Question about Koolatron ABC1 Thermoelectric Cooler Adapter and Battery Charger
I am looking for the wiring diagram of the koolatron ABC-1 adapter battery charger, One component burned up and I can't read its value.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 53 Answers
Send me snap
Posted on Oct 15, 2013
Need a circuit diagram of a dewalt charger DE9108-xe 7.2V-18V one hour charger type 1:Q 96307-12/15 OUTPUT : 2.6A 7.2-18.0V 46.8VA
Can you (carefully!) measure the volts across them with a load (battery) and then the current through them by disconnecting one end, and if the charger is still working OK then they are V/I ohms, choose nearest value. 10k sounds very high, are you sure they aren't 1 ohm or less?
May 21, 2014 | Dewalt 7.2-18.0 Volt One Hour Charger
Hp laptop charger 90w 463955-001 burned component
Adapter arrived promptly, but did not have a "dongle." Seemed to work well for about 6 months but then did not charge laptop battery and only worked plugged in. Eventually a computer technician friend pointed out the adapter was too light to be real - compared my original adapter it weighs about half the weight. Not very impressed and would not recommend. I have no complaints about this item whatsoever, for all intents and purposes it does everything my original AC adaptor did.
http://mhelpdesk.com/field-service-management-software/
Nov 11, 2013 | HQRP 90W Laptop AC Adapter / Charger...
Hp dv4 no power
first remove battery then use charger for 1 min
then attach battery then charge it if not
it is problem with *********** board
plese once check another adapter
Oct 24, 2012 | HP Pavilion dv4-1145go Notebook
I have a B&D Firestorm 18v 1-hour battery charger, model 5100235-09 (240v). When I insert a battery to charge, only the green "battery full" LED lights immediately. But the battery never...
Hi I have same problem with the charger. Solution is to replace the charge with new part number issued from B&D Australia
Number of 90515050-01 until stock runs out , then it is replaced by part number of 90578873 early to mid june 2013.
Hope this helps
Lance from Perth , Western Australia.
Jun 19, 2011 | Black & Decker Drills
Looking for wirring diagram for schmacher SE-1275A battery charger. Wires got pulled out of component need to know where white wire & black wire goes.
yay I emailed schumacher asking about this and they got bak to me within 12 hours or so with EXACTLY what I needed
I looked a long, long time without finding anything like this online, and many different people asking the same questions
so please save this picture for your records, and if you have a minute, go post it on an unanswered schumacher battery charger wiring diagram question
Jan 18, 2011 | Schumacher DSR ProSeries Battery Charger -...
Hi I have an inspiron 1525 and when I boot it up I get a message that the computer does not recognise the AC charger. The charger actually stopped working and I had to pull the power cable from it and...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
Sep 11, 2010 | Computers & Internet
I have 110 volt durapro 18volt dc battery charger, component R14 has burnt out beyond recognition and I was hoping someone could tell me exactly what it is so I can replace it. Thanks
The component is a resistor. The problem is going to be determining the resistors value since it was burnt and you can not see the color code. You might try contacting the manufacturer and asking them the value of that specific resistor by including the number like you did in your post R14. If you can find a wiring diagram for the product, it should tell you the value of the resistor also.
I hope this helps you getting started in solving the issue.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Feb 07, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I lost my battery charger thinghy ......... can I buy another one? Where?
The charger needs to be 9.5 volts DC,2-1/2 amps. The polarity(plus or minus) is shown on the side of the unit. (It is negative on the outside and Positive on the inside) DO not reverse the polarity or you will damage the device.
You can buy universal changeable chargers at places such as Radio SHack, Best Buy, ABC Warehouse, and other stores.
Jan 24, 2009 | Zenith DVP615 Portable DVD Player
Wiring
Hi Mitchmath,
One of our scientists has just asked me to take a look at his Koolatron (which he is using as a field incubator), it seems he is having similar problems to yours. I expect to have it apart tomorrow so will post a wiring diagram after I have
Jun 14, 2008 | Koolatron P-85
Koolatron ABC1 Thermoelectric Cooler Adapter and Battery Charger Logo
108 people viewed this question
Top Koolatron Refrigerators Experts
Ilia Bichin
richie46
Your Consultant
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
