That's the idea of HDD passwords. You can't access the data on it at all. Either by boot cd or physically removing the hard drive and connecting it to another pc, you still won't be able to access the drive. Two options, replace the hard drive and reload a clean o/s. Or, there is a service available that might remove the password and retain the data. There are also services that will remove the password and wipe the data, as a security measure. But at the cost of either of these services, makes better sense to replace the drive and reload the o/s. You can goole HDD Unlock and find the software easily. You would need to connect the drive to another working pc. Download and run the software on that password protected drive. It will tell you if it is unlockable. To bad it's not a Dell, I may be able to provide you with a p/w to unlock it.
SOURCE: need to bypass primary master HDD user password
the only solution is for you to call the acer tech support and they can generate a password for you to gain access to your hard drive and bios.
visit: http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7117&areaid=2&website=AcerPanAm.com
call the acer tech support or go on line a to www.acer.com and they should be able to get you need best regards mike
SOURCE: asking for password sata port pass
This is a "security" feature, to protect the files on the disk-drive from unauthorized access.
The computer supports "full-disk" encryption of each disk-drive inside your computer.
So, what password did you set when you first initialized this disk-drive?
If you don't know it, there's nothing you can do -- all the files on the disk-drive are _NOT_ accessible to you.
SOURCE: have a acer aspire 5515 notebook laptop it keeps
It sounds like you may need to go into the BIOS and change or disable the password. Alternatively, clear the CMOS.
SOURCE: when I turn on my
you go in your bios to remove but your bios is probly locked pull the small main board battery out turn it on and off put battery back in its under one of the panel on the bottom..
