Question about Electronic Specialties Battery & Starting/Charging System Tester
Ford explorer 98 replaced starter replaced starter relays new fuel pump. shop did some work still having starting problem. the shop said it needs a new flywheel.doesnt skip seems to be straining to start new battery too.
    Problem Solver:
  • 15 Answers
If flywheel is worn, then it should be replaced. Chances are that it's the problem.
Posted on Nov 22, 2013
98 ford explorer getting to much fuel in cylinder
Have a shop check fuel trim & determine if you
have fuel injectors that leak & need to be removed,
mailed away & cleaned & tested
Jan 18, 2013 | 1998 Ford Explorer
98 ford explorer cranks wont fire
Check your Cam,MAP,MAF sensors.
Mar 07, 2012 | 1998 Ford Explorer
98 ford explorer fuel pump only work for one second than shut off when you crank the engine the fuel pump shut off
Check the fuel pump relay connections, the Explorer is bad about connection corrosion at the relays, try unplugging it and sticking it back in. Hope this help, let me know.
Aug 04, 2010 | 1998 Ford Explorer
98 ford explorer cranks but won't run.
it means that the key(s) needs to be recoded to the car,when you did the wheel you wiped the codes out.....the transponders are in the keys.
the car thinks its not you/your keys.
Apr 01, 2010 | 1998 Ford Explorer
My 1995 Explorer will start then wont start.
what exactly is it doing, does the starter turn the engine over? if that is ok what is the fuel pressure reading? do u hear the pump running?
Jun 28, 2009 | 1995 Ford Explorer
Ford explorer no fuel coming through
disconnect fuel filter on flow side turn key on if it spits fuel you should check the sparkplugs and injectors for propper spray pattern
Jun 05, 2009 | 1996 Ford Explorer
My 1998 ford explore stop running!
Try rapping your started with a hammer a couple of times. It sounds to me you are having starter problems, not you fuel pump. If this works it may be only tempory and your starter may "freeze up" again. If so, you are probably in need of a new starter.
Dec 19, 2008 | 1998 Ford Explorer
1995 FORD EXPLORER 4X4 6 CYL 4 DOOR WONT START
Fords have inertia fuel cut off switch. You need to check that first. If you dont have fuel. If you have fuel and no spark you need to check for inj pulse to injector. Make sure no fuses are blown. If no spark and no injector pulse then replace cranksensor.
Dec 17, 2008 | 1998 Chevrolet Cavalier
Electronic Specialties  Battery & Starting/Charging System Tester Logo
53 people viewed this question
Top Electronic Specialties Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Electronic Specialties Measuring Tool and Sensor Expert? Answer questions, earn points and help others
