Says dl and blinks. Abs beeps - Washing Machines
    Master:
  • 818 Answers
I fell like your washing machine is trying to tell you something-what make and model number is it-Denny
Posted on Oct 15, 2013
    Master:
  • 492 Answers
With all electronics unplug the machine for about 2 hours. This will ensure that the capacitors on the board discharge. Then plug in the machine again and try to operate normally. This will load a fresh set of code into the chip and rest anything that is not damaged. We usually never remove power to the board. It's like rebooting your computer.
ABS disabled
abs dont beep. alarm does. you will need to check this. abs alarm and ecu and immobiliser etc are linked. I.e locked to you make and model and serial code. alarm can beep and knock out one of the units. sometimes if this fault happens it can be a simple problem like the external alarm unit has its own power but is charged from the main battery. these can go wrong, will beep. you can disconnect this part of the alarm. there is the back up alarm part. I would check this.
Feb 23, 2014 | Cars & Trucks
Abs and brake light blinks with beeping sound on my 2000 audi quattro A4 1.8T. What could be the problem? How can I fix it?
Check & replace if necessary the brake pedal switch placed above pedals on the support.
If the problem still occurs you might access the ABS ECU (Electronic Control Unit) using diagnostic equipment connected to the data link connector of the car, in order to pull out all DTC (Diagnostic Trouble Codes) memored.
Then you will be able to replace bad piece(s) and fix the problem by erasing all DTC stocked inside ABS ECU & reset it.
Dec 14, 2010 | 2000 Audi A4
ABS light and brake light on
there are 2 options, ABS module is most likely, I just had my ABS module remanufactured and it worked greate when i re-installed.
the second option is the wheel sensor could have a bad connection(may have been bumped when your bearing got looked at.
there are a few companies that repair ABS modules, i used modulemasters, they did a good job, i can not vouch for any of the other companies.
May 03, 2009 | 2000 Volkswagen Beetle
ABS doesnt work I want to cut the Beep sound.
This is an idnication that you have a foult in your ABS system and need to have it checked with a scan tool.
Feb 04, 2009 | 2000 Volkswagen Golf
Not sure
Do you get a flashing ABS light or BRAKE light along with the beeps? If so, this is indicative of an ABS failure, which is either a wheel speed sensor or (much more likely) the ABS controller. I've had an ABS/wheel speed sensor fail on my A4 and I had no beeping, but people I know have had the beeps and had to replace or rebuild the ABS module. If you do have this problem, go to www.modulemaster.com and call them - they can rebuild the ABS module for a couple hundred dollars give or take, versus several times that cost for a new one.
If you are only getting the beeping, but not the lights flashing, it could still indicate this failure, but Audi usually has the cars set up to indicate what is wrong by flashing lights as well as the beeping, to help you see what the problem is.
Jun 23, 2008 | 1999 Audi A6
DL flashes over and over
unplug machine for 2 minutes this will reset the computer if problem continues look behind bottom front cover and there is a tech sheet that will tell you what the f code is the DL code is bad door lock assembly. it could be the main control (mother board throwing you these codes) Ive seen this happen before
Dec 14, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool HE4t front load washer problem
The dl means doorlock. These machines are notorious for bad solder joints in the main control board in the door lock circuit. You could have a bad door latch but I doubt it.
You can keep trying to start it and sometimes it will work and sometimes not.
Remove the top of the washer. It is held on by three screws at the rear of the top. Slide back and lift up.
You will see the control at the top rear of machine. There are two connectors that plug to the board with pink wires. The board will be marked dl1 and dl2 where they plug in. Wiggle these connectors and try the machine again.
If your machine is less then 2 years old the board may still be covered by warranty. Check your owners manual for details.
Post back and let me know what happens.
Oct 27, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
