Question about Shoprider Sprinter XL4 Deluxe
How far can I go on a single charge - Shoprider Sprinter XL4 Deluxe
My new Dyson Serial Number PM8-US-HHB1494A will not charge.
Suspect a dead battery or a defective charger
Dec 28, 2016 | Dyson Vacuums
Tip
Camera batterys
i have noticed that so many people are still putting factory charged batterys into there cameras. you must use rechargable batterys they last much longer on one single charge cost far less but most of all have a much more powerful output path <br /><br />try it youl be glad you did <br />
on Dec 24, 2010 | Cameras
Can i over charge my mobility scooter go go pride
Yes you can overcharge a battery, it all depends on the charger your using. Most chargers are single stage chargers. Most scooters come with a single stage charger. My scooter has a built in single stage charger What this type of charger does is output a constant 24v @ 4amps.The problem is batteries amperage requirements decrease as the battery charges. An overcharge will occur when the battery is charged. It requires very little amperage to maintain a charge on a fully charged battery. A single stage charger like mine will output 4amps regardless of the state of charge of the battery. Batteries bring charged with single stage chargers loose their electrolyte. What happens is overcharged batteries break down the electrolyte into oxygen and hydrogen. So overcharging will cause a battery to "boil-out" its electrolyte. Batteries don't work without electrolyte. In the old days there were only single stage chargers. That was the state of the art back then. So to cope with the constant overcharging batteries had refill ports where you could replenish the electrolyte using distilled water.
Scooter batteries are far and away different from the lead acid of the 1970's. Scooter batteries are sealed, they are deep cycle, they use a glass mat soaked in gelled electrolyte. These glass mat batteries optimize the electrolyte used so they can use allot less of it. These newer batteries have a lot more power in a lot smaller package but they have a draw back, they must be charged properly. You can absolutely can not charge these batteries with a single stage charger. Actually you can charge with this device but you will loosed electrolyte each time you charge.
I use a three stage charger 24v @ 5amp. This charger s different from a single stage. Its what they term a "smart charger" it monitors the state of charge of the battery. As the battery charges it turns down the amperage. When the battery is fully charged the amperage is turned low enough were the charge is maintained. The entire charging process is designed to preserve electrolyte. In short this type charger will not overcharge the battery.
Click here to see the charger i currently use.
http://www.amazon.com/Sealed-Battery-Charger-3-Stage-Fan-Cooled/dp/B0051WHAU0
Jul 30, 2012 | Health & Beauty
Can't change the bulb in o ovenneff
If you are struggling to get the lamp cover off in the far right top corner, try wearing a pair of rubber gloves to get a better grip and you need to turn it right to left ad you look at it, if it still will not move, contact Neff Customer Service and they should sent you out a removal tool free of charge 0844 892 9002
Nov 21, 2011 | Neff B1451 Single circotherm plus Electric...
We have a funny noise and have a broken belt, not sure which one. but then engine light was not on before the cab was lifted, The engine light is the one with a question mark thingy on it.Can we still...
Depends what belt it is. If it the alternator belt, it will not charge the battery, and soon die and then not start. If it the fan belt will over heat. Either way determine what belt it is, but personally I would not drive it very far, maybe far enough to get it to somewhere safe off road and maybe to first repair shop, if you can get it that far. Mike Write me back and describe what belt it is, by telling me what it goes around, alternator, air conditioner, both>? fan belt>? one single belt?
Jul 07, 2011 | Nissan King Cab Cars & Trucks
How much should a dealership charge to replace timing belt and water pump on 1999 Plymouth Breeze 2.0?
it depends what their door rate is to do the job and they can charge what they can as far as parts are concerned.you don`t say if its a dohc or a sohc(dual or single cam motor).roughly it would take about 3.5-5 hours to change the timing belt and about .4-.7 to change the water pump.call around and compare prices as this doesn`t have to be done at a dealer.
May 09, 2011 | 1999 Plymouth Breeze
We just installed the Price Pfister Hanover Single Handle faucet in our kitchen. (Series T529). We find that it doesn't have the same pressure as our previous faucet. Is there a reason for this? We have...
Hey,
We have the same problem. Just called Price Pfister with the same question, and she offered to courier replacement parts free of charge. She was much too accomodating. My suspicion is that she gets this question quite regularly. Love to know if anyone has solved this problem as we like the look of the faucet.
Apr 22, 2011 | Price Pfister Hanover Single Handle...
I lost the adapter/charger and purchased a new one of the same size. The light will work when plugged into the car cig lighter, but not while plugged into the dc adapter (has been plugged in for approx. 3...
The battery life for these lights are for about 2 years at the most if left uncharged. The best way to determine if you need new a new battery or batteries would be to dismantle the light, remove the batteries and check the voltage with a volt meter. If they are dead, you may be able to fine a suitable replacement at: http://www.batterymart.com/c-04-12-volt-sealed-lead-acid-batteries.html
Nov 12, 2010 | Vector 20 Million Power Series Spotlight
Cracked screen on sony brava 52"
Sorry, but forget it.
If the screen has cracked then you've broken the single most expensive component in your tv. When you bought it you basically bought the screen at a bulk discount price and the casing, electronics and all other components came for free.
Buying the screen separately will usually cost far more than buying the entire tv and then you still have to add on the labour charges to fit it as it's not a DIY job.
May 08, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
2001 Jeep wrangler not charging. Alternator has been checked and tests good. Check gauge light on. Alternator not charging power to the field wire from the battery and power to the back alternator on one...
on the field wires ones a posative and one a negative and the single post gets connected to a wire that runs straight to the main fuse box in the engine compartment then is fused to another wire that goes to the battery have that fuse checked it could be your problem as far as the feild wires the positive side only works when you start the vehicle up to engage the field
Apr 13, 2009 | 2001 Jeep Wrangler
Shoprider Sprinter XL4 Deluxe Logo
26 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
