Question about Pride Go Chair Travel Power Chair
Squeaking/squealing noise I have a squeaking/squealing noise from rear wheel of Prdie go Chair. Can you tell me what this is.
I have select gt power chair, it is only 2 years old but has developed a very troubling squeak.
hi James, the squeal, now it can be a bearing running dry or worn in a given area or metal rubbing on dry plastic etc...
Try some silicone grease on the parts that move... beware of shorting anything ... is the noise coming from the end of the motor , e.g the brake ?
Regards
Feb 28, 2016 | Pride Jazzy Select Gt Mid-wheel Drive...
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Feb 03, 2016 | Cars & Trucks
What would make a trans squeal while driving down the road?
You don't say, Front or rear wheel drive. First check oil level, On rear wheel drive check the thrower plate on the tail shaft at the diff end is not bent and rubbing on the seal, A dry oil seal can make this noise.so can the U/Joints. on front wheel drive , check the cv joints , dry oil seals , the drive shaft inner cv joints have a thrower plate that may be bent. worn or binding brakes can make this noise also.
Sep 24, 2014 | Cars & Trucks
Loud squeaking/ squealing noise when turning wheel
Have you had your wheel bearings checked. With the front wheels straight, back up about 50 feet then pull forward about 50 feet. You will need to do this on level ground. Then from about 25 feet in front of and behind see if any of your wheels look like they are tilting in at the top. If so jack that wheel off the ground and see if it moves in and out at the top. If so its likley the wheel rubbing aginst the backing plate of your disk brakes. Let me know what you find
Jan 09, 2014 | 1991 Mitsubishi 3000GT
Sharp squeaking from rt rear wheel. Might be a bearing but it stops if i apply light brake pressure
your rear brakes need servicing!!Those sqeaking noises are from metal pins within the brake pads. They touch the rotor surface when the pads are worn. Usually when brakes are applied they tend to silence the squeal. Inspect the rear brakes for pad thickness. Hopefully this helpd!!
Aug 14, 2010 | 2004 Toyota RAV4
In my 2003 Saturn Vue, whenenver I turn the wheel left or right I hear a squeaking nose coming from the wheel (inside of the car) what could this be?
moz-screenshot.jpgThere is a TSB for your complaint from Saturn: Here's the jist of it.
Condition: Some customers may comment on a squeak or squeal noise coming from the base of the steering column while turning vehicle.
Cause: The squeak or squeal noise may be caused by insufficient lubrication of the intermediate steering shaft-to rubberboot- contact area.
you may be able to get it warrantied through saturn. this is the TSB #
#03-02-34-002
Jan 07, 2010 | 2003 Saturn VUE
Hl-2140 noises
For a possible fix to the Brother HL-2140 squeal/squeak/noise problem open the printer at the other side from the paper tray and toner cartridge door. You should see a little black roller rod along with some white wheels.
The noise may be coming from the contact between the wheels/rollers which pull paper toward the output tray on top after it has been printed.
Check and clean/wipe the wheels and black rod, especially in the center area. Hopefully the noise will now be reduced/eliminated.
Cheers, Stephen
Sep 14, 2009 | Brother HL 2140 Laser Printer
Brake noise from rear drivers disk brake when turning
sounds like the front brakes need replacing, that what the squeal is. They are made to do that so you know when to replace them
Apr 27, 2009 | 2002 Chevrolet Camaro
Loud squeaking brakes.
If they are wearing down, they may squeak, and some brakes have a metallic part that will come in contact with the rotor when the wear gets to a certian point making an awful squeaking sound telling you that mabe you should change 'em soon, eh
Jun 17, 2008 | 1995 Ford Escort
Pride Go Chair Travel Power Chair Logo
43 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
