Question about Canon Pixma MX452
Printer won't print & give an error code 300 - Canon Pixma MX452
2 Suggested Answers
rajdeepdutta
  • 2517 Answers
SOURCE: i9990 repeatedly gives error 300 message. Worked
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Jan 21, 2011
OCE Plotwave 300. Error Code 22701\printer.
This error will be caused by a jamb inside the cutter assembly of the lower roller drawer. Remove the two black Torx screws at the left and right sides inside the lower paper drawer. Next remove the galvanized cover. You should then be able to see the edge of the paper. Grasp it firmly with a pair of needle nose pliers and pull straight up and out. Clear your errors and commence printing.
Dec 10, 2009 | Office Equipment & Supplies
Setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
Refuses to print
Do you solve the problem? Because I have the same probleme and I can't fixed it. Give me a solution if you can. Thank tou!
marcelgiosan@yahoo.com
Feb 12, 2009 | Canon PIXMA MX7600 Multifunction inkjet
Printer busy or error
So are you saying that the printer looks like it's about to print but then gives you a red error light? If so I think I had the same problem. It is to do with a faulty part (very cheap). The part is a kind of roller that picks up the paper. In some CLP-300s the rollers surface is too coarse, thus not picking up enough paper.
I had a service department change it for me, did it in 5 mins.
Hope this helps.
Jul 25, 2008 | Samsung CLP 300 Laser Printer
How to use auto cut for ADP-300 urgent
dear sir / madam
i am mohamed anver azam mohamed currently we are using a adp 300 pos printer i needed a pos printer driver if you can plase post to us
129, hospital road,kurundugaha ela, akurana , kandy, sri lanka
May 06, 2008 | POSX POS-X ADP-300 Matrix Printer
Canon Pixma MX452 Logo
old marine
old marine
