Question about Ricoh Office Equipment & Supplies
Ricoh fax unable to send and receive, makes 3 attempts then gives error "e333"
  • 54 Answers
SOURCE: can't receive fax but can send
Call your cell phone from the fax machine and check the caller ID to make sure that it is the correct number for your fax machine. Next, call the fax machine from you cell phone, and make sure the fax machine rings. Problems like these are almost always a phone line issue, not the machine.
Don't forget to rate your solutions please.
Posted on Dec 04, 2007
checkitright
  • 1362 Answers
SOURCE: how do i change the modem speed on ricoh 3900 fax machine
here is the manual
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=16cc4320e2ae38af56a141f15a196713&q=ricoh+3900+fax+manual
Posted on Dec 05, 2007
  • 1003 Answers
SOURCE: Replaced Ink Cartridge
turn fax machine off open cover and put 3 drops of 3 in 1 oil on the the big silver bar the ink cartridges ride along perform alignment and try to recieve fax if this doesnt work clean all the rubber feed rollers with isopropanol alcohol (rubbing alcohol) applied to a microfiber towel then try.
Posted on Jan 17, 2008
  • 106 Answers
SOURCE: Intellifax 4100 won't receive faxes
probably you not properly install a line cord,try to check.check it and this is 100%.if you still have problem try to conect the telephone on telephone line cord aand check the line is ok.
Posted on Feb 07, 2008
Ajkill
  • 2035 Answers
SOURCE: Lexmark 7350 all in one
Before you begin
To pinpoint the cause of the issue, please record answers to the following questions:
Can a fax be sent or received?
Can a fax be sent, but not received?
Has the fax function ever worked in the past?
Any error messages may also help to narrow down the cause of the issues.
Print out the following:
- a settings list to view the current fax settings
- a receive log if there are issues receiving faxes
- a send log if there are issues sending faxes
- an activity log if faxes cannot be sent or received.
Initial checks
If the fax option has worked in the past and does not do so now, check that the same connection is being used and that it still works.
Check to see if any configuration settings have been changed that could have affected the fax settings.
Faxes cannot be sent/received:
If you are using a digital line, you need an analog card, an ISDN adapter, or an ADSL filter in order to send faxes.
If a PBX is being used, an ISDN Adapter/ADSL filter will not be used as these are supplied within the system. (A PBX is normally used within a company to share a small number of public lines among a large number of private ones to save on cost.) For instructions on configuring the X6100 Series machine with a PBX, see How and When to Use the PBX Option.
Check the phone line (without the printer):
Test the line by connecting a phone directly into the phone port.
Check for a dialing tone.
If you cannot hear a dialing tone, try another phone cable. Once you can hear a dialing tone, you know that the phone port is live and working.
Make sure the RJ11 cable is not damaged.
Check that the printer is accessing the dialing tone correctly:
Press the Options button on the operator panel five times until ON HOOK DIAL is displayed.
Press Select. You should hear a dialing tone.
If you can't hear a dial tone, make sure that the speaker volume is set to High. (Go to Fax, press Options eight times until SPEAKER VOLUME is displayed, then use the plus or minus buttons to change the setting to HIGH. Press Select.)
If there is still no dial tone, unplug the power cable and the phone lead, then plug them back in and try again.
Faxes can be sent but not received:
Connect the Lexmark All-in-One directly to the phone port. IMPORTANT: Do NOT connect any phones to the EXT port.
Make sure the Fax receive mode is set to answer the fax after 3 rings. (Press the Fax button on the operator panel and then press Options three times until ANSWER FAX WHEN is displayed. Change the settings using the - or + buttons as appropriate.)
Faxes can be received but not sent:
Make sure that Country Code is set correctly:
Press the Fax button on the operator panel and then press Options 15 times until Advanced is displayed.
Press Select.
Press Options 13 times and then press the + or - button until the right country is displayed.
Press Select.
IMPORTANT! These tests must be carried out with NO EXTENSIONS, i.e. phones or answering machines, connected to the EXT port on the All-In-One.
Posted on Mar 11, 2008
Can send Fax but not receive error message 0-22 on the fax report
The error message means you have received an fax but there were problems because of poor line condiotions. Ask to resend. Here is lonk to manual.
Ricoh FAX5600L Operator Manual Error Codes
Jan 30, 2015 | Ricoh Aficio Office Equipment & Supplies
We have a receiving problem with our HP Color LaserJet CM2320nf . The exact issue is that, sometimes the machine is unable to receive a fax with any number of pages from different senders Also, the...
Error Code 223 (ECM error)
The receiving product has been unable to receive an entire page even after multiple attempts to rereceive the parts of the page that contain errors. This is usually due to extremely poor line conditions.
1. Reattempt the fax reception at a different time when telephone line conditions have improved.
2. If the error persists, disable ECM. Errors may still occur, and may result in degraded image quality on the received page. However, the ability to receive the entire document will be improved.
Error Code 420
V.34 negotiations have failed from the originating product during phase four, which occurs after V.8 and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Reattempt the fax transmission at a different time when telephone line conditions have improved.
Error Code 421
V.34 negotiations have failed from the originating product during phase three, which occurs after V.8, before phase four, and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Jul 20, 2011 | HP Laserjet CM2320nf All-In-One Color...
Receiving a "DIC error mode
Does the printer have a suitable power source? That error usually comes up if someone attempts to tamper with the unit or power is not up to suitable standards.
Nov 01, 2010 | Ricoh SFX2000MI Plain Paper Fax
Canon fax-phone L75 will not send nor receive
CHECK YOU PHONE LINE IF OK YOU HAVE BAD MODEM CARD
Feb 09, 2009 | Canon FaxPhone L75 Plain Paper Laser
Rx comm error 200082 on receiving fax Ricoh aficio 222SF
I have Dell Monolaser MFP1125, can not send and receive fax
Aug 04, 2008 | Office Equipment & Supplies
Ricoh 2050L
1.put the document for sending on the place
2.dial number
3.if you sending to a direct fax press start or send
and all is ok
Feb 06, 2008 | Office Equipment & Supplies
Could not receive and send Fax
Sending faxes and revieng faxeng through a pbx you need te configure the pbx and youre fax too.( Dail a 0 before youre messages! ) You have to connect always on the pstn line on the 210sf even if you use a pbx.
The Ricoh spc210sf isn't supporting an pbx on isdn line!! Watch out for this because the isdn line is working on 24Volts!! Then you can blow youre fax modem of the spc210sf .
You can contact me true email= r.trip@alice.nl
Let me know is you encounter new problems?
Greetz
Richard Trip
Jan 16, 2008 | Ricoh Aficio SPC210SF All-In-One Laser...
Brother MFC 8860DN: Send Problems
Update the firmware and it does support SMTP-AUTH
Nov 04, 2007 | Brother MFC-8860DN All-In-One Laser...
386 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
