Question about Eyemax DVB 9060 16CH 60FPS DVR Board
The computer is re-booting, (turns on, off, and same again), it stays on for 5 min at a time. I changed the power supply; still, same problem. Any idea?
  • 2,113 Answers
It likely lost it's boot.ini because you left a software install cd/dvd in it once and it didn't finish restoring the boot.ini back to original. Use the windows disk (full) to repair (most people don't have a full windows disk... if that is the case try to reinstall windows from the hidden partition... if you don't have a recovery on your drive then reinstall windows from your dvd etc)
Posted on Oct 15, 2013
Tip
You press the power button on your computer and nothing happens
1. Find out if computer has power.
Are fans running, lights on? When there are no signs of power, 99.9% of the time its a faulty power supply. Before you replace power supply try this.Unplug the power cord to the PC, wait approx 10 mins and plug back in. Does the computer power on now? If so, it may have been a power surge that the PC experienced. You may want to invest in an Uninterruptible Power Supply unit.
2.Computer is turning off by itself.
This can be a electrical short to a serious hardware issue. Open the computer case and inspect the wiring. Make sure there is no chafing or exposed direct contact with metal. Look for loose connectors. Connectors can become unseated. Inspect and reseat all connections.
3.Computer beeps shortly after powering on.
The beeps are error codes and can be used to troubleshoot computer search google for number of beeps
4. PC powers on and display codes.
POST (Power On Self Test) codes, are usually specific to the manufacturer. It’s best to go to manufacturer support website the codes can point you in the right direction. If you get “No hard drive connected” error, reset the connectors on the hard drive and test again.
5. Computer turns on but the operating system wont load completely.
Boot up in safe mode by pressing F8 during boot up, select safe mode with networking and after everything loads, boot back up in normal mode. If you installed any recent drivers you can uninstall them and see if that helps if this is not helpful most of the time you will have to use a restore disk and put computer back to factory settings.
on Dec 07, 2009 | Computers & Internet
Monitor shuts off after approx 2 min when i start. i turn monitor switch off and turn on again and stays on approx 2 min and shuts off again
Go to control panel > Power options and check the power settings there. Are the settings for "Turn off monitor" set to 2 minutes? Increase the time and see if there is any changes.
If the above does not solve it, it's quite likely that your monitor's power supply is giving problems. Turn it in for warranty/repair.
Mar 07, 2011 | HP 2009M Monitor
TOSHIBA dlp projection, model 42hm66 won't stay on
Could be the power supply. You can check the power from supply with multi-tester or voltmeter. If have a service manual, then I suggest testing the ballast as well
Aug 07, 2009 | Toshiba 52HM95 52" HDTV Projection...
PC does not boots
Change the SMPS, preferably with 450 & above wattage. Also you must be using an UPS(uninterrupted power supply or battery back-up so there are no chances of voltage fluctuation. At the time of changing the SMPS also remove the RAM and clean the contact points with a piece of normal white paper..............sodeep
Jun 28, 2009 | Computers & Internet
PC SHUTS DOWN ON ITS OWN
Could be a few different possibilities-
Power Supply failing
Overheating Issue
Virus-
first thing i would do is to try booting the computer up into safe mode with networking. to do this:
Shut off your computer and turn it back on- immediately start pressing the F8 key repeatidly until you get an advance boot menu- then go to safe mode with networking and press enter on your keyboard- See if Windows operates normally while in safe mode- If so then issue is probably a Virus.
Apr 09, 2009 | HP Computers & Internet
Computer stays on bios page
Hello there
first i would remove the battery on the board and see if it is good if so replace it and now remove the power supply to the motherboard for 2 min and press the power on button and the reset button
now plug in the power supply to the motherboard back on and plug in the computer now you should just have top reset the time and date ok?
best regards michael
Apr 05, 2009 | Compaq Digital PC 3100 PC Desktop
Acer Aspire powers on and off
The power supply is suspect here but go to setup or Control Panel to disable any power saving settings. Just change the setting to "Never turn off". I don't have your operating system to be specific but you can find the settings if you just explore.   If the signs point to the power supply you can try connecting another power supply if you have one available or check the Power On/Power OK pins at the connector if you have a meter. There are also power supply checkers you can buy but power supplies are not much more so just take the power supply out and any local service department where power supplies are sold will check your old one before selling you a new one. Let me know if you get any more clues to go on or need help as to where to check with a meter. Steve Medley
Dec 14, 2008 | Computers & Internet
Computer keeps shutting off
The problem more likely seems with the power supply or the front power button. Donnot try switch on the computer again and again it may cause damage to the motherboard. Use the following link to pin point the problem.
http://tinyurl.com/5bbrxc
Thanks
Proton
Do remmber to rate the solution if it was helpful or fixed your problem.Thanks for using fixya
Jul 05, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Boot Issues
I've seen the same problem fixed it with new power supply. The old one was losing full power.
Oct 08, 2007 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Eyemax DVB 9060 16CH 60FPS DVR Board Logo
53 people viewed this question
Top Eyemax Computers & Internet Experts
David Payne
David Payne
Are you an Eyemax Computer and Internet Expert? Answer questions, earn points and help others
