Question about Wildgame Innovations X6c Digital Scouting Trail Camera
Realtree pro series trail camera blinks and takes black photos and said file is empty.
Where can I get a Manual for a Realtree x6c trail camera?
Go to manufacturer website for user download
Oct 13, 2015 | Cameras
How do i erase the internal memory from my trail camera
Think of your camera as a flash drive. Plug your camera in to your laptop using the USB cord. A window should appear showing a folder which inside are all the photos on your camera. Think of your photos as files in which you can copy, paste, or delete. You can copy them, then paste to a folder on your computer or laptop. Or, you can simply delete clearing the memory on your trail camera..
May 25, 2014 | Moultrie GameSpy 4.0 Digital Camera Deluxe
How do i clear the internal memory from my trail camera
Think of your camera as a flash drive in which you can copy, paste or delete files. Plug your camera in to your laptop using the USB cord. A window should appear showing a folder which inside are all the photos on your camera. Think of your photos as files in which you can copy, paste, or delete. You can copy them, then paste to a folder on your computer or laptop. Or, you can simply delete clearing the memory on your trail camera..
Why does my moultrie mlb-800i take pictures fine then read card error after around 400 pictures
If you are using a micro sd card not compatible. If you have deleted pic from another camera has different format file. If still having the issue call Moultire 8006533334 option 1 and 1 for a live person will need the equipment with you to troubleshoot the issue.
Sep 29, 2013 | Moultrie MLB 8MP 800I Black IR Trail...
How do I delete the photos from my SD card in my AXE 2 Trail Camera (Wildgame Innovations)
Just plug the cam into your laptop with the USB cord. Navigate on your computer to the video or picture files for the camera. Select the files you would like to delete (just as you would with any other files on your computer) and then simply delete them.
Sep 02, 2013 | Wildgame Innovations Axe 2 2Mp Game Camera
How can I import Panasonic HPX 250EJ project into Final cut pro?
The AG-HPX250 Memory Card Camera Recorder is a new handheld model for Panasonic's broadcasting and professional P2HD Series. It's also the first handheld model to support AVC-Intra codecs. So you may find that it's not easy to import such a file directly into FCP. Pavtube MXF Converter for Mac can help you convert AVC-Intra encoded MXF to FCP compatible ProRes codec, then you will have to problem to import the projects, pls download a free trail version from below.
http://www.pavtube.com/mxf-converter-mac/
Jan 02, 2013 | Video Cameras
My memory card is completely empty, all photos
You need to reset the file-numbering.
Turn mode-dial to Set and turn on the camera. Select Frame No. from the setup menu. Switch Frame No. to Renew. Press OK. Format the card (also from the Setup Menu) After formatting, select Frame No. againg and switch to Cont. File numbers will now start from 100.0001 again
May 10, 2010 | Fuji FinePix S7000 Digital Camera
Wildgame Innovations X6c Digital Scouting Trail Camera Logo
Top Wildgame Innovations Home Security Experts
 Mikey
Mikey
Jay Plesset
Are you a Wildgame Innovations Home Security Expert? Answer questions, earn points and help others
