Coleman dgat 090 bdd furnace will ignite but go out after 5-10 seconds of burning
Buffalo12980
  • 625 Answers
SOURCE: How to install an igniter?
if the heater uses a hot surface igniter its a simple matter of unscrewing the igniter and replacing it with another unit. if it is a spark ignition, the spark wire is a heavy insulated wire that goes to the gap. check out white-rodgers for a replacement. if your furnace uses a purge mode get a purge cycle programmable igniter.
Posted on Nov 15, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: have to replace ignitor on coleman furnace every year
The voltage regulator on the control module is sending the wrong voltage to the ignitor or the ignitor is getting wet from condensation. That ignitor should last many years. Replace the control module.
Posted on Dec 04, 2008
Gort007
  • 1187 Answers
SOURCE: COLEMAN FURNACE BURNER NOT LIGHTING
There is a thermocouple "wire" that is supposed to be touching the pilot flame.
The thermocouple senses a flame (hot) and allows the heater to operate. If the thermocouple does not sense that the pilot is on, then it will not allow the furnace to operate.
Bend the thermocouple wire (or the pilot tube) so that the pilot flame is touchingg the thermocouple.
That shouls work now.
The air from the fan should not be blowing through the same cxavity that the pilot is in.
If it is, then you may have a leaking furnace whereby carbon monoxide may be seeping into your living quarters.
If the fix above works and the pilot stays on after the heater starts, then there is probably no leak.
Let us know the results ... post a comment or "RATE" this or another expert's solution.
Posted on Sep 16, 2009
  • 767 Answers
SOURCE: My Coleman furnaces with electronic ignition just
you have to replace the ignition control board.
Posted on Dec 12, 2009
SOURCE: Coleman furnace -- fan runs, ingniter won't light,
My furnace did not have a reset switch on that particular limiter. I unpugged the switch, it had 2 wires, waited 15 seconds or so and then plugged it back in . Turned the furnace back on and the limiter reset itself.
Posted on Dec 24, 2009
Coleman 4324 furnace pilot wont stay lit
replace the flame sensor,looks sorta like this,http://www.ebay.com/itm/Coleman-Furnace-Flame-Sensor-7975-3881-7975-388P-A-DGAT-/370453130096?hash=item5640ba2b70
Apr 20, 2017 | Coleman Heating & Cooling
Coleman furnace dgaa077bdta
The control fuses keep blowing tells me one or more of the control that operate the control on 24 volts is malfuctioning. Most controls operate at about 5 watts and on a clamp on amp meter normally pull about 0.2 amp (p = current x voltage, 5 watts = 0.2 amps x 25 volts) I install 75 watt 24 volt transformer with a resettable overload to save on fuses. I reset the transformer and quickly go to the controls and determine the amp draw. When I find the one >0.2 amps I found the problem. The things to check is the emergency heat sequencer, fan control sequencer, reversing valve for heat pumps, main contactor on the condensing unit and any other 24 volt control loads. I have had to replace the themostat wire because the increase current for the thermostat wire can cause the entire length of wire to form a long heater and cause insulation degradationa and cause the thermostat wire to short out and blow the fuses.
Hope this helps
Aug 30, 2014 | Coleman Mobile Modular Home Gas Furnace...
Hvac turns on and shuts off after 3 tries
just to be sure this is a gas fired furnace? - what make and model?
behind most not all are sensors behind or near the blower fan - these little buggers are easily missed if you have one - jumper the wires and see if it fires if it does this sensor need replacing -
Mar 20, 2014 | Coleman York Dgat Gas Furnace Flame Sensor...
Coleman evcon furnace
For sensor if you mean thermocouple that sits in the pilot light I say this is usually the problem. The thermocouple needs to heat up to a preset temp before it will allow the gas to remain on. Does the pilot light stay on? If so make sure you turn the gas knob to on from pilot/light
Oct 15, 2013 | Heating & Cooling
Ican anyone help me find a wiring diagram for a coleman DGAT075ADC FURNACE?
Did you look on the inside of the removable cover? That would be the normal place for this information.
Apr 13, 2013 | Coleman Mobile Modular Home Gas Furnace...
Sep 16, 2009 | Coleman Propane Forced Air Heater...
Have to replace ignitor on coleman furnace every year
Dec 04, 2008 | Heating & Cooling
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
