Question about Kenmore Washing Machines
How do you replace the sensor - Kenmore Washing Machines
    Master:
  • 818 Answers
What sensor are you trying to replace-Denny
Posted on Oct 15, 2013
Replace camshaft position sensor ?
need more information since each manufacturer puts the sensor in different spots --generic answer --the following link shows different vehicles sensors being replaced
How to replace camshaft position sensor in your vehicle Camshaft Position Sensor Replacement Replace Camshaft Position Sensor Yahoo Video Search Results
Aug 31, 2016 | Cars & Trucks
Oven won't heat flashes F2EO and 5D on
List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appears, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad. Replace Keypad.
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Below applies only to the two digit display models for the brands above.
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Mar 20, 2016 | Ovens
How many o2 sensore are on the 99 bravado? I replaced the o2 sensor before the cat converter, now code says bank one( before cat.) needs replacing. are there 4?
the sensor before the cat is NOT an O2 sensor but a HO2S sensor ( two different sensors with different operations). If this is a V6 engine there are 4 sensors -- 2 --HO2S sensors before the cats --one for each bank cat and 2 O2 sensors after the cats.
The fault code would have spelt out the correct sensor for replacing
Jan 24, 2015 | 1999 Oldsmobile Bravada
My car is misfiring
I own a 2000 avalon and had a similar issue, rough idle especially when stopped, car felt like it was going to stall. I had a couple error codes which included one of the o2 sensors and knock sensors. I replaced the pcv valve , and o2 sensor, both easy fixes, but tue knock sensor is in the top half of the engine. Cost me 500 bucks to replace, install knock sensor at shop. After knock sensor was replaced and other o2 sensor replaced, no more idle issues. What happens if an o2 sensor on one of
Mar 02, 2014 | 2000 Toyota Avalon
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Canon3100 with code e000020-01a9 and -02a9 and -03a9, turned off. checked drum, fuser seems ok help
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
XX10 In INIT control of the initial setting,
SGNL is less than 62. Clean the ATR sensor window, Check on attachment of the developing unit, Check on a break
in the ATR sensor, Replace the ATR sensor
XX11 In INIT control of the initial setting,
REF is less than 62. Check on a break in the ATR sensor, Replace the ATR sensor
XX12 In INIT control of the initial setting,
SGNL is 960 or more. Check on a break in the ATR sensor, Check on operation of the shutter, Replace the ATR sensor
XX13 In INIT control of the initial setting,
REF is 960 or more. Check on a break in the ATR sensor, Replace the ATR sensor
XX50 When density data is computed using
SGNL value and REF value in ATR
control, REF becomes 0 due to backup
data corruption.
in the ATR sensor, Replace the ATR sensor,
Replace the DC controller PCB
XX51 When density data is computed using
control, the sensitivity coefficient
becomes 0 due to backup data
corruption.
XX81 P-SENS-P is less than 255 when a base
(drum face) of patch detection is read
out.
Clean the patch image reading sensor window
XX90 A computation result of patch reading in
patch detection is less than 16. Check on attachment of the developing unit, Replace the patch image reading sensor, Replace
the developing unit
XX91 A computation result of patch reading in
patch detection is 1008 or more. Check on toner leak from toner buffer in the developing unit, Replace the patch image reading
sensor
XX92 A computation result of patch reading in
patch detection is less than 42 for Y/M/
C and less than 73 for Bk 3 times in
succession.
the developing unit
XX93 A computation result of patch reading in
patch detection is 522 or more for Y/M/
C and 543 or more for Bk 3 times in
succession.
sensor
XXA0 In ATR control, SGNL is less than 62. Clean the ATR sensor window, Check on
XXA1 In ATR control, REF is less than 62. Check on a break in the ATR sensor, Replace the
ATR sensor
XXA2 In ATR control, SGNL is 960 or more. Check on a break in the ATR sensor, Check on
XXA3 In ATR control, REF is 960 or more. Check on a break in the ATR sensor, Replace the
ATR sensor
XXA8 In ATR control, the detected T/D ratio is
upper than its upper limit (13%) 10
times in succession.
developing unit, Replace the ATR sensor
XXA9 In ATR control, the detected T/D ratio is
lower than its lower limit (3%) 3 times
in succession.
BUT FIRST: Check the ATR SENSOR, left from the developing rotor you have an "rail" with atr sensor - vacume it!!!!! Vacum all dev units, and copier
Apr 20, 2010 | Canon imageRUNNER C3200 Copier
F3 code
F3 E0 5 Top oven sensor open Check for open circuit. Sensor resistance should be 1K to 1.1K @ room temperature. If not, replace the sensor. F3 E1 6 Top oven shorted Check for shorted sensor circuit, otherwise replace sensor F3 E2 9 Bake range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control. F3 E3 8 Clean range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control. F3 E4 10 Bottom oven sensor open Check for open circuit. Sensor resistance should be 1K to 1.1K @ room temperature. If not, replace the sensor. F3 E5 15 Bottom oven sensor shorted Check for shorted sensor circuit, otherwise replace senso
Feb 24, 2010 | Whirlpool GS460 Gas Kitchen Range
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F7 Shorted Touch Panel Replace Glass Panel
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F2-E0 Shorted Keypad Replace Keypad
Ovens with 2 Digit Displays
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2009 | Ovens
Where is iat sensor located on 2000 mazda mpv van . i have a p0113 code and cant find sensor
the IAT sensor is part of the Mass Airflow sensor. here is a picture of that sensor.
Dec 16, 2009 | 2000 Mazda MPV
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Washing Machines Logo
13 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
