Question about Frigidaire ATF8000F Front Load Washer
Time gets stuck at one minute - Frigidaire ATF8000F Front Load Washer
  • Yvan
    Yvan Oct 15, 2013
    Yvan: The timer goes down very slowly until it gets to the one(1) minute display. But nothing else happens with the washer, and it is the same on any cycle. I tried to unplug the washer for 36 hours,no result!
  • Denny Giesel Oct 16, 2013
    Yvan I am sorry for your frustration-there are a few things that could be wrong-it may not be sensing that the door is latched-this means the door latch switch is bad or it may not be sensing that it has water pressure-please keep me posted Denny
    Master:
  • 818 Answers
O k this is alittle more info-is the machine trying to fill at this point-it may be you don't have enough water pressure to fill-check for incoming blockage or the inlet valves are not working-cheers Denny
Posted on Oct 15, 2013
Maytag bravos gets stuck at 8 minutes on cleaning cycle
Probably the timer is hanging. A vinegar rinse won't make any difference.
Aug 21, 2017 | Maytag Washing Machines
Cotton program stuck on wash cycle with 1 minute left
Control board needs to be replaced. Many times the control boards go bad because of a spike in the electrical grid cause by a brown out, lightening strike or even a surge in the power. After the control board is replaced... I suggest using a surge protector on all of your electronic devices including the washing machine.
Feb 06, 2014 | Hotpoint Ultima WF865 Front Load Washer
On any of the wash cycles the timer will go for 2 minutes and get stuck on that time. It will stay on that time for about 5 minutes and then we get an nF signal.
Its probably a solenoid in the washer that tells it where it is in the cycle. Have it checked or DIY which is cheaper but will void any warranty on it.
Jan 23, 2014 | Samsung WF337AA Front Load Washer
How do I know if my thermostat is bad on my 1995 tahoe
About all a bad thermostat can do is get stuck open or get stuck closed. If stuck closed, engine will overheat-coolant can't circulate through the radiator.
If stuck open, will take a long, long time for engine to reach normal operating temperature-about 20-30 minutes driving or more.
Dec 10, 2012 | Chevrolet Tahoe Cars & Trucks
LG dryer won't shut off - gets stuck at 6 minutes
Your problem seems to be the timer switch is faulty.
Timer switches are normally non-repairable. You would need to replace the faulty switch
Oct 04, 2009 | LG DLE2532W Electric Dryer
Display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
May 09, 2009 | Car Audio & Video
Final Spin Cycle gets stuck at 1 minute
back tub bearing,,and spin surport,,defective,,,under warranty,,,call for service..onthejob
Dec 10, 2008 | Frigidaire Affinity ATF7000E Front Load...
My LG Dryer timer gets stuck on 6 minutes everytime
We had this problem three times. First two times we just removed, cleaned and put back the moisture sensor (metal strips inside). The last time we did as well but it didn't help. We phoned to a service guy and he said unplug the power cord for 20-30 minutes. And it worked!
Nov 12, 2008 | LG DLG2524 Gas Dryer
LG Front Load Washer
This model automatically detects the load size and optimizes the washing time however I do not believe the it should get stuck as you say... try this.. load the washer and then using the control knob.. select Normal.. then push the Quick cycle button on the right.. select the soil level button until it displays 31 minutes.. and run that.. if after you run a wash load it continues to display or get hung up on a specific number such as 7.. your control board may be defective.. If its warranteed.insist they replace it.. Hope that helps...
Aug 10, 2008 | LG WM-2277HW Front Load Washer
Frigidaire ATF8000F Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
