Question about Maytag Washing Machines
My maytag washer keeps going into rinse cycle
    Master:
  • 492 Answers
Unplug the machine and plug in again after about 2 hours. Resets the computer code on the board.
Posted on Oct 15, 2013
SOURCE: GE WASHER WON'T GO THROUGH THE DRAIN CYCLE AFTER WASH CYCLE
Most likley it's the drain pump! check the wiing and pump
Posted on Jul 09, 2008
TheMobilian
  • 8220 Answers
SOURCE: maytag washer overfilling
Easy fix. Do this: Remove the rubber tube coming from the bottom of the tub up to the water level switch right there at the switch itself. Blow through it to remove the sediment in the bottom of the tub so that air pressure from tub to switch will be kosher. Put the hose back on the water level switch tight and pump out any water in the machine.
Retry
Posted on Dec 19, 2008
SOURCE: Maytag Atlantis MAV6200AWW; Washer goes through
Maytag Atlantis washer goes thruout washing cycle,but dosen't simse or spin....
Posted on Jun 12, 2009
SOURCE: My Maytag Neptune washer won't spin during the spin cycle.
I'm having the same problem...Does it say LR?
Posted on Jul 20, 2009
dh1200s
  • 335 Answers
SOURCE: maytag neptune washer keeps beeping
The Service Manual for reference. Sears Parts Direct for reference.
I have tried to work with a few folks on this issue never received feed back to resolution see this post. I feel the issue is caused by one of three possible issues.
A stuck key issue/defective Spin Cycle key making constant contact forcing the Key/LED to cycle thru the Spin Cycle settings. Under normal conditions if you press and hold the Spin Select key it will cycle thru the settings, yours has a mind of its own (defective issue).
A false signal from the Control Board for the Spin Cycle.
A corrosion path issue at the Membrane Pad ribbon cable socket connection between pins 5 and 4. See page 20 of the SM button functionality “Spin” key.
Try to verify that the spin cycle membrane key is not stuck/defective signaling the Control Board to cycle thru the spin settings. I have not experienced this issue but let’s try the Membrane Pad Test
to get a start point. See the Service Manual page 15, I have modified the process to make it a bit more understandable at least for me. Make sure the two digit display is not On or Lite.
Press the off button first so there is nothing displayed in the Two Digit display of your FAV6800AW.
Now Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys for three seconds or until the control beeps. While in Service Mode, pressing the Presoak key will start a membrane switch check that verifies switch operation.
All the LEDs (except Presoak ) can be toggled or slewed by pressing the key associated with the LED or set of LEDs. Do not press the Presoak again during this test.
Press each key once and only once including the Signal Key the on side and the off side, also the UP and Down Arrow key of the LED display. All keys (including the OFF button) must be pressed within 5 minutes for this test to pass. “PA” will be displayed for five (5) seconds once all keys have been pressed and the test is completed (more like PA will be displayed for only a few seconds on my FAV6800AW). Following 10 seconds of inactivity at any point, this test will exit without any display. Let us know the results.
See my additional comment this board has message limit issues.
Posted on Sep 17, 2009
My Maytag Neptune front load washer (about 12 years old gets stuck between 7 & 8 (minutes) in the rinse cycle and won't progress beyond.
It has reached it's use by date, It will just keep on needing repairs , save some money and buy a new one.
Jan 04, 2016 | Maytag Washing Machines
My Maytag Neptune front loader always retains water after the rinsing cycle is complete. This has lead to mold in the door gasket and a moldy smell. Is it normal for water to stay in the machine after the...
pump is probably clogged not allowing all water to drain out. Should never see water in the tub at the end of a cycle. About once a month you should run your washer through a cycle with hot water and bleach. Doing that should keep the moldy smell down.
Mar 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
OUt of balance during rinse and spin cycles
I have the same problem. During the spin cycle, the washer spins all over the room.....very loudly.
Dec 26, 2009 | Maytag Washing Machines
Maytag washer stopped working at the rinse cycle
do you have the machine set for cold water rinse? if so, the solenoid that allows the cold water to come into the machine may be malfunctioning. try to see if it will fill in the rinse cycle with hot water? if so, you need to change the water inlet valve.
Oct 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer shutting off on rinse cycle
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Let me know if you need further assistance.
Regards
Ellin
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Washer Maytag
the drain hose tear or broken/ clamp detached / need to replace.
Dec 26, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag keeps washing
Washer with O.C.D Darn, sounds like your timer sequence board has a problem. don't spose a warrantee issue?
Dec 09, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
44 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
