Question about Garden
Black and decker as185-2
Power cuts out when cord is moved at certain angle
  • 2,113 Answers
It's time to cut the cord shorter. Disassemble and cut out the bad part of the cable and either marrette or add crimps etc to put it back together... or get a new cord cap.
Posted on Oct 15, 2013
I have a black and decker jigsaw that the plate you put on the wood moves and the cut angled and I do not it to?
Hi John:
These saws are usually really reliable, and SOLID.
I'd suggest that you UNPLUG THE SAW and then explore a bit. Look for loose bolts at the pivot points, or possibly a poorly fitted bolt. If this is your saw that you have had for some time, you should know what maintenance has been done that possibly caused this problem.
Oct 03, 2015 | Saws
1 year old starting spitting out possible cord pieces and hitting me in shin area. at first I thought it was little rocks or pebbles,,but not
The cord is not properly wound on the center spool, or there is dirt, grass, plant parts, etc. in the spool release mechanism.
First step clean and check the spool and release.
Jul 27, 2015 | Black and Decker USA Black & Decker 12"...
No start on a mm 1800 18"
check the cord for cuts then check the safty engagement on the handle and make sure it disengages to cut thats about all you can do turn blade make sure turn freely not plug in after you will have to take it in
May 31, 2014 | Black & Decker Black and Decker Mm575 18"...
Black and decker lawn hog 18 was working fine last time used but will not start now what,s the problem
while unplugged rotate the blade a few spins to move the brushes if there stuck make sure the outlet is good and try another power cord
Aug 13, 2012 | Black & Decker Black and Decker Mm575 18"...
Angle grinder head is worn how can i fix it
http://www.ereplacementparts.com/search_result.php
Why not replace the worn part?It would be safer.
May 09, 2011 | Black & Decker Black Decker Decker G750 4...
Need new brushes
Match them up at ace hardware. Pull the screw out of the back by the cord. And slide that half down. Your brushes are exposed. Use the same spring that was in before and toss the new ones, unless they are close to the original. The ones that matched a recent 7750 (type 3) was #61702. Good luck.
Apr 10, 2011 | Black & Decker 7750 4 1/2'' Small Angle...
When I try to cut with my saw, the blade bends so that the cut is at an angle. Because of this angle cut, it is difficult to follow a line but even if I can follow the line, the angle cut through a 3/4...
This is a common issue with jig saws. There are sometimes larger blades, but all seem to distort to some degree. The only real solution is to go slow enough to allow the blade to return to it's normal shape...Essentially, is sounds like another tool would work better, but often you are scrolling with a jig saw and circular saw (for example) would not work.
The other workaround involves several cuts, so the final cut is removing much less material.
Nov 07, 2010 | Black & Decker Black decker Firestorm...
I have a Black and Decker Band Saw Model 9422 Type 1. I do not have an owners manual. I would like to move the cutting table to a 45 degree angle and find that I do not know how to do that. Without the...
You should have 2 hand wheels under there, or bolts, loosen them up, tilt the table, all set. Most band saws tilt, even the smallest and the least expensive. Hope this helps.
Feb 02, 2010 | Black & Decker Saws
Ground Wire?
You don't. It's a double insulated tool.
Jun 12, 2009 | Black & Decker 4 1/2" Small Angle Grinder
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
