Question about Plumb Pak Actuating Lift Chain Fits American Standard PP830-46L
How to install chain - Plumb Pak Actuating Lift Chain Fits American Standard PP830-46L
Timing jeep cherockee
double posted but this time the CAM pops up.
why not read the FSM first. ? linked below.
or alldata.com . log in and read.
here ill do a paste from JUST install PART chapter.
you are doing ALL THAT book free, REALLY?
https://www.techauthority.com/en-US/Pages/Home.aspx
  1. Using a vise, lightly compress the secondary chain tensioner piston until the piston step is flush with the tensioner body. Using a pin or suitable tool, release ratchet pawl by pulling pawl back against spring force through access hole on side of tensioner.
  2. While continuing to hold pawl back, Push ratchet device to approximately 2 mm from the tensioner body. Install Special Tool 8514 lock pin into hole on front of tensioner. Slowly open vise to transfer piston spring force to lock pin.
  3. Position primary chain tensioner over oil pump and insert bolts into lower two holes on tensioner bracket. Tighten bolts to 250 inch lbs. (28 Nm).
  4. Install right side chain tensioner arm. Install Torx®bolt. Tighten Torx®bolt to 250 inch lbs. (28 Nm). CAUTION The silver bolts retain the guides to the cylinder heads and the black bolts retain the guides to the engine block.
  5. Install the left side chain guide. Tighten the bolts to 250 inch lbs. (28 Nm).
  6. Install left side chain tensioner arm, and Torx®bolt. Tighten Torx®bolt to 250 inch lbs. (28 Nm).
  7. Install the right side chain guide. Tighten the bolts to 250 inch lbs. (28 Nm).
  8. Install both secondary chains onto the idler sprocket. Align two plated links on the secondary chains to be visible through the two lower openings on the idler sprocket (4 o'clock and 8 o'clock). Once the secondary timing chains are installed, position special tool 8429 to hold chains in place for installation.
  9. Align primary chain double plated links with the timing mark at 12 o'clock on the idler sprocket.
  10. Align the primary chain single plated link with the timing mark at 6 o'clock on the crankshaft sprocket.
  11. Lubricate idler shaft and bushings with clean engine oil. NOTE The idler sprocket must be timed to the counterbalance shaft drive gear before the idler sprocket is fully seated.
  12. Install all chains, crankshaft sprocket, and idler sprocket as an assembly . After guiding both secondary chains through the block and cylinder head openings, affix chains with a elastic strap or equivalent. This will maintain tension on chains to aid in installation. Align the timing mark on the idler sprocket gear to the timing mark on the counterbalance shaft drive gear, then seat idler sprocket fully . Before installing idler sprocket bolt, lubricate washer with oil, and tighten idler sprocket assembly retaining bolt to 25 ft. lbs. (34 Nm). NOTE It will be necessary to slightly rotate camshafts for sprocket installation.
  13. Align left camshaft sprocket "L" dot to plated link on chain.
  14. Align right camshaft sprocket "R" dot to plated link on chain. CAUTION Remove excess oil from the camshaft sprocket bolt. Failure to do so can result in over torque of bolt resulting in bolt failure.
  15. Remove Special Tool 8429, then attach both sprockets to camshafts. Remove excess oil from bolts, then Install sprocket bolts, but do not tighten at this time.
  16. Verify that all plated links are aligned with the marks on all sprockets and the "V6" marks on camshaft sprockets are at the 12 o'clock position. CAUTION Ensure the plate between the left secondary chain tensioner and block is correctly installed.
  17. Install both secondary chain tensioners. Tighten bolts to 250 inch lbs. (28 Nm). NOTE Left and right secondary chain tensioners are not common.
  18. Remove all locking pins from tensioners. CAUTION After pulling locking pins out of each tensioner, DO NOT manually extend the tensioner(s) ratchet. Doing so will over tension the chains, resulting in noise and/or high timing chain loads.
  19. Using Special Tool 6958, Spanner with Adaptor Pins 8346, tighten left and right . camshaft sprocket bolts to 90 ft. lbs. (122 Nm).
  20. Rotate engine two full revolutions. Verify timing marks are at the follow locations: ² primary chain idler sprocket dot is at 12 o'clock ² primary chain crankshaft sprocket dot is at 6 o'clock ² secondary chain camshaft sprockets "V6" marks are at 12 o'clock ² counter balancer shaft drive gear dot is aligned to the idler sprocket gear dot.
  21. Lubricate all three chains with engine oil.
  22. After installing all chains, it is recommended that the idler gear end play be checked. The end play must be within mm 0.004-0.010 inches (0.10-0.25). If not within specification, the idler gear must be replaced.
  23. Install timing chain cover and crankshaft damper.
  24. Install cylinder head covers. NOTE Before installing threaded plug in right cylinder head, the plug must be coated with sealant to prevent leaks.
  25. Coat the large threaded access plug with Mopar® Thread Sealant with Teflon, then install into the right cylinder head and tighten to 60 ft. lbs. (81 Nm).
  26. Install the oil fill housing.
  27. Install access plug in left cylinder head.
  28. Install power steering pump.
  29. Fill cooling system.
  30. Connect negative cable to battery.
Dec 07, 2014 | Jeep Cars & Trucks
How do I set timing on a 2.3 Suzuki aerio engine
wow no job stated.
04 (2.3L) ill take a wild guess and say, you might be fiddling the cam
and doing something there, new cam, new lifters, new chain, new head, ? what?
FSM means factory service manual, ever heard of one?
the FSM is just lousy 4 bucks why not read that first. and not mess it up.
https://suzukipitstopplus.com/Products/1004-2004-aerio-service-manual.aspx
you said SET, so i can only assume its all apart. right then
you want to Instal the chain and time it, right so here are the fsm steps
no photos. log in and read the FSM for that.
  1. Check that match mark on crankshaft timing sprocket is in match with timing mark on lower crankcase.
  2. Install crankshaft timing sprocket as shown in figure.
  3. Apply oil to bush of idler sprocket and install idler sprocket and sprocket shaft.
  4. Install first timing chain by aligning dark blue plate of first timing chain and match mark on idler sprocket.
  5. Bring yellow plate of first timing chain into match with match mark on crankshaft timing sprocket.
  6. Apply engine oil to sliding surface of timing chain tensioner and then install it as shown in figure. Tighten tensioner nut to 18 ft. lbs. (25 Nm).
  7. With latch of tensioner adjuster No.1 returned and plunger pushed back into body, insert stopper into latch and body. After inserting it, check to make sure that plunger will not come out.
  8. Install timing chain tensioner adjuster No.1. Tighten the timing chain tensioner adjuster No. 1 bolt to 8 ft. lbs. (11 Nm).
  9. Pull out stopper from adjuster No.1.
  10. Apply engine oil to sliding surface of timing chain guide No.1 and then install it. Tighten guide bolts to 6.5 ft. lbs. (9 Nm).
  11. Check that dark blue and yellow plates of first timing chain are in match with match marks on sprockets respectively.
  12. Install second timing chain as follows:
    • Check that match mark on crank timing sprocket is in match with timing mark on lower crankcase.
    • Check that arrow mark on idler sprocket faces upward.
    • Check that knock pins of intake and exhaust camshafts are aligned with timing marks on cylinder head.
    • Install second timing chain by aligning yellow plate of second timing chain and match marks on idler sprocket.
    • Install sprockets to intake and exhaust camshafts by aligning dark blue plate of second timing chain, match marks on intake sprocket and exhaust sprocket respectively. NOTE As an arrow mark is provided on both sides, camshaft timing sprocket has no specific installation direction.
  • Install intake and exhaust camshaft timing sprocket bolts. To install it, fit a spanner to hexagonal part at the center of camshaft to hold it stationary. Tighten the camshaft timing sprocket bolt to 57.5 ft. lbs. (80 Nm).
  • Push back plunger into tensioner body and hold it at the position by inserting stopper into body.
  • Install timing chain tensioner adjuster No.2 with new gasket. Tighten the timing chain tensioner adjuster No. 2 bolts to 8 ft. lbs. (11 Nm) and No. 2 nut to 33 ft. lbs. (45 Nm).
  • Pull out stopper from timing chain tensioner adjuster No.2.
  • Turn crankshaft two rotations clockwise then align timing mark on crankshaft and timing mark on cylinder block.
  • Check that timing marks of cylinder head and cylinder block are in match with match marks on sprockets respectively.
  • Apply oil to timing chains, tensioner, tensioner adjusters, sprockets, and guides.
  • Install timing chain cover. Reverse removal sequence to install timing chain cover noting the following points:
    • Apply sealant "A" and "B" to area as shown.
      • "A": Sealant 99000-31250
      • "B": Sealant 99000-31140
    • Apply sealant amount to the following areas.
      • "a": 0.12 inches (3mm)
      • "b": 0.08 inches (2mm)
      • "c": 0.24 inches (6mm)
      • "d": 0.63 inches (16mm)
      • "e": 0.55 inches (14mm)
      • "f": 2.56 inches (65mm)
      • "g": 2.87 inches (73mm)
      • "h": 0.16 inches (4mm)
    • Apply engine oil to oil seal lip, then install timing chain cover. Tighten bolts and nut to 8 ft. lbs. (11 Nm).
      NOTE Before installing timing chain cover, check that pin is securely fitted.
    • Before installing timing chain cover, check that pin is securely fitted.
  • Install alternator belt idler pulley. Tighten nut to 30.5 ft. lbs. (42 Nm).
  • Install alternator belt tensioner. Tighten bolts to 18.5 ft. lbs. (25 Nm).
  • Install water pump pulley.
  • Install A/C compressor bracket (if equipped). Tighten bracket bolts to 40 ft. lbs. (55 Nm).
  • Install cylinder head cover with new gaskets and seal washers and tighten nuts to 8 ft. lbs. (11 Nm).
  • Install oil pan.
  • Install crankshaft pulley using pulley holder tool. Tighten the crankshaft pulley bolt to 108.5 ft. lbs. (150 Nm).
  • Install engine assembly.
  • Install all remaining components in the reverse order of the removal procedure.
did that cover it, surely not.
but if you get the FSM and read it or log in , you will not miss the photos and the complex sealing bs on this motor.
Oct 18, 2014 | 2004 Suzuki Aerio
Snow chains
  1. Tire chains should be installed on the drive wheels of the vehicle following the chain manufacturer's instructions, To retain as much of the normal handling characteristics of 4WD/AWD vehicles as possible, tire chains should be installed on all four tires, requiring the purchase of two pairs of tire chains.
  2. Buy chains that are the correct size for the tires. A proper fit is key to receiving the desired performance and durability. Do not deflate tires to install tire chains. A correctly sized tire chain will fit over a properly inflated tire. Additionally, because there is typically no source of compressed air to refill a deflated tire, driving with low tire pressure may cause permanent damage to the tire. Snow chains may not be available for all tire sizes.
  3. Use only SAE Class "S" chains. The restricted wheel well clearance in most of today's down-sized and front drive vehicles require tire chains to operate in an envelope that is no greater than 1.46-inches vertically and .59-inches laterally around the tire. These minimum clearances must be maintained between the tires and the vehicle's fenders, suspension, struts, brake lines and braces.
  4. It is important to pre-fit chains prior to actual use. Being faced with the choice of either damaging their vehicle or not completing a journey if the tire chains didn't fit is not a choice many drivers would want to have to make. Pre-fitting the chains will also allow the driver to become familiar with their installation. Since tire chains will only be required when the weather is at its worst, who would want to learn how to install them during a blizzard?
    You may want to buy a tire chain installation helper. These small ramps are designed to prevent slipping and allow you to lay a cross chain in a pre-formed indentation. Once you drive onto the ramp, the chains are positioned under your tire for easier installation following the manufacturer's directions.
  5. Tire chains should always be carried in the trunk during the appropriate times of the year and only mounted on the vehicle when warranted by driving conditions or required by law.
Dec 11, 2013 | 1992 Chevrolet S-10
Need timing gear marks for 2004 Kia Sadona 3.5L engine
Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Record the radio anti theft code data.
  3. Remove or disconnect the following:
    Negative battery cable Engine cover Accessory drive belts Idler pulley Crankshaft pulley Power steering pump pulley Belt tensioner pulley Upper and lower timing belt covers
  4. Support the engine with a floor jack and remove the engine mount.
  5. Rotate the engine to align the camshaft sprocket timing marks with the cylinder head cover timing marks.
    Fig. Timing belt routing and timing marks-3.5L Engine
  6. Remove or disconnect the following:
    Auto tensioner Timing belt
    Fig. Timing belt and related components-3.5L Engine
To install:
  1. Ensure that the engine is set to Top Dead Center (TDC).
  2. Prepare the auto tensioner for installation by compressing it in a vise and installing a retaining pin.
  3. Install the timing belt in the following order:
    1. Crankshaft sprocket
    2. Idler pulley
    3. Left bank exhaust camshaft sprocket
    4. Left bank intake camshaft sprocket
    5. Water pump pulley
    6. Right bank intake camshaft sprocket
    7. Right bank exhaust camshaft sprocket
    8. Tensioner pulley
  4. Install the auto tensioner. Do not remove the retaining pin at this time.
  5. Check that the crankshaft and camshaft timing marks are aligned correctly.
  6. Rotate the crankshaft 1 / 4 turn Counterclockwise .
  7. Rotate the crankshaft 1 / 4 turn Clockwise to return the engine to TDC.
  8. Loosen the tensioner pulley center bolt.
  9. Apply 44 inch lbs. (5 Nm) torque to the tensioner pulley as shown and tighten the center bolt to 32-41 ft. lbs. (43-55 Nm).
    Fig. Adjusting the tensioner pulley-3.5L Engine
  10. Remove the auto tensioner retaining pin.
  11. Rotate the crankshaft 2 revolutions Clockwise , then wait 5 minutes for the auto tensioner to adjust.
  12. Measure the auto tensioner rod as shown. If the measurement is not 3.8-4.5 mm, then repeat the belt tensioning procedure.
    Fig. Measuring the auto tensioner rod-3.5L Engine
  13. When the auto tensioner measurement is correct, install or connect the following:
    Engine mount Upper and lower timing belt covers Belt tensioner pulley Power steering pump pulley Crankshaft pulley Idler pulley Accessory drive belts Engine cover Negative battery cable
  14. Reprogram the radio anti theft codes.
    Kia_Sedona_2002-2006
    Timing Chain, Sprockets, Front Cover & Seal
    Print
    3.8L Engine
    3. Remove the engine from the vehicle.
    4. Remove the drive belt. Remove the power steering pump. Remove the air conditioning compressor.
    5. Remove the alternator. Remove the drive belt idler. Remove the drive belt tensioner. Remove the water pump pulley. Remove the intake manifold.
    6. Remove the connector bracket from the left cylinder head cover. Disconnect the right ignition coil connector, condenser connector and remove the bracket.
    7. Remove the left cylinder head cover retaining bolts. Remove the cylinder head cover from the engine.
    8. Remove the right cylinder head cover retaining bolts. Remove the cylinder head cover from the engine.
    9. Set the No. 1 cylinder to TDC on the compression stroke. Turn the crankshaft pulley and align its groove with the timing mark T of the lower timing chain cover.
    10. Check that the mark of the camshaft timing sprockets are in straight line positioning on the cylinder head surface. If not rotate the crankshaft 360 degrees. Do not rotate the engine counterclockwise.
    11. Remove the oil pan. Remove the crankshaft damper pulley. Remove the timing chain cover.
      NOTE Be careful not to damage the contact surfaces of the cylinder block, cylinder head and timing chain cover. Before removing the timing chain, mark the right and left timing chains with an identification mark based on the location of the sprocket because the identification mark on the chain for TDC can be erased.
    12. After compressing the timing chain tensioner, install a set pin. Remove the right cam to cam guide. Remove the right timing chain auto tensioner and timing chain tensioner arm.
    13. Remove the oil pump chain cover. Remove the oil pump chain tensioner assembly. Remove the oil pump chain guide. Remove the right timing chain.
    14. Remove the right timing chain guide. Remove the oil pump chain sprocket and oil pump chain. Remove the crankshaft sprocket, oil pump and camshaft drive gear.
    15. Remove the left cam to cam guide. Remove the left timing chain auto tensioner and timing chain tensioner arm. Remove the left timing chain.
    16. Remove the left timing chain guide. Remove the crankshaft sprocket and left camshaft drive. Remove the tensioner adapter assembly.
      Fig. Timing chain and related components-3.8L Engine
    To install:
    1. Check the camshaft and crankshaft sprockets for wear and damage, replace as required.
    2. Inspect the tensioner arm and chain guide for wear and damage, replace as required.
    3. Check that the tensioner pin moves smoothly when the ratchet pawl is released with a thin rod.
    4. The key of the crankshaft should be aligned with the timing mark of the timing chain cover. This indicates that the piston is at TDC on the compression stroke.
    5. Install the tensioner adapter assembly. Install the crankshaft sprocket and left camshaft drive.
    6. Install the left timing chain guide and torque the retaining bolts 14-18 ft. lbs.
    7. Install the left timing chain. Be sure to install the chain with no slack between the camshaft and the crankshaft (crankshaft sprocket, timing chain guide, exhaust camshaft sprocket, intake camshaft sprocket). The timing mark of each sprocket should be matched with the timing mark (color ink) of the timing chain at installation of the timing chain.
      Fig. Left timing chain markings and installation: (D) exhaust camshaft sprocket (C) intake camshaft sprocket-3.8L Engine
    8. Install the left timing chain tensioner arm and torque the retaining bolts 14-16 ft. lbs.
    9. Install the left timing chain tensioner and torque the retaining bolts 7-9 ft. lbs.
    10. Install the left cam to cam guide and torque the retaining bolts 7-9 ft. lbs.
    11. Install the crankshaft sprocket, oil pump and right camshaft drive.
    12. Install the oil pump chain and oil pump sprocket. Torque the retaining bolt to 14-16 ft. lbs.
    13. Install the right timing chain guide. Torque the retaining bolts to 14-18 ft. lbs.
    14. Install the right timing chain. Be sure to install the chain with no slack between the camshaft and the crankshaft (crankshaft sprocket, intake camshaft sprocket, exhaust camshaft sprocket). The timing mark of each sprocket should be matched with the timing mark (color ink) of the timing chain at installation of the timing chain.
      Fig. Right timing chain markings and installation: (C) exhaust camshaft sprocket (B) intake camshaft sprocket-3.8L Engine
    15. Install the right timing chain tensioner arm. Torque the retaining bolts to 14-17 ft. lbs.
    16. Install the right timing chain auto tensioner. Torque the retaining bolts to 7-9 ft. lbs.
    17. Install the right cam to cam guide and torque the retaining bolts to 7-9 ft. lbs.
    18. Install the oil pump chain guide. Torque the retaining bolts to 7-9 ft. lbs.
    19. Install the oil pump tensioner assembly. Torque the retaining bolts to 7-9 ft. lbs.
    20. Pull out the pins on both the left and right hydraulic tensioners. Install the oil pump chain cover.
    21. Rotate the crankshaft two revolutions in the clockwise direction. Confirm the timing mark. Be sure to rotate the crankshaft in the clockwise direction.
    22. Apply sealant on the chain cover and on the cylinder head, cylinder block, and lower oil pan. Be sure these parts are free of engine oil and dirt.
      NOTE Before assembling the timing chain cover, the liquid sealant TB1217H should be applied on the gap between the cylinder head and block. The part must be assembled with five minutes after the sealant is applied.
      Fig. Sealant application (1 inch bead width)-3.8L Engine
    23. Apply sealant on the chain cover.
      NOTE The liquid sealant TB1217H should be applied on the gap between the cylinder head and block. The part must be assembled with five minutes after the sealant is applied.
      Fig. Timing cover sealant application-3.8L Engine
    24. Install a new gasket to the timing case cover.
      NOTE It is important that the dowel pins on the cylinder block and holes on the timing chain cover should be used as a reference in order to assemble the timing chain cover in the correct position.
      Fig. Timing cover gasket installation (A) gaskets-3.8L Engine
    25. Install the timing chain cover. Torque the retaining bolts in the proper sequence and to specification. The engine should not be started for at least thirty minutes after timing chain cover assembly.
      Fig. Timing cover bolt torque sequence and specification-3.8L Engine
    26. Install the timing case cover oil seal.
    27. Continue the installation in the reverse order of the removal procedure.
May 19, 2012 | 2004 Kia Sedona
Timing chain replacement
Timing Chain and Gears REMOVAL & INSTALLATION 1.9L Engine NOTE: The following procedure requires the use of the puller tool No. J-25031 or equivalent, and timing sprocket installation tool No. J-26587 or equivalent.
  1. Remove the timing (front) cover from the engine.
  2. Lock the shoe on the automatic adjuster in fully retracted position by depressing the adjuster lock lever. NOTE: To remove the timing chain, it may be necessary to remove the camshaft sprocket. Before removing the timing chain, be sure to align the timing marks.
  3. Remove timing chain from crankshaft sprocket.
  4. Check the timing sprockets for wear or damage. If crankshaft sprocket must be replaced, remove the sprocket and the pinion gear from crankshaft using the puller tool No. J-25031 or equivalent.
  5. Check timing chain for wear or damage; replace as necessary. Measure distance "L'' (40 links) with the chain stretched with a pull of approximately 22 lbs. (98N). Standard "L'' value is 15 in. (381mm); replace chain if "L'' is greater than 15.16 in. (385mm).
  6. Remove the automatic chain adjuster-to-engine bolt and the adjuster.
  7. To check the operation of the automatic chain adjuster, push the shoe inwards, if it becomes locked, the adjuster is working properly. The adjuster assembly must be replaced if rack teeth are found to be worn excessively.
  8. To remove the chain tensioner, remove the "E'' clip and the tensioner. Check the tensioner for wear or damage; if necessary, replace it. Fig. 1: Timing chain guide and tensioner - 1.9L engine 85383285.gif
  9. Inspect the tensioner pin for wear or damage. If replacement is necessary, remove the pin from the cylinder block using a pair of locking pliers. Lubricate the NEW pin tensioner with clean engine oil. Start the pin into block, then place the tensioner over the appropriate pin. Position the E-clip onto the pin, then (using a hammer) tap it into the block until clip just clears tensioner. Check the tensioner and adjuster for freedom of rotation on the pins.
  10. Inspect the guide for wear or damage and plugged lower oil jet. If replacement or cleaning is necessary, remove the guide bolts, the guide and the oil jet. Install a new guide and upper attaching bolt. Install the lower oil jet and bolt, so that the oil port is pointed toward crankshaft. To install: Fig. 2: Timing chain alignment and installation - 1.9L engine 85383286.gif
    Fig. 3: Inspecting the timing chain for wear 85383287.gif
  11. Install the timing sprocket and the pinion gear (groove-side toward the front cover). Align the key groove with crankshaft key, then drive it into position using installation tool No. J-26587 or equivalent.
  12. Turn the crankshaft so that key is turned toward the cylinder head-side (No. 1 and No. 4 pistons at TDC).
  13. Install the timing chain, align the timing chain mark plate with the mark on the crankshaft timing sprocket. The side of the chain with the mark plate is on the front-side and the side of chain with the most links between mark plates is on the chain guide-side. Keep the timing chain engaged with the camshaft timing sprocket until the camshaft timing sprocket is installed on the camshaft.
  14. Install the camshaft timing sprocket so that it's marked-side faces forward and it's triangular mark aligns with the chain mark plate.
  15. Install the automatic chain adjuster.
  16. Release the lock by depressing the shoe on adjuster by hand, and check to make certain the chain is properly tensioned when the lock is released.
  17. Install the timing cover assembly.
Dec 12, 2010 | 1993 GMC Sonoma Club
How do u set timing on it? 1.8 engine
Installation
Install crankshaft sprocket on crankshaft.
Make sure mating marks on crankshaft sprocket face front of engine.
Position crankshaft so that No. 1 piston is at TDC and crankshaft key is at 12 o'clock.
Install slack side timing chain guide and timing chain tension guide.
Install timing chain on crankshaft sprocket.
Set timing chain by aligning its mating mark with that on the crankshaft sprocket.
Make sure sprocket's mating mark faces engine front.
Install camshaft sprockets.
Set timing chain by aligning mating marks with those of camshaft sprockets.
Install camshaft sprocket bolts to correct torque.
Apply new engine oil to bolt threads and seat surface.
Install chain tensioner.
Before installing chain tensioner, insert a suitable pin into pin hole of chain tensioner.
After installing chain tensioner, remove the pin.
Install timing chain guide.
Install O-rings to cylinder block.
Before installing front cover, remove all traces of RTV silicone sealant from mating surface using a scraper.
Also remove traces of RTV silicone sealant from mating surface of cylinder block.
Apply a continuous bead of Genuine RTV Silicone Sealant or equivalent to mating surface of front cover. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Check alignment of mating marks on chain and crankshaft sprocket.
Align oil drive spacer with oil pump.
Place timing chain to the side of chain guide. This prevents the chain from making contact with water seal area of front cover.
Install front cover.
Make sure two O-rings are present.
Be careful not to damage oil seal when installing front cover.
Install cylinder head bolts at engine front side as shown in Fig. 55.
Tightening procedure:
Tighten bolts (1 - 4): 6.3-8.3 N.m (0.64-0.85 kg.m, 55.8-73.5 in.lb).
Install oil pump drive spacer.
Install water pump and water pump pulley. Refer to REMOVAL AND INSTALLATION .
Install idler pulley and bracket.
Install RH engine mounting bracket
Install RH engine mounting.
Install oil pan. Refer to INSTALLATION.
Install crankshaft pulley.
Remove ring gear stopper.
Install starter motor.
Install cylinder head front cover.
Apply RTV silicone sealant to cylinder head front cover.
Use Genuine RTV Silicone Sealant or equivalent. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Install Camshaft Position Sensor (PHASE).
Before installing rocker cover, apply a bead of Genuine RTV Silicone Sealant or equivalent, to mating surface of cylinder head as shown in .
Install rocker cover gasket into rocker cover.
Install rocker cover and tighten in numerical order as shown in
Install spark plugs.
Install ignition coils.
Install front exhaust tube.
Install front/right-side splash undercover.
Install front RH wheel.
Install drive belts.
Adjusting drive belt deflection..
Nov 29, 2010 | 2002 Nissan Sentra
I need to know how to set thte timing chain
Discoverd this indepth expalaination of process steps involved in the installation of the timing chain from an ASE certified technician. I hope this helps. See the repair manual on the link below.<br /> <br /> Link: <a href="http://www.2carpros.com/forum/2002-jaguar-xj8--gearbox-default-appear-on-dashboard/2000-jaguar-xj8-timing-chain-replacement-vt218070.html">http://www.2carpros.com/forum/2002-jaguar-xj8--gearbox-default-appear-on-dashboard/2000-jaguar-xj8-timing-chain-replacement-vt218070.html</a><br /> <table id="table14" style="BORDER-RIGHT: #000000 1px dashed; BORDER-TOP: #000000 1px dashed; BORDER-LEFT: #000000 1px dashed; BORDER-BOTTOM: #000000 1px dashed" bordercolordark="#000000" width="100%" bordercolorlight="#000000" border="0"> <tbody> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"><span class="name" roundtrip="0" lastvisited="3">By <a name="755408"></a><b roundtrip="0" lastvisited="0">Dave H</b>,<b> </b></span><span class="postdetails" roundtrip="0" lastvisited="0">Certified ASE Technician</span></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="100%" roundtrip="0" lastvisited="6"></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"></td></tr> <tr> <td style="BORDER-LEFT-WIDTH: 1px; BORDER-BOTTOM-WIDTH: 1px; BORDER-RIGHT-WIDTH: 1px"> </td> </tr> <tr> <td colspan="2"> <span class="postbody" roundtrip="0" lastvisited="77">PRIMARY TIMING CHAINS (NON-SUPERCHARGED) <br />NOTE:The 4.0L V8 has no engine timing alignment marks on the crankshaft or camshafts. Engine timing is achieved by installing the Crankshaft Setting Peg (303-531) and Camshaft Locking Tool (303-530). With the crankshaft setting peg in position, ensure the timing flat on each camshaft is in the uppermost position before installing camshaft locking tool. Variable camshaft timing unit may also be referred to as Variable Valve Timing (VVT) unit. <br /><br />NOTE:Special Tools Required: Crankshaft Setting Peg (303-531), Camshaft Locking Tool (303-530), Chain Tensioning Tool (303-532), Primary Chain Wedge (303-533) and Variable Camshaft Timing Oil Control Unit Setting Tool (303-654). See Fig. 232-Fig. 236 . <br /><br />NOTE:"A" bank refers to the right/passenger side of the vehicle and "B" bank refers to left/driver side of the vehicle. <br /><br />NOTE:Each door glass automatically drops 12 mm when the door is opened or when the convertible top is raised or lowered. It is important that windows are lowered before battery is disconnected to allow doors to shut properly. <br /><br />Removal ("A" Bank) <br />Tips Click a link to view tip <br />Tech1Tip: special tool <br /><br /><br />Remove timing cover. See TIMING CHAIN COVER (NON-SUPERCHARGED). <br />Remove the variable camshaft timing oil control solenoid. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Remove the variable camshaft timing oil control unit housing retaining bolts and remove the variable camshaft timing oil control unit housing. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Remove and discard the variable camshaft timing oil control unit housing "O" rings. <br />Raise and support vehicle. Remove the bolt which secures the Crankshaft Position (CKP) sensor to the flywheel housing. Remove the CKP sensor and allow it to hang free under the engine. Remove the torque converter bolts access grommet from the flywheel housing. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Install the crankshaft damper bolt (old one) to the crankshaft, hand-tight only. Rotate crankshaft until the triangular arrow indent on the flywheel is visible through the access hole. See Fig. 144. Confirm that the timing flat on each camshaft is uppermost position. <br />Position the crankshaft so that the Crankshaft Setting Peg (303-531) engages fully into the timing slot. Install and tighten the bolt to secure the crankshaft setting peg. See Fig. 145. Remove the crankshaft damper bolt from the crankshaft and lower the vehicle. <br />Install the Camshaft Locking Tool (303-530) to the "A" bank camshafts, aligning the shafts slightly as necessary. Loosen the bolt that secures the exhaust camshaft sprocket and the bolt that secures the variable camshaft timing oil control unit. See Fig. 146. Remove camshaft locking tool. <br />Remove the primary chain tensioner bolts, primary chain tensioner and tensioner backing plate. See Fig. 147. <br />Remove the primary timing chain tensioner pivot bolt and remove the primary timing chain tensioner blade. See Fig. 148. <br />Remove the bolt which secures the primary timing chain guide. Noting the position of the primary timing chain guide, remove the primary timing chain guide from the upper retaining pin. See Fig. 149. <br />Remove the primary timing chain from the variable camshaft timing oil control unit and from the crankshaft sprocket. Clean and inspect all components. <br />Installation <br />If "B" bank timing chain was removed, see INSTALLATION. If not, go to next step. <br />If previously removed, install the timing chain sprocket to the crankshaft. The teeth of the "A" bank and the "B" bank timing chain sprockets on the crankshaft must be out of phase with each other. If they are in phase after installing, remove the sprocket, turn it on its vertical axis and reinstall sprocket. See Fig. 150. <br />Install the chain tensioning tool to the exhaust camshaft sprocket. Reposition the sprocket (and the variable camshaft timing oil control unit) for the most advantageous position for use of the tool. See Fig. 151. Remove the tool. <br />Install the primary timing chain into position over the crankshaft sprocket and the variable camshaft timing oil control unit. There must be no slack on the drive side of the primary timing chain and the sprockets must not be rotated on the camshafts, or the tensioning tool may not fit. See Fig. 152. <br />Install the primary timing chain tensioner blade to the cylinder block. See Fig. 148. Install the pivot bolt and tighten specification. See TORQUE SPECIFICATIONS. <br />Push the primary timing chain tensioner piston into the tensioner body to provide clearance for installing the primary timing chain. Insert a thin rigid wire through the hole in the end of the tensioner piston to displace the ball from the non-return valve seat. See Fig. 153. With the wire in position, press the piston fully into the tensioner body. Remove the wire. <br />Install the 2 primary timing chain tensioner bolts to the primary timing chain tensioner and locate the tensioner backing-plate on to the 2 bolts. Align and install the primary timing chain tensioner to the cylinder block and to the mating slot on the rear face of the primary timing chain tensioner blade. See Fig. 147. Tighten the primary timing chain tensioner bolts to specification. See TORQUE SPECIFICATIONS. <br />Use a Primary Chain Wedge (303-533), or 2 if needed, between the primary timing chain tensioner and primary timing chain tensioner blade, to take up the slack in the chain for tightening of the variable camshaft timing control unit and exhaust camshaft sprocket. See Fig. 154. <br />Using the chain tensioning tool, apply force to the tool in an counterclockwise direction to tension the chain on its drive side. See Fig. 151. While applying opposing force to the sprocket and chain, tighten the exhaust camshaft sprocket bolt to specification. See TORQUE SPECIFICATIONS. <br />Using the Variable Camshaft Timing Oil Control Unit Setting Tool (303-654), rotate the variable camshaft timing oil control unit fully counterclockwise to the fully retarded position. See Fig. 155. <br />Check that the primary chain wedges are still in place. While applying opposing force to the sprocket and chain using the chain tensioning tool, tighten the variable camshaft timing oil control unit bolt to specification. See TORQUE SPECIFICATIONS. Remove the chain tensioning tool and the primary chain wedges and camshaft locking tool. <br />Raise and support vehicle. Remove crankshaft setting peg. Install the CKP sensor and bolt to the flywheel housing. See Fig. 143. Tighten the CKP sensor bolt to specification. See TORQUE SPECIFICATIONS. Install the access grommet to the housing and lower the vehicle. <br />WARNING:Check that the ring dowels are engaged squarely. Fully locate the assembly as much as possible by hand. Failure to follow this procedure may result in damage to the vehicle. <br /><br />Install NEW "O" rings to the variable camshaft timing oil control unit housing. Lubricate the "O" rings and the bushing. Install the variable camshaft timing oil control unit housing. See Fig. 142. Install the variable camshaft timing oil control unit housing bolts. Tighten to specification. See TORQUE SPECIFICATIONS. <br />Install the variable camshaft timing oil control solenoid. See Fig. 141. Install and tighten the variable camshaft timing oil control solenoid bolt to specification. See TORQUE SPECIFICATIONS. <br />Install the timing chain cover. See TIMING CHAIN COVER (NON-SUPERCHARGED). </span><br /></td></tr></tbody></table>
Aug 26, 2010 | 2001 Jaguar XJ8
What is the right way to time a 4cyl Chevy S-10 timing chain
1998-2003 To Remove:
  1. Remove or disconnect the following:
    • Crankshaft pulley and hub
    • Timing chain cover and gasket
  2. Install a bolt in the end of the crankshaft CAUTION
    Do not install the crankshaft balancer bolt or a bolt longer than 1 inch or damage to the crankshaft threaded hole will result.
  3. Rotate crankshaft until the number 1 piston is at Top Dead Center of compression stroke.
  4. Make sure that the alignment marks are aligned with the tabs on the timing chain tensioner. gm-03-22-611.gif
  5. Measure distance between hole in bracket and unworn surface of timing chain tensioner shoe. NOTE: If distance between the hole and unworn surface of timing chain tensioner is greater than 0.314 in (8 mm), replace tensioner, timing chain and sprockets.
  6. Remove timing chain tensioner bolts.
  7. Remove the timing chain, timing chain tensioner and camshaft sprocket at the same time.
  8. Remove the crankshaft sprocket using special tool J 22888-20A or equivalent.
  9. Remove crankshaft sprocket alignment key.
NOTE: If any camshaft components are being replaced to correct a noise problem, all camshaft drive components must be replaced.
To Install:
  1. Install the crankshaft sprocket alignment key.
  2. Install the crankshaft sprocket using special tool J 5590 or equivalent. gm-03-22-613.gif
  3. Compress the timing chain tensioner spring and insert a pin into the tensioner hole to retain the tensioner shoe.
  4. Install timing chain and timing chain tensioner (do not tighten tension bolts).
  5. Align the crankshaft and camshaft timing marks with the tab on the timing chain tensioner.
  6. Tighten the timing chain tensioner bolts.
    • Torque to: 18 ft lbs (24 Nm)
  7. Tighten the camshaft sprocket bolt.
    • Torque to: 96 ft lbs (130 Nm)
  8. Remove pin from timing chain tensioner hole.
  9. Remove bolt from end of crankshaft. CAUTION
    Inspect the timing chain cover for warping or damage. Replace if needed.
  10. Clean all timing chain cover mating surfaces.
  11. Install or connect the following:
    • Timing chain cover to the engine block
      1. Ensure that the gasket is installed properly in the groove in the timing chain cover
    • Timing chain cover and make sure it fully seated on the alignment dowel pins
    • Timing chain cover bolts
      1. Torque to: 97 inch lbs (11 Nm)
    • Drive belt tensioner
    • Crankshaft damper hub and the crankshaft pulley
Aug 17, 2010 | 2000 Chevrolet S-10
The chains keep falling off the tire. What have
let all the air out of the tires before installing chains. Then install chain as tight as possible then inflate tire this will get chains on tighter.
Dec 27, 2009 | John Deere 22 In. Rear Tire Chains
Timing on 4.7 help
INSTALLATION
  1. Using a vise, lightly compress the secondary chain tensioner piston until the piston step is flush with the tensioner body. Using a pin or suitable tool, release ratchet pawl by pulling pawl back against spring force through access hole on side of tensioner. While continuing to hold pawl back, Push ratchet device to approximately 2 mm from the tensioner body. Install Special Tool 8514 lock pin into hole on front of tensioner. Slowly open vise to transfer piston spring force to lock pin (Resetting Secondary Chain Tensioners).
  2. Position primary chain tensioner over oil pump and insert bolts into lower two holes on tensioner bracket. Tighten bolts to 28 N·m (250 in. lbs.). CAUTION: Overtightening the tensioner arm torx® bolt can cause severe damage to the cylinder head. Tighten torx® bolt to specified torque only.
  3. Install right side chain tensioner arm. Apply Mopar® Lock N, Seal to torx® bolt, tighten bolt to 17 N·m (150 in. lbs.). NOTE: The silver bolts retain the guides to the cylinder heads and the black bolts retain the guides to the engine block.
  4. Install the left side chain guide. Tighten the bolts to 28 N·m (250 in. lbs.). CAUTION: Overtightening the tensioner arm torx® bolt can cause severe damage to the cylinder head. Tighten torx® bolt to specified torque only.
  5. Install left side chain tensioner arm. Apply Mopar® Lock N, Seal to torx® bolt, tighten bolt to 17 N·m (150 in. lbs.).
  6. Install the right side chain guide. Tighten the bolts to 28 N·m (250 in. lbs.).
  7. Install both secondary chains onto the idler sprocket. Align two plated links on the secondary chains to be visible through the two lower openings on the idler sprocket (4 o'clock and 8 o'clock). Once the secondary timing chains are installed, position special tool 8515 to hold chains in place for installation (Installing Secondary Timing Chains on Idler Sprocket).
  8. Align primary chain double plated links with the timing mark at 12 o'clock on the idler sprocket. Align the primary chain single plated link with the timing mark at 6 o'clock on the crankshaft sprocket (Timing Chain System).
  9. Lubricate idler shaft and bushings with clean engine oil.
  10. Install all chains, crankshaft sprocket, and idler sprocket as an assembly (Installing Idler Gear, Primary and Secondary Timing Chains). After guiding both secondary chains through the block and cylinder head openings, affix chains with a elastic strap or the equivalent, This will maintain tension on chains to aid in installation. NOTE: It will be necessary to slightly rotate camshafts for sprocket installation.
  11. Align left camshaft sprocket “L” dot to plated link on chain.
  12. Align right camshaft sprocket “R” dot to plated link on chain. CAUTION: Remove excess oil from the camshaft sprocket bolt. Failure to do so can result in over-torque of bolt resulting in bolt failure.
  13. Remove Special Tool 8515, then attach both sprockets to camshafts. Remove excess oil from bolts, then Install sprocket bolts, but do not tighten at this time.
  14. Verify that all plated links are aligned with the marks on all sprockets and the “V8” marks on camshaft sprockets are at the 12 o'clock position (Timing Chain System). CAUTION: Ensure the plate between the left secondary chain tensioner and block is correctly installed.
  15. Install both secondary chain tensioners. Tighten bolts to 28 N·m (250 in. lbs.). NOTE: Left and right secondary chain tensioners are not common.
  16. Before installing idler sprocket bolt, lubricate washer with oil, and tighten idler sprocket assembly retaining bolt to 34 N·m (25 ft. lbs.).
  17. Remove all locking pins (3) from tensioners. CAUTION: After pulling locking pins out of each tensioner, DO NOT manually extend the tensioner(s) ratchet. Doing so will over tension the chains, resulting in noise and/or high timing chain loads.
  18. Using Special Tool 6958, Spanner with Adaptor Pins 8346, tighten left (Tightening Left Side Camshaft Sprocket Bolt) and right (Tightening Right Side Camshaft Sprocket Bolt). camshaft sprocket bolts to 122 N·m (90 ft. lbs.).
  19. Rotate engine two full revolutions. Verify timing marks are at the follow locations:
  20. Lubricate all three chains with engine oil.
  21. After installing all chains, it is recommended that the idler gear end play be checked (Measuring Idler Gear End Play). The end play must be within 0.10–0.25 mm (0.004–0.010 in.). If not within specification, the idler gear must be replaced.
  22. Install timing chain cover (Refer to 9 - ENGINE/VALVE TIMING/TIMING BELT / CHAIN COVER(S) - INSTALLATION) and crankshaft damper (Refer to 9 - ENGINE/ENGINE BLOCK/VIBRATION DAMPER - INSTALLATION).
  23. Install cylinder head covers (Refer to 9 - ENGINE/CYLINDER HEAD/CYLINDER HEAD COVER(S) - INSTALLATION). NOTE: Before installing threaded plug in right cylinder head, the plug must be coated with sealant to prevent leaks.
  24. Coat the large threaded access plug with Mopar® Thread Sealant with Teflon, then install into the right cylinder head and tighten to 81 N·m (60 ft. lbs.) (Cylinder Head Access Plug Location).
  25. Install the oil fill housing.
  26. Install access plug in left cylinder head (Cylinder Head Access Plug Location).
  27. Install power steering pump (Refer to 19 - STEERING/PUMP - INSTALLATION).
  28. Install radiator fan shroud.
  29. Fill cooling system (Refer to 7 - COOLING - STANDARD PROCEDURE).
Jul 08, 2009 | 2000 Dodge Durango
Plumb Pak Actuating Lift Chain Fits American Standard PP830-46L Logo
51 people viewed this question
Top Plumb Pak Home Experts
Donni Steen
Tom Chichester
Are you a Plumb Pak Home Expert? Answer questions, earn points and help others
