posted by hotgirls on Sep 25, 2007
i need at code for my rca412c
Comment by hotgirls, posted on Sep 25, 2007
can you tell me how to program thsi
Best Solution
posted on Dec 15, 2007
THIS WORK!!!!! to make this simpler
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 21, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I believe I can help, I have the same one. First push the device button you want to program, for example we will program your t.v. First push the t.v. button on the remote, then push and hold the t.v. button down and the on/off button and hold them down at the same time until the on/off button light comes back on and stays on, then alternately push the on/off button then the CH+ or channel up button, on your remote while pointing it at the t.v. until it comes on or goes off, each time you hit the CH+ button you advance to the next code until you go thru all the codes programmed in the remote. After the t.v. goes off or on you have found the code for your t.v., then just hit the stop button on the bottom and the on/off button light goes out and the code is stored, hope this helps.
Suggest a new solution for this problem
Post a New problem for RCA RCR412C Remote Control
Email this problem
Email this problem
Can you Help with these Remote Controls problems?
Repair Service
Find Remote Control Repairman Near You:
Find Parts
