Question about Garmin Rino 110 (14 Channels) 2-Way Radio
I have a pair of head phones that are PTT. They work, but will not transmit when in the radio. It worked for a while, but will no longer transmit, and again the headset works fine on other radios. And the radio works fine when you use the press to talk on the radio device.
    New Friend:
    Problem Solver:
  • 15 Answers
CHECK THE SETTINGS
Posted on Oct 23, 2013
I have a pair of wrist watch freetalker walkie talkie. One works fine, calls the other and transmits perfectly well. The other however does not appear to join in. It receives the voice message from the...
Odd that it calls itself. I suspect a weak battery on the no transmit unit. Radios require a lot of power to transmit and little to receive. Even if the charger says charged, it is more often the battery than not. If you have the walkie hooked up to the transformer and try talking on it (not recommended) it still could be the battery. Other issues: liquid damage, dropped, etc.
Feb 22, 2015 | Radio Communications
After cloning transmits only once
Out of habit, after I clone a radio, I turn it off before transmitting. I think it does a reset and saves the information. So, do that, turn it back on and try again. If the problem persists, try manually or with the software programming it. If it still will not save the information, the radio is in need of repair. Please post if this worked.
Apr 11, 2014 | Radio Communications
Active headset
Your headset is operating in VOX mode. This sometimes will happen if the headset is plugged into the radio when the radio is still turned on. Try unplugging the headset, turn on the radio, then talk using the PTT on the radio. Shut the radio back off. Then insert your headset plug, being certain it is seated (click) into place. Then turn the radio back on and see if it works without VOX. If you are still having problems, press the PTT on the radio one more time and see if it shuts it off.
Mar 12, 2014 | Motorola HMN9021A Dual...
Headset transmits automaticly
When I press PTT the walkie talkie turns off
Dead, shorted, not fully charged, bad battery connection, or bad battery.
Jun 15, 2012 | Radio Communications
Motorola talkabout MJ270R switching off when transmitting
Turning off while transmitting is typically a sign of a weak or bad battery. However, since you mention it happens with either battery type, another cause might be the length of time you are depressing the PTT button. These radios have a fail-safe to prevent damaging the final amplifier of the radio. To protect itself the radio will shut down or stop transmitting after the PTT button is held in too long. This being said, I'd check the batteries first. The rechargeable battery pack which came with the radio has a one year life expectancy. A battery can test full when it is weak and might not hold the charge when placed under a load. And usually transmit is the first thing to fail.
Best regards.
Jan 24, 2012 | Motorola MJ270R Two Way Radio
Radio stuck in RX mode.
Your PTT button is possibly at fault. It may be partially depressed, leaving your receiver open. Behind your PTT button there is an internal PTT button on the componet board. It may be stuck or defective.
Feb 28, 2010 | Radio Communications
Transmit button on the lapel mic will not key the radio
Two things which come to mind, one would be if the PTT on the remote mic is bad/defective, second would be you are plugging the audio device in with the radio turned on.
If your remote mic is failing, the PTT is a repairable item, as is the cord on most models.
Mar 30, 2009 | Motorola MU21CV (1 Channel) 2-Way Radio
T8500 blinks off and back on often when transmitting
It takes more energy to transmit than to receive. It is possible you have an old or defective battery pack, a bad connection to the battery, or your PTT button is not working properly. On this unit, the internal PTT button can begin to be bent further in from repeated use, or pressing too firmly.
As far as a more durable/reliable radio, you might want to look at radios in the business division such as the Motorola CP110, BPR40 or the CP150. These business level radios are built to work a 40+ hour work week, and are much more reliable than the consumer division products, which are intended for occasional usage.
Jan 17, 2009 | Motorola Talkabout T5720 (7 Channels)...
One radio continually transmits
Hello
This could be the Ptt Switch , Midland is 3 Years warranty try to claim the warranty, this is a Factory fault.
Oct 25, 2007 | Midland LXT303-A 2-Way Radio
Garmin Rino 110 (14 Channels) 2-Way Radio Logo
57 people viewed this question
Top Garmin Radio Communications Experts
eradiostore
eradiostore
Steve
Computer Repairing
Computer Repairing
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
