Question about Singer 2263 Mechanical Sewing Machine
Singer 5830c bobbin issue, my machine tends to eat the back right prong of the bobbin holder, I've been through way too many of them. Before hand it sounds like it's jumping around in its place, and the tension gets screwy so it doesn't sew cleanly but leaves a tangled mess on the under side of the fabric. I've taken it for service on this issue several times, but it always comes back. I've checked the needle is in right way and high enough,I've played with tension dials what else can I try?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Are you using a quality thread (top and bobbin) and is the bobbin a genuine bobbin?
Change needle regularly - do not use blunt or recycled needles. Correct needle for type of fabric
Posted on Oct 20, 2013
SOURCE: tangled bobbin thread
Okay. I had this problem too. try taking the bobbin casing out. I had a bit of thread lintg caught in a remote area of the under-plate area. Blow it out with canned air and oil your machine. That should help. It fixed mine.
Posted on May 09, 2007
  • 19 Answers
SOURCE: Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Posted on Dec 30, 2008
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
My zigzag 20uid.sewingmachine is locked cant turn the balancewheel I ve cleaned both the wheel and the bobbinassembly but still remains d dame
if it has been sit use sum oil if there is rust on the parts use a scott pad to clear see if that will help
May 24, 2016 | Singer Sewing Machines
How do Iinstall the Bobbin holder in na Singer tiny taylor machine?
I"m assuming that you are asking how to reinsert the bobbin case, rather than the bobbin itself. If you don't have your user's manual, you can download it free at the Singer website. When you do, look on page 19; it has exact directions and an illustration there regarding how to reinsert the bobbin case.
Oct 06, 2014 | Singer Tiny Tailor TT700
How to put bobbin attachment back together and then....thread a bobbin! lol
hi, this webpage contains a manual that show you how to put the whole section back
http://www.searspartsdirect.com/partsdirect/user-manuals/3116-singer-parts-SEWING+MACHINE-manual
Regards
Rob
www.electronicrepairs.co
Dec 28, 2013 | Singer 3116 Simple
Machine is out of time
This will be difficult to explain but basically if you remove the plate covering the bobbin holder you will see the bobbin holder.It will have a small prong that should pass the eye of the needle and picks up the thread from the needle. If the timing is out then this pick up prong will be either too soon or will have gone past the eye. get on the web and type in sewing machine needle timing and you will get diagrams for most makes. I did that and fixed an old singer industrial machine.
Mar 02, 2013 | Sewing Machines
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Need to put bobin in a merritt 4530
Flip the presser switch up to raise the presser foot. Turn the hand wheel counterclockwise until the needle is in its highest position.
  • 2Hold the hand wheel in place with your left hand while turning the hand wheel knob counterclockwise with your right hand to loosen the hand wheel knob.
  • 3Place the desired spool of thread on the spool pin so that the pin fits all the way through the hole in the center of the spool. Put the spool holder onto the end of the spool pin that is sticking through the spool of thread and press firmly to ensure that the spool holder keeps the spool in place.
  • 4Grasp the end of the thread and hold it taut between the thumb and index fingers of both hands. Snap the taut section of thread into the thread guide post located to the left of the spool pin.
  • 5Pull the end of the thread gently. Wrap the thread around the bobbin winder tension disk near the left front on top of the machine, starting at the side of the tension disk facing you and wrapping around in a clockwise direction.
  • 6Poke the end of the thread through the small hole in the bobbin from the inside out so that the loose end of the thread sticks through the top of the bobbin. Put the bobbin on the spindle, or bobbin winder, and gently slide the bobbin winder to the right.
  • 7Hold the loose end of the thread in place while pressing down on the foot pedal to start the machine. Hold the foot pedal down until the bobbin is as full as desired. The machine will automatically stop once the bobbin has reached capacity.
  • 8Cut the loose end of the thread using scissors. Slide the bobbin winder to the left and remove the bobbin. Hold the hand wheel in your left hand and tighten the hand wheel knob with your right hand by turning it clockwise
  • Apr 05, 2012 | Singer 6510 Sewing Machine
    When i'm sewing the bobbin holder jumps out of place the needle then lodges it's self in casing and locks machine up,i have replaced the casing/holder and it did the same thing again
    It sounds like the wrong size bobbin, try calling Singer is your bobbin is right because they should be able to answer why it is acting so strange. Good luck
    Oct 05, 2010 | Singer Quantum XL-5000 Computerized Sewing...
    Singer/merritt 2430 bobbin fill
    If you lift up the thread holder, the bobbin holder is inside. Loosen the hand guide to stop the needle from going up and down. Pull the thread around the top thread guide and back into the bobbin holder. Thread the bobbin and move the bobbin over so the guage is "inside" the bobbin. As for the manual, the Singer Merritt 2404 is applicable to the 2430 if that helps.
    Jun 18, 2009 | Janome 6019QC Mechanical Sewing Machine
    Singer 2263 Mechanical Sewing Machine Logo
    183 people viewed this question
    Top Singer Sewing Machines Experts
    Tally Girl
    Tally Girl
    mystery_soul
    Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
