Question about LG DVD 5183 DVD Player
Blown power supply ic for cd/dvd receiver da3620 no.not visible
A loose screw shorted one leg of the 8 legged switching ic and blew it such that the ic number can not be read from the ic. the ic no.is the one that i am looking for.
  • structure391
    structure391 Aug 22, 2012
    lg dv276k power ic blown and want replacement
2 Suggested Answers
  • 6 Answers
SOURCE: Can you please send
Seems like FixYa don't like me posting images in the solution box.
I'll send you a link instead. The image is quite small, but as I don't have the shecmatics myself, I had to look it up...I guess you can download it as a .pdf file though.
There you go!
Hope it helps. Good luck!
Posted on Jul 26, 2011
Hi,i have samsung ml-2240 OS version 1.01.00.84 how can i reset it?
Unplug all the printer cables and make sure it is switched off. Remove the two bolts that are on the left and right at the back of the printer using a screwdriver plus (+)
After both bolts removed, and the socket lock is opened, slide the cover to the side slowly.
Remove the cooling fan attached to the cover
It will be seen two engines Samsung ML-2240 printer, the machine power supply and motherboard.
Find and watch IC EEPROM 8 feet that attach to the mainboard printer Samsung ML-2240, ie the number 93C66WP ic U6.
After the IC U6 is found, install and connect a jumper or a small wire to the ic leg 1 and 4
After leg 1 and 4 on the IC is connected, plug the power cable, and turn on the printer.
Wait a few moments until the printer has finished calibrating and lights show green
After the green light, turn off the printer, then remove the cable or wire attached to the legs 1 and 4 IC EEPROM 93C66WP
Close the back cover of the printer and do not forget to plug the two bolts that screw removed earlier. After all these steps done, reset Samsung printer ML-2240 is completed, the printer is ready for use again.
Jan 04, 2018 | Samsung Office Equipment & Supplies
Sa-ht545 error code f61- comes up upon statrting
F61 just equal 'power fault'
Generally a fault with either audio power amp ic (IC 501) or power supply ic IC 502.
As both said ICs get very got first remove bottom steel grill and with the power off and capacitors drained (shorted together with a low ohms resistor or leave unit powered down for a few hours) resolder the ICs legs if there are any signs of cracks aka dry solder joints.
Hope that helps.......
Jul 09, 2008 | Panasonic Audio Players & Recorders
Cloth not dry
Check for a build up of lint in the exhaust duct, an excessive build up will block air flow.
Also 220VAC electric dryers use different legs of the electrical supply. (two 110VAC legs tied via a common neutral make 220 VAC) One 110VAC leg runs the motor and controls while the other supplies power to the heater.
It is possible that one side of the 220VAC has a blown fuse and is not supplying power to the heater element.
Other possibilities:
Blown out heater - requires replacement
There is a safety switch attached to the shaft of the motor. THis switch relys on centrifical force to close and is intened to kill the power to the heater if the motor and its attached blower stop turning.
If the motor is not turning fast enough of the switch is worn then it is possible that power to the heater circuit is not being completed. It doesn't take must of a speed reduction to cause a problem. Lint build up on the drum bearings can cause enough drag to slow the drum slightly. Combined with a worn/dirty switch and the switch fails to operate.
Finally there is a blower attached to the motor shaft. The blower is made of plastic and somtimes the blower comes loose on the shaft. Usually you hear a rattling sound or sounds after the dryer drum stops as the loose spinning blower spins to a stop. ( A tight blower stops with the dryer drum) A loose blower doesn't move enough air and causes your dryer to run longer.you can find about uniforms: https://www.mysocceruniform.com/customsocceruniforms.html
Mar 06, 2014 | Maytag Neptune MLE2000A Front Load Stacked...
Trransistor by five legs had destroyed i want
That 5-leg component is an IC, more likely to be switch mode power supply IC. What is the make and model of this product? What is this product? Pictures will help a lot.
http://s807.photobucket.com/home/budm/allalbums
Apr 27, 2010 | HP mx705 17" CRT Monitor
Have a str-de 945,unit was working,sound stopped,still powers up.Replaced 2, 8 a fuses,blew again,nothing was connected to the unit.The heavy power supply unit in the front seems to have a hard orange...
Chances are you have shorted output transistors,check with ohm meter across all 3 legs,there should be no shorts if good.. cost on average around 150.00
Apr 16, 2010 | Sony STR-DE945 Receiver
Load bang no power going to it
Look at the power supply first; look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find
Dec 08, 2009 | Polaroid 4011-TLXB LCD TV
Tv turned itself off. turn power back on, picture
Your TV is experiencing a convergence issue as indicated by the 3 blinks. The only way to fix this is replacing the convergence ICs. It is not a hard task to replace these ICs. You just need to know how to solder and work on printed circuit boards.
The convergence ICs are mounted on a large heat sink and are marked with codes starting with the letters STK and there are two of them. You need to replace both.
Look for the heat sink with two ICs mounted on it and check the markings.
Once found, cut the IC legs with a small side cutter and unscrew it from the heat sink. Remove the legs left soldered on the board.
Take note of the IC markings for ordering the right part and how it was installed. Don't forget to buy along with the IC a thermal compound.
Check the pico fuses on the same board. Most likely you will find a blown one. These fuses look very much like a resistor, not like the usual transparent fuse, and usually yellow.
Once you have the replacement ICs, put it on the board in the same way as it was installed before. Make sure the screw holes are aligned before soldering the legs into the board.
Put a reasonable amount of thermal grease/compound between the ICs and the heat sink and fix them with the screws.
Double check the board for any splash of solders that might cause a short circuit and damage the board.
Dec 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I have a Pioneer VSX-454 reciever, both 1.25 Amp fuses blown
blue two legged varacter on power supply board needs to be replaced
Jul 12, 2009 | Pioneer VSX-454 Receiver
Power surge has killed my DR-MH200SEK
gargame,
good day, if you already replaced the fuse and still keeps on blowing it again. you still have a short circuit somewhere within the power supply area or board.try to check if there are any other blown parts or slightly expanded shape part specially for capacitors near the power supply area .
2) If you do have multi tester and have some basic knowledge with component checking try to check the polyswitch protector, this is connected parralel to AC supply right after the fuse before going to voltage rectifier diode.
3) if it doesn't have a polyswitch protector check the polarity of your rectifier diode, maybe 1 of this 4bridged diode is shorted.
cheers,
mark
Jan 29, 2009 | JVC DRMH20 DVD Recorder
P5002 Problem
The schematic is available from Rockford.
It's possible that the outputs have blown. They generally short from the center leg to the third leg when they fail.
Unless you have experience working with the MEHSA insulators, you may want to buy the entire MEHSA strip from Rockford. You can replace the transistors on the insulators but you have to use a torch to heat the strips.
Nov 18, 2007 | Rockford Fosgate Punch P5002 Car Audio...
LG DVD 5183 DVD Player Logo
245 people viewed this question
