Question about Kenmore Microwave Ovens
Model #721.79152010 microwave lights up but won't work
The lamp of won't work
follow the steps and fix it. God bless you
ight Bulb
If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
Main Control Board
If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
Light Bulb Socket
If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Sharp microwave & convection & turn table on model R1874F won't work
That would be just a defective secondary interlock (bottom door switch) or its mount.
My help file on door switches is here.
The service manuals you need are here and here.
You can get other Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Jan 07, 2013 | Microwave Ovens
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
Door open button won't work on KitchenAid microwave model YKCMS135H
Page 3 of the exploded view here shows the door open parts 24510L and 250201 (or 23551B if your full model number is YKCMS135HSS).
What look like part numbers seem to be reference numbers.
For further help you will need to contact Kitchenaid Canada here.
Sep 05, 2012 | KitchenAid KCMS1555RSS Stainless Steel...
My microwave is an LG model, lights turns on and make normal sound but won't cook or heat.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 05, 2011 | Microwave Ovens
We have a sunbeam microwave. it starts but the light doesn't work and it won't heat the food. what should we do?
heatman101 ;'
Sep 01, 2011 | Sunbeam SMW750 Microwave Oven
I have Problem with my microwave
it may be just a fuse , but if the fuse inside the microwave blows again then there is something else wrong and it would need to be tested to find the problem and fix it
so the fuse inside needs to be check and or replaced and if the microwave powers and works ok after replacing the fuse , then the other fuse was just bad
Jan 11, 2009 | Emerson MW8108P Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
