Question about Dometic Rooftop RV Air Conditioner
Thermostat has no numbers on it a/c wont come on already checked fuse and breakers
    Master:
  • 818 Answers
Next thing to do is to check and see if there is power at the unit-Denny
Posted on Oct 15, 2013
Samsung dryer wont heat
If it does not heath at all check the heating element, circuit breakers, thermal fuse, and also the thermostat.
If heat is scarce check thermostat and faulty heat relay.
Jul 08, 2010 | Samsung 7.3 Cu. Ft. Electric Dryer
Removed honeywell thermostat from new home to install a new honeywell programmable thermostat. Couldnt get the new one to work so reinstalled the old one and it wont work. Checked breaker already, cant...
Do you have a model number for the new and old thermostat? Do you have a split system? This means you have a heater in the house and a condensing unit somewhere outside of the house. Let me know if you have a packaged unit or a split system and we can go from there. I might just be a blown fuse on you board, but I need to know what you have so we can start to trace things out.
May 11, 2010 | Honeywell Programmable Thermostat Heater
My 970-c85092 dryer only runs cold air. I'd like
not likely a fuse. check the heating element for a break. the thermal fuse will shut the dryer down completley. could be you need an upgraded thermostat kit for the heater assy.
Oct 04, 2009 | Dryers
Dryer won't heat up but tumbles. What could be
you could have a bad heating element, a tripped circuit breaker, a blown fuse in the dryer or a bad timer. you can check the element and fuses/ thermostats with an ohm meter for continuity.
Sep 17, 2009 | Dryers
My dryer will not heat. I had this problem about 6 months ago. I have a res6745rq0 model.The thermostat was replaced and the fuse 6 months ago
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor 2 heavy red wires (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 16, 2009 | Dryers
No heat
was the old heater bad? check your fuses and /or circuit breakers fuses will show a break in the glass part, circuit breakers flip to off and then back on. some times breakers dont flip to blown section. if all o.k. test the terminal block where wire connects to dryer see if a terminal is blown. if o.k. chreck thermostats especially fuseable link inside back panel most likely fuseable link will be no good. if everything checks out youmay want to buy a repair booklet or call a repairman as the problem is very technical. good luck
Jan 27, 2009 | Whirlpool Dryers
Ge spacemaker jvm1533 is dead wont turn on
check the circuit breaker first it may be the fuse is blown The fuse may be located behind the grille following the power cord on the rside of the unit.
it may be a bad thermal fuse or oven thermostat.
Dec 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Central air unit problem
Check inside that breaker box for fuses.
Sep 06, 2008 | Amana Heating & Cooling
Dpsb513eboww elictric dryer
ck thermal fuse on heating element usually the smallest of the thermostat looking parts on the element housing
May 28, 2008 | GE Dryers
LG DRYER MODLE DLE0332W
If it is running, chances are one of the thermostats are gone. You have two on the heater bank, a high level and a safety, have them both changed.
Sgt 48
May 25, 2008 | LG DLE2532W Electric Dryer
Dometic Rooftop RV Air Conditioner Logo
20 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
