Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
GE FRIG has stopped dispensing crushed ice, just cubes
    Champion:
  • 210 Answers
Test auger solenoid. unusual problem, usually other way around. clean out ice bin and check for anything broken.
Posted on Oct 15, 2013
4 Suggested Answers
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
SOURCE: Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
samrat_babui
  • 296 Answers
SOURCE: Ice maker only makes crushed ice, no cubes
hi.
I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck.
chek these sites
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23620-ice-maker-only-makes-crushed-ice-no-cubes.html
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
if satisfied plz rate this answer
all the best
regards
Posted on May 27, 2009
I got a new french door frig and it wont make ice CUBES. It makes ice and even though the indicator says cubed ice, it comes out crushed. Is there a way to fix this easily. Otherwise i like the frig very...
Try removing the ice bucket and ensure that there is no obstruction (ice cubes stuck inside of metal blades). If no obstruction, then your problem may be in the electronic dispenser control board (if applicable) that distinguishes between cubed and crushed ice. If it appears that the problem is the board, then contact an appliance service company.
Feb 10, 2010 | Samsung RF265AA Bottom Freezer French Door...
Dispenses crushed ice instead of cube ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE refer will not dispense cubed ice
I have the same problem. My GE refridgerator won't dispense ice cubes.
May 01, 2009 | General Electric GSS22JET Side by Side...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Ice crusher has stopped crushing
Replace the switch behind the front panel on the freezer.
Mar 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
WE HAVE A GE REFRIGERATOR THAT IS ONE YR OLD AND IT WILL NOT CRUSH ICE. WE'VE REPLACED THE ICE MAKER AND IT STILL WILL NOT CRUSH. IS THE SOLENOID OUT BEHIND THE ICEMAKER ARM IN THE FRIG WALL? GE MODEL...
You may be on the right track. Remove the ice bucket and check the square hole behind the ice bucket in the back wall of the freezer. You should be able to move the horizontal rod in it up and down with your finger. If not, it may be frozen in one position. If so, just warm the area a bit with a hair dryer to free it. Replace ice bucket and test. Another thing which may cause that is the ice auger itself may have separated from the drive shaft. (The icemaker itself has nothing to do with making "crushed" ice. It only makes cubes. The cubes are dispensed or crushed and dispensed at the front of the ice bucket using the auger and the metal parts there.) You might also want to verify that the long metal rod (which extends past the ice bucket and into that square hole) is able to move. (it is spring loaded)
Feb 03, 2009 | Refrigerators
I have a GE Frig 2 years old It make crushed ice when you press the cubed button. It's making cubed ice fine just not dispencing everything else works fine. It is model No. GSH25JSTASS and Serial NO....
could be a problem with micro switches inside the dispenser. it has small switches that when you press the button outside, you are pressing a switch inside and if they are cross wired or what ever, these things happens. if you are familiar with electrical wiring trouble shooting, then i could guide you but if not, then i suggest you call a qualified tech to help you with this kind of problem.
it is as if the wires were interchange. cube button would dispense crushed ice then the crushed ice button is not working.
tnx 4 using fixya,
drcool
Oct 07, 2008 | GE Refrigerators
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
