Question about Cameras
My camera will not power on after adding new batteries. A red light comes on in the back when batteries are put in
    Champion:
  • Cameras Expert
  • 319 Answers
Check your lensblock
Posted on Oct 16, 2013
4 Suggested Answers
  • 153 Answers
SOURCE: HP 945 lens stuck out, red light on steady, white screen
Ok, here's a couple of long shots to try...
If there is a backup battery remove that also and let it sit for some time with the power switch in the on position (if it has one)
also check the battery contacts are clean. Refit both batteries and try again.
Beyond that unfortunately it sounds like a main board failure. If you have any warranty on the camera return it, if not its likely the cost of replacement would be fairly high but worth checking with HP.
If your handy and fancy a go at it yourself it may be worth opening it to check nothing has become dislodged, but this is unlikely. else pick up a faulty one off ebay, one with a broken LCD or lens and have a bash at swapping the main board out yourself.
A WARNING ABOUT OPENING DIGITAL CAMERAS THEY BITE
Before opening a digital camera its recommended you let it sit for some time (like a week) with no batteries in. There ia a large capacitor (like a battery) which can be charged up to 300v if you touch the contacts or anything connected to it it really is like a shock from the mains.. I have been bitten many times...
This can damage the delicate parts within because of high voltages but more often because you almost always drop the darn thing..
Best of luck
Posted on May 26, 2008
SOURCE: battery problems
I just read this post about elevating the metal contacts on the outside door with paper & it worked like a charm. Thanks so much for the tip! We just got this camera for Christmas (hand me down) & don't have the money to replace it so very thankful for the advice!
Posted on Dec 26, 2009
  • 11967 Answers
SOURCE: Sony DSC-W110
First, stop plugging it into the computer. Next, remove the card and battery, press all the buttons, leave it alone for 20 minutes, insert the card and then the battery (which I'm assuming is fully charged), turn it on. To download your pics in the future, use a separate card reader.
Posted on Apr 25, 2010
Testimonial: "Thanks for the advice, but that was not it. I posted some more information that i found out after i tried your first solution."
When i press power button red light shows but will not turn on
certain cameras can only power up using a more powerful battery such as lithium batteries... if you are using regular alkaline batteries then it will not power up
Aug 19, 2012 | Video Cameras
I'll push the power button and the little green light flashes it beeps and the lense comes out just a tiny bit but then in stops goes back in and beeps twice and it's still off. Is there and...
First check the battery. Charge the battery to full condition or change with new battery and try to turn on your camera.
Or you can put off all batteries and memory card, wait for a moment, then put in again and turn on your camera.
Hope this help
Feb 09, 2011 | Casio EXILIM 10.1-Megapixel Digital Camera...
My camera will not come on.
hmmm...if the lens in the front is stuck; take the batteries out, charge em (rechargable batteries), put em back in, press the power button once. the lens should come back in only. leave it for a while. hmm...if the green power does that then u need to charge ur batteries again for a really long time. it means the camera will not use the juiceless batteries.
May 13, 2010 | Samsung S760 Digital Camera
After charging the Battery the power button flash blinks
i think the red light means low power for battery... maybe just maybe your battery didnt really charge.. im not saying that its the charger, but try to buy a new rechargeable batteries, use it then charge it and compare it with the other one... i think thats the problem with batteries if we stop using it for a long time... hope ull be able to resolve it
Sep 13, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
When I press the power button the light turns
hi..
Try taking out your batteries and then taking out your memory card. Put back in batteries. Turn on camera.
If this works, just put back in your memory card and try again. Sometimes the memory card hangs and you need to pop it in and out.
thank u
rate me!!
Jul 15, 2009 | Sanyo Xacti VPC-S770 Digital Camera
Red flashing light
Find a new supply of "Duracell Ultra with M3 Technology" batteries and give them a try. The flashing red light is usually an indication that the batteries you have in the unit are not producing sufficient power to run the camera. Rechargable batteries are should have a rating of 2500mAh or above in order to provide enough power to maintain the draw from the camera.
Hope this helps!
OpenSource13
Apr 05, 2009 | Sanyo Xacti VPC-S60 Digital Camera
Kodak Easyshare CX7530 won't stay powered on
SOLUTION: Fot the past two years, fully charged NiMH and new alkaline (generic and fresh Name Brand batteries) in my CX7530 always gave a red light and immediate power off -- symptoms of low batteries. Today I tried it again with the same problem. This time, I folded up a small piece of stiff paper to depress the small Lithium battery module detect switch in the battery compartment, and put my NiMH batteries back in -- it WORKED for the first time in two years! After removing the paper and reinserting the batteries, it still works. I suspect this somehow recalibrates the low battery detect circuit. I hope it helps you as well.
Oct 18, 2007 | Kodak EasyShare CX7530 Digital Camera
Camera Will NOt Charge
go for the new charger. Keep the battery, always good to have a couple of batteries[I have 3 lions and when I was using AA's I had 6 sets of 4.
Aug 19, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Red light flashing
I had the same problem last night. It went away when I recharged the AA batteries.
Jul 23, 2007 | HP Photosmart 945 Digital Camera
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
