Question about True Fitness TPS100 Treadmill
Memory fail error on True Modeel TPS100 treadmill
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
What does treadmill error code E1 mean?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Here's a link to more error codes:
Error Code List for Precor Fitness Equipment
May 26, 2014 | Precor Exercise & Fitness
Precor treadmill code e3 is on
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 03 E03 EEPROM Test Error
Oct 18, 2013 | Precor C954 Remanufactured Treadmill
Precor error code 1
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on Precor Error Code 01
Aug 18, 2013 | Precor 9.21 Treadmill
I have a VL0901 treadmill that displays error 9 when I turn it on. How do you clear this as nothing works.
follow this troubleshooting and fix it. God bless you
Error 09, Lower PCA Memory Test Error
Probable Cause Most commonly indicates a problem with the lower PCA when the error consistently appears. It is rare for a failure to occur that would cause this error.
Corrective Action
  • The lower PCA should be replaced if the error consitently appears at power up.
    1. External causes may make the error appear intermittently.
      1. If the AC input of the unit dips significantly during power up test sequences, the test could fail causing the error to appear.
      2. A treadmill connected to a non-dedicated AC circuit can experience this error intermittent
    Jul 29, 2013 | Exercise & Fitness
    Error code 1 and 3 on my Precor 9.21s treadmill?
    Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
    Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
    Error 0 problem
    see the error +causes +remedy:God bless you
    Description
    Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and
    EEPROM checksum during the power up test sequence. If a fault is found during the power up
    test sequence, the appropriate error code will be displayed.
    Possible Causes
    1. These errors messages almost always indicate an upper PCA problem when they are
    consistently displayed. Failures causing these error messages to be displayed are rare.
    Possible Remedies
    1. If the error message is consistently displayed when the unit is powered up, the upper PCA
    should be replaced. It is possible to see one of these messages displayed intermittently due
    the test could fail resulting in one of these messages being displayed. Treadmills operating
    on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.2_4_2013_5_52_44_pm.gif
    Feb 04, 2013 | Proform Sport 1000 Folding Treadmill...
    Treadmil t733 shows E9 error and soes not start
    Dear Sir:
    Hello I hope you are o.k
    I wil give some tipoe with this Error code:
    Error 09 - Lower PCA Memory Test Errors
    Description
    Error 09 checks lower PCA memory locations during the power up test sequence. If a fault is
    found during the power up test sequence, error 09 will be displayed. This error code is only used
    on products utilizing the dual microprocessor system.
    Possible Causes
    1. This error message almost always indicates a lower PCA problem when it is consistently
    Possible Remedies
    1. If the error message is consistently displayed when the unit is powered up, the lower PCA
    should be replaced. It is possible to see this error message displayed intermittently due to
    Thank you in advance, sincerely. Blessing.
    If you need additional Help, please reach me.
    E.CUADRA
    Managua, Nicaragua. C.A.
    Sep 28, 2011 | Exercise & Fitness
    9.1.0 TREADMILL PRECOR PACE ERROR 3
    Dear Sir:
    Hello I hope everything is fine.
    I will give some Tips:
    Description Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and EEPROM checksum during the power up test sequence. If a fault is found during the power up test sequence, the appropriate error code will be displayed. Possible Causes 1. These errors messages almost always indicate an upper PCA problem when they are consistently displayed. Failures causing these error messages to be displayed are rare. Possible Remedies 1. If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see one of these messages displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in one of these messages being displayed. Treadmills operating on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.
    In other words, you need recalibration in your equipment, I recomend after you make a test for a RAM MEMORY.so contact your service call. I recomend Strong, INSTALL regulator Voltage is cheap about us$15,00 Radio Shak or another Electronic Place.
    Thank you in advance , sincerely. Blessing. If you need additional Help, please do not hesitate to contact me.
    E.CUADRA MANAGUA, NICARAGUA. C.A.
    Sep 25, 2011 | Precor 9.21 Treadmill
    True Fitness TPS100 Treadmill Logo
    354 people viewed this question
    Top True Fitness Exercise & Fitness Experts
    Ross Metcalfe
    Ross Metcalfe
    Howard
    Howard
    Tom Chichester
    Are you a True Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
