Question about Speed Clausing 15" Variable Floor Model Drill Press
Need help removing a chuck from a drill press model 15-000 i think it has thread
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: I have a model 1689 drill press with a 33 taper
you dont hold it, the chuck is a taper fit and you would need wedges to remove it. the newer chuck would also have to have the same taper to work. if replacing the new chuck you would need to make sure the parts are clean, use a brake cleaner and a paper towel to clean them and then they would press together. Let me know if you still need more assistance.
Posted on Jan 14, 2010
How do I remove the chuck from my drill press
Need to know what make and model drill press you have. You could have a taper or a threaded chuck setup. If threaded it would turn opposite drilling rotation and the may be a screw inside the chuck that needs to be loosened/removed and if it is a taper you need a removal tool to pop it out with.
Sep 21, 2014 | Drills
How do you remove the drill chuck on a vintage delta 14 inch drill press model dp-220
Thread Changing chuck on older Delta drill press This site speaks on the subject of changing chucks. It may be helpful. Also if you search;' how to remove a jacobs chuck from a delta drill press' , you should get several hits I hope this info is helpful....
Oct 17, 2013 | Delta Woodworking Drills
I have a Magnetic Drill Press DW 151, and I am trying to replace the chuck. I can not figure out how to remove the chuck. Any help would be nice thank you.
WARNING !! SOLUTION # 1 BY dleemacc_0.jpgDarryel Hubbard
IS WRONG . FOR THE DEWALT
Magnetic Drill Press DW 151I ALMOST DESTROYED A $500.-!,000 DRILL READING HIS ADVICE
THE ABOVE DRILL HAS A 1/2" X 20 THREAD THAT THE CHUCK
THREADS ONTO. LEFT TO REMOVE AND RIGHT HAND TO REPLACE YOUR NEW CHUCK . YOU CAN TAKE A PIPE WRENCH AND AFTER PLACING THE DRILL ON THE SIDE PUT THE PIPE WRENCH AT/ON THE END OF THE OLD CHUCK AT ABOUT 2 o'clock. Once set up slap
the pipe wrench very hard/fast with a suitable hammer . It took about three times to knock the chuck loose and then I removed it with my hands. A little crude but it worked. Have a good one.
Dave Shelby
Jul 15, 2011 | Dewalt DW151 magnetic drill presses
How to change the chuck on 18 volt cordless drills
Set the drill to reverse. Hold the chuck, press the trigger and open the drills chuck to it wide open position. Now,, take the correct size allen wrench and insert it into the back of the chuck to remove the screw. Turn the screw clockwise to remove it. Notice I said clockwise, just the opposite of what you might think. Hold the chuck with your hand or a pair of large vise grips and press the trigger to unscrew the chuck from the drill. Rotate it counterclockwise to remove it from the drill. Reverse the procedure to install the new chuck.
Mar 10, 2011 | Dewalt 18 Volt Compact Drill Kit
How do i remove the chuck from a Makita 8391D
I think you will find that if you open the chuck fully you will see a cross head screw inside the chuck which you need to undo before removing the chuck. this secure the chuck from unscrewing while being used in reverse to undo screws. Once this screw is out a spanner is used at the base of the chuck to unscrew it from the shaft. this may need a short sharpe shock to get it to move.
Jul 31, 2010 | Makita Drills
Slipping clutch on low switch with Milwaukee 2601-20 drill/driver. Can't separate clutch housing assy from drill. Is it pressed on? Same for chuck. I've removed the screw in chuck, still won't separate.
this tool has a 5 year limited warranty so I would try and have repaired under warranty. I looked at a breakdown and it doesn't specify how the chuck is on but I would to think it is threaded. the clutch is an assembly and there are no replacements parts other than the assembly available. Let me know if you need more assistance.
Jan 28, 2010 | Milwaukee Tool Drills
I have a model 1689 drill press with a 33 taper jacobs chuck I need to remove the chuck to put a larger chuck on is the smaller chuck threaded on and if it is, is it RH or LH thread and how do you hold the...
Jan 13, 2010 | Speed Clausing 15" Variable Floor Model...
How i remove a dewalt drill chuck Model dc988
put the drill in speed setting 1 before you continue~!
Step 1. This step loosens the screw inside the chuck. Open the chuck all the way — if you see a screw inside, it’ll need to come out before you can remove the chuck. If there’s no screw inside, you can skip steps one and two.
Step 2. If there’s a screw inside the chuck, typically the threading will be left-handed, so turn it clockwise to remove it. Be careful, and use the right size screwdriver — you don’t want to strip the screw.
step-2.gif Step 3. Insert the largest hex key that you have into the chuck, short-side-in, and tighten the chuck. Tap the hex key sharply in a counterclockwise direction to loosen the chuck. Now you can remove it by hand.
step-3.gif This won’t work for every consumer drill ever made, but pretty close. Most drills will match one of two common chuck-threading standards: 3/8′-24 threaded mount for 3/8′-capacity drill chucks, and 1/2′-20 threaded mount for 1/2′-capacity drill chucks — but on some drills just the opposite may occur. To be safe, always check the thread count before you buy a replacement drill chuck.
Oct 07, 2009 | Dewalt DC988VA XRP 3 - speed 1/2" 18v...
Remove and replace the chuck
Most drill press chucks are held on with a screw. Open the chuck all the way. Look inside the chuck, there should be a screw in the bottom. Some are left hand threads, some are not. Good Luck
May 28, 2009 | Drills
Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
Feb 08, 2009 | Craftsman 4" Drill Press Vise, Side -...
Speed Clausing 15" Variable  Floor Model Drill Press Logo
27 people viewed this question
Top Speed Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Speed Drill Expert? Answer questions, earn points and help others
