Question about Refrigerators
I have a Frigidaire gallery series fridge. The fan runs all the time and rarely turns off. The condenser kicks off and on normally and it's maintaining temperature but I don't know what it's causing the fan to stay on.
  • Refrigerators Master
  • 842 Answers
Hi Brandy,
As for your fans, the fans in the back of the unit, (bottom back of the unit, not inside) is called a condenser fan motor this only cools the compressor for the fridge. This fan only runs when the compressor is running. The other fan is in the freezer section and is a variable speed fans motor, this can do two different things with only one job. The fan itself can ramp up and down in speed to control air flow and temperature demand in the two sections. This can run a lot but should slow down when temperature is met or while in a defrost mode. So to sum up this answer, it is common to hear fans run in the newer unit over the older units. Believe it or not do save energy with just moving air over running the compressor all the time.
I hope this helps.
Posted on Oct 15, 2013
SOURCE: Samsung fridge freezer
Hi I have same problem as gordon. fridge 5 years old.
Posted on Mar 02, 2008
22yooper
  • 828 Answers
SOURCE: Frigidaire Gallery Side by Side - Fridge not cooling
Locate the defrost timer and rotate the dial a small amount clockwise. If the compressor starts the timer should be replaced. If the compressor does not start check the temperature control. It may be bad, if it is bad try jumpering the thermostat wires. If it starts and runs the thermostat is bad. Replace the thermostat.
Posted on May 26, 2008
sandy_s
  • 111 Answers
SOURCE: Frigidaire Gallery Series M# GLHS36EESB5
check to make sure there is nothing blocking the water lines and no kinks in the water lines, you did not say if it had an ice maker, and if it is affected.
The frigidaires also has a plastic tube coiled under the back to dispense cold water make sure this tube is not kinked.
Hope this helps
Posted on Jul 02, 2008
micromaster
  • 3614 Answers
SOURCE: Ignis fridge isn't cold enough,
check the thermostat settings... it is better to clean and defrost the fridge to meet again the desired freeze... let me know if you have defrost the unit and already clean the unit....
thanks
Posted on Jul 05, 2008
vanni7
  • 163 Answers
SOURCE: SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Posted on Jan 04, 2009
My condenser fan is not working on my frigidaire gallery could it be the inverter is not working right?
Sound like your capacitor popped is the condenser running and does it work on both units
Sep 28, 2016 | Frigidaire Refrigerators
Electrolux Frigidaire Model # FRT21BW8DW0 NOT WORKING, HELP!!
Hello Emily R - Do you hear anything running in the machine compartment and what type of airflow is the condenser fan providing (try removing the toe grille, located above the drain pain on the bottom right-hand side)? If you do not hear the compressor and unit is providing room temperature, it usually means the unit may have a faulty compressor or a sealed system leak. I would personally recommend contacting the manufacturer for a listing of authorized technicians who may assist you in repairing your unit and reinstalling the part that has been removed due to liability reasons.
Oct 08, 2012 | Frigidaire Gallery Series GLRT86TEW 30"...
MY FRIDGE THE FRIZER WORK GREAT,BUT THE FRIDGE BOTTOM NOT
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 22, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
My gallery frigidaire refrigerator is on, the light works, I can hear the fan going but it doesn't get cold, neither the fridge or freezer
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 15, 2010 | Frigidaire Refrigerators
9-10 year old Frigidaire Gallery FRS26ZSH refrigerator stopped cooling as only the fan was running and not the compressor. Cleaned the lower coil and fan of a small amount of dust. The unit worked for 1-2...
might be your compressor relay gone bad. if the condenser fan was running and no compressor that could be the case. Also could be a bad compressor. you could try installing a 3in1 start kit. cost about $30. if doesn't start with that then compressor is kaput.
Jun 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
May 23, 2010 | Frigidaire PLHS267ZA Side by Side...
Front Center wall getting hot to the touch On Frigidaire side By
Normal operation to reduce outside condensation.
Could get up to 120 degrees.
Jul 04, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Comperssor kicks on but quickly cuts off intermittently every 5 minutes on my frigidaire fridge side by side
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
Freezer and Fridge are both not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
hhsg
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Mar 30, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
