrost drain trough and drain path. Verify by removing kick panel, pour a cup of near boiling water through drain and watch as it drains into pan. Once clear, pour one ounce of bleach into drain tube. Also check as water is draining into pan that the pan is not leaking due to pan cracks. This solution is based on the fact that you are stating no hoses are bad.
Mar 27, 2012 | Freezers
Kenmore refrigerator model 363-58572892 side by side refridge/freezer. Water is appearing on floor in fron of freezer side. Appears to be coming from ice maker. Crack in cce mold? Clogged drain? filling...
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 29, 2011 | Kenmore 64802 Top Freezer Refrigerator
My Maytag MZD2766GES is leaking water to the bottom of my freezer, which, when it get alot starts leaking all over the floor. where is this coming from?
Gene
Aug 18, 2011 | Maytag Refrigerators
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water runs out of freezer door overnight ,at times
Have a look at this link:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/7670-leaks-water-floor-front-freezer.html
or this one:
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Apr 17, 2009 | Westinghouse Refrigerators
Water leaking into bottom of freezer and on rto floor in front. Kenmore elite bootom freezer 596 series
Drain hose clogged. Removed rear panel and blew out hose. draining fine and no water leaking into bottom of freezer or floor. Be sure to thaw out drain and tray before you return to service.
Sep 14, 2008 | Kenmore Refrigerators
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
26 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
