Acer am3100 u3201a
Receiving a "No signal" message on monitor when booting PC.
20YrsCompExp
  • 227 Answers
SOURCE: Acer Aspire AM3100-U3202A ''hard drive'' will not boot up
That could be a hardware failure of some sort, or because you added a new hardware device. The "DMI pool" code has nothing to do with Windows, but is part of Plug and Play. Windows has not even loaded yet. It is the System Board BIOS startup code checking the hardware configuration, and setting system board resources for Plug and Play to use. Go in to the system board BIOS (normally DEL key when first powering on) Look in the PnP or PCI Configuration section, for an entry "Reset Configuration Data. It will show Disabled. Change it to Enabled, and save the new configuration and reboot. BIOS will set it back to Disable after it clears the DMI data and rebuilds it. The first time through, it will take a long time, but after that it should not hang. Unless there is a hardware problem with one of the adapters on the system board or PCI bus.
I have seen CD-Rom drives cause this hang, if there is a CD in the drive. So make sure there are no CD's in the drives when you start up.
Posted on Apr 01, 2009
ericvb2005
  • 194 Answers
SOURCE: No signal to monitor
if u have a two VGA output in ur PC..try to use the build in VGA port...if doesn't appear... Try the one VGA port
Posted on Oct 18, 2009
greg_margo
  • 1959 Answers
SOURCE: Acer Monitor V193W has no signal
There are 2 basic reasons for the "No Signal" message.
  1. Loose video card inside the machine- if you're machine didn't come with on board video or if you are using an independent video card instead of on board video, the card can unseat at times, either due to movement of the machine or pulling on the video cord
  2. Loose connection between the video cord and/or monitor and/or machine. Unless the plugs on both ends are secure (including tightening both screws to prevent loss of connection), the cord can dislodge just enough to interrupt your connection, causing a "No Signal".
If neither of these is the case, try hooking up a different monitor (if equipped, you can use an HDMI cable to your TV) to see if the "No Signal" message persists.If using a different monitor works, the issue is your Acer Monitor.
Posted on Dec 08, 2011
  • 81 Answers
SOURCE: Acer M1640 Desktop Acer monitor come up no signal . Have put other monitor it comes up the same
Reset the cmos usualy a jumper, or remove the batery for 10 min, it might be a videocard problem, try another videocard. It might be a memoryproblem.
If you hear bleeds google for biosbeebs and that will show you wich bleeb is what error.
If all else fails change processor and powersuply or finaly the motherboard.
Posted on May 02, 2012
SOURCE: Monitor no signal acer M1640
Check the cable at the back of the monitor and at the back of the computer. If the cables are in tight and you still get the no signal error message you either have a bad monitor or a bad video card in the computer.
Try plugging another monitor into the computer (borrow one from a friend, neighbor or family member if you don't have one). If the monitor does the same thing and shows a no signal message like your original monitor, then the Video Card in the computer is bad. If the monitors works, then your original monitor is bad.
Posted on May 03, 2012
Acer am3100 u3201a
what device it is? it is new? have you replace it?
Aug 25, 2013 | Computers & Internet
May 02, 2012 | Computers & Internet
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
Acer x136w monitor, no signal. Connected parralel conector to back of computer. no signal..tried everything I know to do. Even stupidly pirchased driver whiz. nothing. ready to through monitor into th e...
No signal message on your LCD monitor screen means that your monitor is not receiving any signal from your PC graphic card. This problem "no signal" have nothing to do with the drivers installations. Have you check whether your graphic card is faulty or your cable connection properly connected/secured? ie VGA (D-sub). As far as I know there are no parallel connectors for PC Monitor connectors only, VGA(D-sub), DVI or HDMI cable interface.
Try to connect your monitor to another PC, just to test whether the LCD monitor is functional.
Hope it helps.
Mar 19, 2011 | Computers & Internet
If you monitor is showing the message no signal this means that the monitor is not receiving a signal from your computer and/or receiving a signal that it does not understand. So the first thing I would do...
hi ,
check the pins in the monitor plug as they can be bent , and also check your mointor is set to accept an input from your lead ( serial/hdmi etc )
Some monitors have a built diagnostic which is often colour bars , if your monitor shows this then its almost certainley a lead problem
hope this helps
Jan 16, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
Acer al1716 monitor flicks green and orange and screen remains black
I would say that is not receiving a signal from your computer.
Can you swap out monitors to see if another one works?
Most probably, if you see no error messages at all, you have a bad video card (assuming the computer is actually starting up).
Oct 21, 2009 | Acer AL1716 F Monitor
Bought a new computer. Getting no signal from my multisync 1700V
check the device manager and see what it says for the monitor...I know you can press CNTRL+ F5 for monitor selection , try this if everything is good in device mngr
Apr 13, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Why do I get a "No Signal" on my Acer x193w monitor?
sounds like a video card issue.  Check the screen on another computer.  If it is doing the same thing, it is the monitor.  If it doesn't, then you have a video card issue
Feb 24, 2009 | Acer X193W LCD Monitor
Acer Monitor boots up w/computer then "no signal"
you must have disconnected it while the pc was running.damage can occur while doing this as can a keyboard (they are not like USB devices that can be plugged and unplugged while "hot".)
Jul 20, 2008 | Acer AL1916W 19" LCD Monitor
Acer Monitor Doesn't Receive Signal From Computer
can you test your monitor on another computer to verify the monitor is at fault? If the monitor is at fault its time for a new one, factory warranties on monitors are usually 1 year unless you purchased an extended warranty.Otherwise repair is usually more costly than buying a new one.
Dec 25, 2007 | Acer 17" AL1706B LCD Monitor
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
