Question about Brother Sewing Machines
I have a new Brother se400. Recently, when I am embroidering, the machine is picking up the white bobbin thread and either stitching the entire design in the bobbin thread or putting colored thread in the middle of the design and then stitching the edges of the design in the white bobbin thread. I am using prewound bobbins and wasn't having any problems. Please help.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Sound s like top tension too high, bobbin tension too loose, or a needle issue - dull or incorrect one for the fabric.
Change the needle, check tensions.
Have you stabilised the fabric?
Posted on Oct 19, 2013
  • 4 Answers
SOURCE: top thread wraps around bobbin
Is it birdnesting under the bottom or it is actually getting tangled inside the bobbin case? I've had my machine for almost a year and don't think I've had your exact issue. Sometimes, when you do a stich over a already stitched portion, you may have a problem with the bobbin and I just generally stop and start it again. It is important that you use the correct needle and also use a good embroidery thread and stablizer. Another thing suggested is changing the needle after about every 5 designs. Also, check the bobbin case to make sure there's no fuzzies caught in it. I use "canned air" like you use on computer keyboards. I also only use 40 weight emboidery thread for the top and actual bobbin thread for the bottom. Other threads can really jam everything up. So it's been trial and error to find the right combinations. Good Luck!
Posted on Jan 16, 2008
SewExpress
  • 41 Answers
SOURCE: Picking up the bobbin thread
A few suggestions:
  1. Rethread top of machine from scratch with the presser foot raised, i.e. remove thread completely from all thread guides & paths and start from scratch, making sure thread is securely seated between tension disks. Once the needle is re-threaded, lower the presser foot and give the tail end of the thread a tug to make sure there's tension on it.
  2. Make sure the bobbin is turning the correct direction for your machine - and that the thread tail is under the tension plate or bobbin tension guide (depending on machine).
  3. Blow out any fuzz.
  4. Insert a new needle, making sure needle is pushed all the way up.
  5. Oil machine (in locations recommended in your owner's manual).
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Hope this helps narrow down your stitching problems.
Happy sewing,
Kim & Linnette
Posted on Jun 27, 2008
jpack76645
  • 23 Answers
SOURCE: needle will not pick up the bobbin thread, gets
Oh boy! I've worked on industrial sewing machines for over 30 years, but the home sewing machines are like comparing cadillacs to mopeds. No offense, but if you want performance out of a machine try an industrial. It will shock you with the difference. Be glad to help you find the right one.
Anyway, the problem you are having is quite common. First, make sure it is threaded right especially the moving spring on the needle thread tension) and the needle is new. This generally covers 75% of the problem. Make sure the bobbin thread is threaded correctly.
If you are still having the problem remove the bobbin/bobbin case and observe the needle/hook point relationship as you turn the handwheel. The hook point should pass behind the needle at the scarf of the needle (indention just above eye of needle) If it is not so the needle bar may have moved up on you. Did the machine get jammed?
I'm not sure about the rod you're talking about but lets try this first.
Posted on May 18, 2009
SOURCE: Thread tangles under throat plate while embroidering
Take the cover off or at least enough to blow the gear drives out around the area of the thread cutter. We use a air pump that you use to blow up an air mattress with. You will also need tweezers to pick out the thread etc. that gets wrapped around the gear and in the teeth. What happens is the gear drive gets clogged and does not turn freely.
Mary
Posted on Jul 26, 2009
Zenqi
  • 208 Answers
SOURCE: needle not picking up bottom thread
Remove the needle plate and the bobbin case.
Ensure that the needle is inserted all the way up into the needle clamp.
Set the machine for straight stitch, center needle position.
Slowly turn the handwheel in the normal sewing direction and observe the following hook timing setting:
When the needle reaches it's lowest point and travels up 3.5mm, the point of the hook should be directly behind the needle, or at least within 1 or 2mm.
Another view is as the hook passes the needle, it should pass the needle slightly above the eye of the needle.
If the timing looks good, use some alcohol on a bit of cloth to clean the hook, careful around the tip of the hook as it is very sharp.
If the hook timing is off, you will need to take it to a knowledgeable service person as there are several possible solutions and several other related adjustments which will need to be made.
Posted on Jan 16, 2010
Hello, I recently purchased a brother lx3817 sewing machine and it works but doesn’t stitch, what could be the problem
hi Desiree.
this is all i could find out.
There could be several things that could cause the machine not to pick up the bobbin thread.
  • The upper thread could be tangled.
    Remove the thread completely from the machine.
    The correct size spool cap should be used for the size of the thread spool.
    Re-thread the machine according to the directions in the manual.
One Point Advice Place a spool of thread on a spool pin.
One Point Advice Upper threading
  • Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race.
    Remove any loose threads or lint in the shuttle race.
One Point Advice Installing a bobbin into a bobbin case
  • You could be holding the needle thread too tight.
    Hold the thread lightly to keep the end from going down into the shuttle.
  • The needle could be thread incorrectly.
    Thread the needle eye from the front to the back.
  • The needle could be bent or improperly inserted.
    Install a new needle with the flat side of the needle facing the back.
or this link might help you out some more.
Why won the machine pick up the bobbin thread Brother
or this one.
brother lx3817 sewing machine doesnt stitch Google Search
Dec 06, 2017 | Brother Sewing Machines
Starting to sew basic stitch
You need to know how to thread the upper thread, wind thread onto a bobbin, and install the bobbin in the machine.
Be sure to lower the presser foot onto the fabric you are going to stitch.
Then press on the foot control pedal (like a gas pedal in a car). The harder you press, the faster it will stitch.
There are a lot of web sites and videos available. But, you should probably read the machine's manual.
How to Use your Sewing Machine for Beginners
How to Use Sewing Machine
How to Sew using sewing machine
Sewing 101 Guide for beginners like me The Dreamer
The Best Sewing Machines For Beginners She Likes to Sew
How to Use Sewing Machine Beginner Guide
Best Sewing Machines For Beginners Our TOP PICKS Sewing Made Simple
Oct 06, 2016 | Brother SE400 Computerized Sewing and...
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
Mar 19, 2014 | Brother Se400 Computerized Embroidery &...
I have an husqvarna #1+, While doing normal sewing It stitches perfectly.however when I try to use the embroidry the machine refuses to pick up the bobbin thread.I've changed bobbins, bobbin...
Are you using a different bobbin when you try embroidry? The machine forms the stitches the same exact way when you either sew or embroider. It's just that the hoop moves the fabric. Maybe your bobbin thread in not flowing out of your bobbin case freely. Maybe the type of stabilizer your using is the problem. Maybe your not hooping your fabric tight enough.
Apr 28, 2011 | Husqvarna Sewing Machines
I have a brother SE-400 and it sounds like the bobbin case is grinding.
I have a Brothers SE400..while free motion quilting, it sounds like the bobbin case is bouncing around. A lot of clanking noises. Does anyone know what I need to do to adjust this problem? It also seems like my stitches are very small and tight. I do see the top thread overlapping with my bobbin thread on the backing...what do I need to do to adjust this problem
Feb 10, 2011 | Brother XR7700
Top thread will not pick up bobbin thread makes a big loopy mess
This is sometimes caused by the upper thread not threaded correctly. You need to thread it first with the pressure foot in the up position. You need to "floss" the thread into the clear plastic guide as this is where the tension is. The tension should be set to E for embroidering. Also make sure you get the bobbin thread in the slot on the bobbin case. Also, lower your pressure foot before you begin embroidering. Hope this helps!
Sep 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Could the little hook that is stuck over the bobbin area be the thread cutter? My thread cutter gets stuck there and I have to turn my machine off and then try to use the cutter to reset it to its "resting" position.
Nov 23, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
183 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
