Question about Omron Healthcare Omron H3cr-a-ac100-240v Timer 0.05s-600h Dpdt 5a250vac
How do I wire a 11 pin OMRON H3CR-A timer.Confused with the wiring labelled on it especially diffrenciating the active and the neutral sides to activate the coil which will consequently start the timer operation.
  • Omron Health... Master
  • 5,245 Answers
2 Suggested Answers
SOURCE: I use Omron H3CR 8pin
I don't have exact schematic for your 8-pin timer.
Use multimeter read ohms and voltage from pin socket to pin socket.
Use multimeter set to ohms to read continuity of pins on timer.
Pin timer relays have NO NC pins.
Some pins are Normally Open (no current flows until timer turns on)
The other pins are Normally Closed (current flows until timer turns on, and when timer turns on, this circuit turns off)
Posted on Apr 08, 2011
11 PIN OMRON H3CR-A TIMER CIRCUIT
i found a wiring diagram using google search term h3cr-a use images tab 11 is a common 8 is nc 9 is no
Oct 15, 2013 | Hardware & Accessories
H3CR 11 pin
1) When oven turns ON, Power flows between the timer and the oven.
http://waterheatertimer.org/How-to-wire-pin-timers.html
2) For example the oven might be connected to pins 8 and 1.
Connect a light bulb to terminals 8 and 1.
http://waterheatertimer.org/images/10-pin-wiring-350.jpg
3) Since the H3CR timer is rated max 16 amps, I suspect the timer controls a contactor and is not directly attached to heavy oven wires.
So if max amp load on timer is 16 amps, then it is safe to add light bulb wire without line fuse between timer and light.
http://waterheatertimer.org/Fuseholder.html
4) Add comment and say what you are doing.
Jan 21, 2013 | Hardware & Accessories
Wiring diagram for Omron off delay timer
Which Omron timer?
The model and wiring diagram appear on side of timer.
Add a comment with more details and I can track down the information.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Omron
Sep 07, 2012 | Amperite Dayton Solid State Timer On Delay...
Omron H3ca
Delay timers usually start with a push button, or momentary impulse of power. The delay begins when the impulse power ends.
H3CR-A is solid state multi-functional pin timer available in 8-pin and 11-pin models.
11 pin has six modes, and 8 pin has 4 modes
http://waterheatertimer.org/pdf/OMRON_H3CR-multi-function-analog-sell-sheet.pdf
How many pins do you have?
What exactly are you controlling with the timer?
And what function are you using?
Sep 04, 2012 | Omron H3CA-A Multifunction Digital Timer
I need a wiring diagram for an Omron H5CX-A timer
Wiring will appear on side of timer.
Test the timer with multimeter to see which terminals are connected. When timer has no power, then Com and NC terminals will have continuity.
H5CX-A Timer has 11 screw terminal connections and timer is rated 100V to 250Volt AC 50-60Hz.
Input is power IN > this is the 100V to 250Volts coming from breaker box or transformer. For example input terminals might be labeled A and B.
This will give power to timer, but remainder of screw terminals have no power.
To put power to relay terminals, jumper the power from Input terminal A to COM terminal.
For example Com terminals might be 7 and 9.
So jumper Hot wire from Terminal A to terminal 7.
This action will put hot on Com terminal 7, but also give power to the NC terminal.
For example the NC terminals might be 1 and 3.
So when timer is OFF, the NC terminal has power.
Then when timer turns ON, the NC terminal no longer has power, but the NO terminals are Hot.
NO terminals might be 4 and 6, and these terminals turn on-and-off when timer turns on--and-off
Open following link to help with Omron 11-pin wiring:
Jun 14, 2012 | Omron Hardware & Accessories
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
I use Omron H3CR 8pin to my CCTV in my car. I use pin 2 for ground,pin 7 for ignition, pin 4&5 for direct current from battery and pin 8 to +ve CCTV. My problem is when I off the engine the timer is...
Apr 08, 2011 | Omron Healthcare Omron H3cr-a-ac100-240v...
How to set the time and which is on out or in
pins IN = timer ON
pins OUT = timer OFF
Slide-switch must be pushed to right for timer to work
If dial is not rotating, wiring is incorrect (see below for wiring)
__________________________________________
Grasslin and Paragon both offer multiple-gang timers.
Grasslin manual says:
" For example, to turn lights ON at 5:00pm and OFF at
11:00pm, leave inward the 18 trippers between 5 and
11 on the "pm" side of the dial.
Link to Grasslin manual
Wiring timer:
Timer black goes to Hot wire
Timer red (or blue) goes to Load
Timer white goes to Neutral (if no neutral, then connect to bare ground)
If timer dial does not rotate, black and red wires are reversed
Oct 08, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Omron Healthcare Omron H3cr-a-ac100-240v Timer 0.05s-600h Dpdt 5a250vac Logo
278 people viewed this question
Top Omron Healthcare Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you an Omron Healthcare Hardware and Accessory Expert? Answer questions, earn points and help others
