Question about GMC Vehicle Parts & Accessories
How to replace 2007 Yukon fog light assembly?
    New Friend:
    Problem Solver:
  • 8 Answers
Remove the right or left wheel liner. (Depending on which lamp you are removing)
From the inside of the bumper fascia, using a blunt instrument, pinch the retainers and push outward on the upper mounting studs for the fog lamp.
Pinch the retainer and push outward on the lower adjustment screw for the fog lamp.
Posted on Oct 15, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Where is the fuse in a 2007 Dodge Nitro that powers the fog lights?
Dodge does not use a fuse to control those lamps. Dodge uses a Totally Integrated Power Module or TIPM which controls the power to the lamps. This thing is located in the Engine Compartment in that big Fuse Box next to the engine. The unit is not a fuse but rather a self contained processor that regulates power to the Fog Lamps. This unit is replace as an assembly as it is not user serviceable. But before replacing it make sure the lamps actually work as simple as that is it is often overlooked. One more thing Dodge has employed the use of Circuit Breakers in the Wiring Harness so make sure they are working as well.
Feb 07, 2015 | 2007 Dodge Nitro SLT
2007 yukon denali back window might of came off track w
The window motor and regulator are one unit. There is a known defect with this assembly. The regulator assembly cable breaks. The regulator needs replacement. This causes the window to become dislodged from track assembly.
Apr 17, 2014 | 2007 GMC Yukon Denali
I have moisture inside my headlight on my 2007 gmc denali. will i have to replace the entire assembly. The lamp is out, could that cause the moisture. Or does the moisture cause the lamp to burn out.
{: ) Some exterior lamps, such as cornering, turn signal, backup, headlamps or tail lamps may exhibit very small droplets of water, a fine mist or white fog (condensation) on the inside of the lamp lens. This may be more noticeable on lamps with "multi-lens" designs and may be normal during certain weather conditions. Condensation occurs when the air inside the lamp assembly, through atmospheric changes, reaches the "dew point". When this takes place, the moisture in the air within the lamp assembly condenses, creating a fine mist or white fog on the inside surface of the lamp lens.
Most exterior lamps on General Motors vehicles use a vented design and feature a replaceable bulb assembly. They are designed to remove any accumulated moisture vapor by expelling it through a vent system. The vent system operates at all times, however, it is most effective when the lamps are ON or when the vehicle is in motion. Depending on the size, shape and location of the lamp on the vehicle, and the atmospheric conditions occurring, the amount of time required to clear the lamp may vary from 2 to 6 hours.
Completely sealed headlamp assemblies (sealed beams) are still used on a limited number of models being manufactured today. These lamps require the replacement of the complete lamp assembly if a bulb filament burns out.
If moisture or droplets appear after being exposed to rain or washing, you can try putting some weather seals on the edges where you think the seal is poor. Check also the headlamp caps. In any case, if the moisture doesn't clear no matter what drying approaches, better replace the assembly.
The bulbs won't cause the moisture, but it is possible that an accumulated moisture on the bulb itself can disable it, although rare.
Jun 27, 2011 | 2007 GMC Yukon Denali
How do you replace the fog light bulb on 2008 avalanche
    • 1 Open the hood and reach down into the engine bay for the fog light assembly. If you cannot reach the fog light assembly from the top you may need to get underneath the truck to reach it. Remove the electrical plug running to the fog light ballast.
    • 2 Remove the bulb. Unlock the fog light bulb by turning it counterclockwise and pulling it straight out of the assembly.
    • 3 Slide a new bulb into the fog light assembly. The part number you will need for the new bulb will be located on the ballast or base of the old bulb.
    • 4 Turn the bulb clockwise to lock it into the fog light housing.
    • 5 Reconnect the electrical connector to the bulb ballast.
Jan 23, 2011 | 2007 Chevrolet Avalanche LTZ
HOW DO YOU CHANGE THE BULBS OF THE FOG LIGHTS?
The fog lights on most vehicles sit directly underneath the headlight bulbs. The ballast and wiring work just like the headlights, so changing them takes not much time. The procedure to change the fog light is as follows:-- 1) Open the hood and reach down underneath the headlights to unplug the electrical plug from the fog light assembly. Squeeze the top of the release tab and pull the connection off the bulb's ballast. 2)Turn the fog light counterclockwise to remove it from the fog light housing. 3)Install the new fog light bulb.Then connect electrical plugs properly. 4) Test the fog lights by turning it ON. Thanks. you can rate this solution and show your appreciation.
May 20, 2010 | 2002 GMC Yukon XL
How do you replace a fog lamp assembly on a 2007 Toyota Rav4?
If you have the replacement fog lamp, examine it's fitting brackets and there's your answer ! Usually 2/3 mounting screws and the alignment adjustment screw. Good luck
Apr 10, 2010 | 2007 Toyota RAV4
Replace fog light bulb for 2006 Honda Odyssey
Touring Model
Use a wrench to remove the mounting bolt from the underbody through the hole in the splash shield.
Remove the fog light assembly from the bumper by pulling its inner edge first, then the whole assembly out of the bumper.
Remove the electrical connector from the bulb by pushing on the tab and pulling the connector down.
Remove the bulb from the fog light assembly by turning it one quarter turn counterclockwise.
Push the electrical connector onto the new bulb.
Turn on the fog lights to test the new bulb.
Reinstall the fog light assembly into the bumper. Tighten the mounting bolt.
Insert the new bulb into the assembly and turn it one-quarter turn clockwise to lock it in place.
Hope this helps you.
Nov 22, 2009 | 2006 Honda Odyssey
How do I change bulbs in front parking lights on my 07 gmc yukon?
when the hood is open look behind the light assembly the bulb is connected to the back just twinst off both sides sometimes you will need to remove the whole light assembly from the vehicle usually four bolts
Nov 03, 2009 | 2007 GMC Yukon
How do i install driver side fog lights
I bought the factory kit from Ebay. It came with clear instructions including the new headlight switch assembly that includes the fog light switch. I think it was under $150. Once installed, you have to see the dealer so they can program the computer to run the new lights.
Dec 26, 2008 | 2007 Dodge Magnum SRT8 Wagon
My 2007 Yukon's Entry light wont come on at all.
Look on the left side of the stering wheel and there should be a switch that is for you foglights. On that same switch under the fog light switch there is a button for all entry lights on or off. Just hit that button.
Jul 30, 2008 | 2007 GMC Yukon
Vehicle Parts & Accessories Logo
57 people viewed this question
Top GMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Todd Arndt
Todd Arndt
Are you a GMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
