Question about Corel Paint Shop Pro 9
I am home this weekend and I decided to paint my living room. Is there an amount of coats that you are needing to put on the wall? It has been a while sense I have painted. I heard maybe about 3 to be safe.
  • 364 Answers
If the existing paint is a light color and you are doing the same color, then 2 coats should suffice,. Painting it darker, I would go 3 coats, painting it lighter, you may need to go more than 3 go to harbor freight tools and buy some plastic drop sheets, masking tape {blue} and some cheap brushes and roller and tray, turn on some tunes and a glass of wine, enjoy the "me time" depending on the quality of paint too will determine the coats needed, ask your home depot guy. behr brands are good cover paints. good luck have fun.{ps..wear some old clothes}
Posted on Oct 15, 2013
2 Suggested Answers
iqbal_del
  • 655 Answers
SOURCE: Jasc Paint Shop Pro 9
I think the better place to learn is the website of the vendor, i.e. http://www.corel.com/servlet/Satellite/us/en/Product/1184951547051
Go to the site and navigate 'Whats new' and you can get many more tricks from there..
iqbal
Posted on Mar 08, 2008
How do I calculate the amount of paint needed for walls in a 12 foot by 16 foot room with 8 foot ceilings?
Ceiling paint estimator
Use the following formula to estimate the amount of ceiling paint you need. Double the result if the ceiling requires two coats.
1. Multiply the length of the ceiling times its width to find its area.
14 × 20 = 280 square feet
2. Divide that number by 350 (the estimated square feet covered per gallon) to figure out how many gallons of paint you need.
280 ÷ 350 = .8
For this example, you want to buy 1 gallon of ceiling paint for a single coat.
Wall paint estimator
Use the following formula to estimate the amount of wall paint you need. Double the result if the walls require two coats.
Feb 18, 2015 | Tools & Hardware - Others
Paint scratches off easily on drywall
You can find good colours for painting your wall and good durable paints and follow it with the help of interior designers. They provide plenty of samples and designs for your requirement and guide you. They use many fabric paintings, hand painted wall papers, laminated multi coloured wall papers with different textures. For further ideas and assistance you can contact them at http://www.interiordesign.net/. Homepage Interior Design
Feb 18, 2014 | Dutch Boy Int Drywall Pva Primer By Dutch
Top 2" of my concrete wall has eroded. How do I fix it, so it will last, and make sure new concrete bonds to the old?
Hi.
There are different kinds of concrete coating. The choice of product varies, depending if the wall is interior or exterior and on the location of the wall (for example the product used in a bedroom's wall will be different from the coating adopted in a garage).
Epoxy coating are great products that can be used in exterior or interior. Epoxy products however may smell and trigger allergies. Epoxy is one of the strongest coating for exteriors.
If the space is a living room, then it is probably better to use acrylic cement. Acrylic coatings do not smell and do not release volatile compounds. Acrylics look similar to Portland cement and are generally less strong and adherent than epoxy paste.
The application method is usually illustrated in the coating product's container. The procedure consists in cleaning the wall (you can use a power washer), applying the product with a trovel, and then checking the results after 24 hours or when prescribed in the coating's instructions.
After applying the coating you can finish the wall with paint and sealer product.
Oct 18, 2013 | Yamaha RX-V757 Receiver
I have a red coat rack in my daughters room and it clashes with the pink walls, do you have paint suggestions?
As an interior designer, I always recommend using gender neutralcolors in kids' rooms. I suggest thatyou paint your coat rack a muted color like grey, beige or white. The lighter the color the less likely it isto be mismatched with the rest of the room.
May 29, 2012 | Home
How could i put a glitters with my wall at my facebook
  • SPRAY CLEAR GLITTER ON DRY WALLS -- Go to your local craft store and pick up a couple cans of spray glitter. You want a clear base so you can keep your current wall color. Look for a spray that says something like clear glitter finish or clear glitter sealer. Then just spray your walls with the clear glitter spray.
  • PAINT YOUR WALLS WITH GLITTER SPRAY PAINT -- If you want to change the color of your walls you can spray paint them with colored glitter spray paint so you get the painting and glitter done in one easy step. However, spray paint can be expensive and you may find it is difficult to get a nice even coat of paint. So this method would be good for a small room or an accent wall.
  • PAINT YOUR WALLS THEN ADD GLITTER -- This is the cheapest way to get the glittery look you want. Buy your wall paint in the color of your choice. Then buy tubes of glitter in the craft section. As you paint your walls, do one small section at a time. Then pour out a bit of glitter on a paper plate and gently blow on the glitter so it blows onto the freshly painted wall. The glitter will stick to the wet paint. Then move on to the next section and do the same thing! If you are applying two coats of paint to your walls add the glitter to the second coat.
  • Feb 27, 2011 | Graphics RSA SID700-6-60-48-5...
    We have been painting our livingroom with Matt Emulsion Ivory Cream. We are painting onto anaglypta. The previous colour was also Ivory Cream. My husband has a heart condition and I have osteo athritis...
    Other possible issues could be:
    1. The paint wasnt mixed properly before application. You have to stir the paint using a wide paddle/object, scraping the bottom of the tim to loosen the pigment and mix it into the paint properly first, and then regularly re-stir the paint therafter.
    2. Was a proper undercoat applied to the wall first? generally undercoats reduce the problem of patchiness by proving a more even surface for the final coat paint to adhere to and remove any existing issues with differing absorbancy of the underlying material.
    3. Could just be bad paint. Also, check with the paint tin that the paint was applied during the right environmental conditions. Some paints can't be applied in extremely low or high temperatures, or when humidity is very high etc.
    Hope that helps.
    Feb 25, 2011 | Garden
    Corel Paint Shop Pro 9 Logo
    103 people viewed this question
    Top Corel Computers & Internet Experts
    Martin Murray
    Chris Larocque
    Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
