Rowenta Master
- Posted on Oct 15, 2013
Re: Does red light suppose to flash
Follow this section troubleshooting and fix it. God bless you
Clean an iron:
- Unplug the iron and make sure it is cool before cleaning.
- Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
- Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
- To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup
vinegar into the water tank. Place the iron on a rack over a broiling
pan and set the iron to steam until the tank runs dry. Repeat if
necessary. Or follow the instructions for using a commercial iron
cleaner.
Service the steam and spray mechanism:
- Unplug the iron.
- Use a fine sewing needle to unclog the steam valve assembly. Also,
check the valve spring and replace it if it is broken or has lost
tension.
- If the spray pump is accessible, remove it and check for leaks by
placing the spray tube in water and squirting the pump. Clean or replace
as needed.
