Question about Saws
Clarke table saw parts list
Cts 10b motor
  • 59 Answers
SOURCE: old craftsman table saw parts?
most sears stores have a dept. that refurbishes and sells these tools. if it can be had, they can help.
Posted on Apr 25, 2009
  • 187 Answers
SOURCE: New or used motor for a Craftsman 10" table saw
You can try Sears but they can be a bit pricey. I use to send out motors for a factory I worked in to a rebuilder who would even do new windings. Check in your area for a rebuilder, As for the replacement being a Sears unit they may have a similar motor in stock. Good luck.
Posted on May 08, 2009
  • 145 Answers
SOURCE: I have a skill table saw model 3400 type 2. The
I would check to see that ID of the blade arbor matches the OD of the motor arbor, and you are not missing an adapter ring. Then I would get some acetone and a wire brush clean all surfaces where the blade seats. This is also good practice for Jacobs chucks on drills, that allow the drill bits to spin.
Jim
Posted on Aug 04, 2009
buffalonyman
  • 1865 Answers
SOURCE: take apart a motor assembly
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=315218050+&=part+number
Posted on Nov 21, 2009
SOURCE: need a parts list for shop craft mod-t678021p
I need the table guide for the saw
Posted on Jul 07, 2010
Bosch 4000 table saw motor does not turn, very stiff
Possibly something has jammed inside the motor housing although unlikely.
Electric brake seized perhaps?
Carbon brushes need replaced?
These saws (and the newer 4100) have a history of motor problems, with the field winding and electronic motor speed control being the most common points of failure. If you go to an online tool parts supplier like toolpartsdirect- Bosch 4000 saw you will see a list of the parts available, as well as the most commonly ordered parts.
Thanks go to Jason for his blog post at:
http://mypeculiarnature.blogspot.co.uk/2013/07/bosch-4000-table-saw-fix-momentum-lost.html
May 23, 2014 | Bosch 4000 - 07 Electric Table Saws
Blade clamp
i purchased a clarke reciprocating saw, and the first time i tightened the blade it broke, where can i get the parts to fix it
Mar 09, 2014 | Clarke Power Products Electronic...
Need on off switch for clark chopsaw 14" BT1010B
The part number for this switch is BT1010B-74. (per manual)
You will need to contact Clarke here:
http://www.clarkeservice.co.uk/parts.shtml
or email them here:
info@clarkeinternational.com / service@clarkeinternational.com
They do not have on line parts info.
Thanks for choosing FixYa,
Kelly
May 07, 2011 | Clarke Power Products Clarke 6" Abrasive...
Can ibuy complete motor
You can find your Craftsmen Table Saw on the internet at http://www.searspartsdirect.com/partsdirect/brands-products/Craftsman-Parts/Saw-Parts?Type=Table saw.
Find your model number on your saw, and you should be able to locate the parts you need.
Feb 25, 2011 | Craftsman 10" Table Saw
I have a crftsman table saw mdl # 137228210 I purchased the saw used. I need a rip fence . the guides are allready there. any help would be appreciated
There's an exploded parts drawing and parts list at the link below. This may be useful to see what the fence is supposed to look like. It's not listed as an assembly, just a surprisingly long list of parts that would cost a fortune - if they were all available. Maybe you can find one on ebay. Barring that, you can always just clamp a board to the table to rip with - the hard part is getting the makeshift fence to be parallel to the blade. To do that you can use an adjustable square and measure from a miter slot in the table to get a quick and straight setup. Good luck.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-137228210/0247/0744600/P0104056/00001?blt=06&prst=0&shdMod=137228210#Partslist
Feb 09, 2011 | Craftsman 10" Table Saw
Looking for cost of replacement motor for skilsaw model 3400 13amp for 10" table saw and where to buy from? Also, is there a 15amp replacement motor that would bolt right in to replace?
i looked online at places I get parts from. Neither listed the motor as a part the had the aramature for about $70 and the field for about $35. Have you tried the reset button? also it may just need new brushes.(if you see lots of sparks at the end of the motor opposite the blade, look through the air vent slots it is likely the brushes, unplug the saw, and take them out and replace them HERE is a blow up ) the I would think that if the saw is well used and the motor has burnt out. It may be a lost cause. I am not sure what the price of this was new but you can get a reconditioned saw from Amazon for 135 bucks. And it is a 15 amp saw.
Dec 07, 2010 | Skil 10" Table Saw 3400
20 amp Circuit breaker trips everytime I flip the motor switch on. Its a craftsman table saw motor 1HP Model 113-12070., 14/7 amps
I assume that you are using the motor on 115 volt service. Remove the drive belt and check for excess friction in either the saw arbor bearings or the motor bearings. If both seem free to turn, then suspect that the start capacitor on the motor has failed. They usually become open circuited which prevents the start rotation. It will just sit there and hum loudly until the breaker pops. You may also have a defective 20 amp breaker--you will need a clamp-on AC ammeter to verify. Suggest that you run the saw on 230 volt service when you get it running. You will be amazed at the acceleration and apparent power available. My table and radial arm saws are both set for 230 volt operation and love it. Go to: Searspartsdirect.com and enter the complete model number minus the decimal point. This will take you to a series of drawings that list all replaceable parts. Hope this helps!
Jun 27, 2010 | Craftsman 10" Table Saw
Bosch 4000 Table Saw running backward
You can find the 4000 manuals and parts diagram at bosch tools online. You will need a new armture Bnew bushes and possibly field. I would also replace the bearings and motor speed control circuit board.
Bosch does not sell the motor assembly.
Turn unit upside down and remove the Plastic body - approx 6 screws.
Thake a digital camera and take LOTS of pictures of dissassembly as you will need them later. Blow unit clean and work neatly keeping all parts in labeled bins for reassembly. Don't attempt this job when your pressed for time.
Before you start check to see if this machine is still under warranty!!
Call customer support listed on website if you run into a problem.
Good Luck !!
May 19, 2010 | Bosch 4000 Factory Reconditioned 10"...
Where do I find a replacement motor for a 1313314 Delta table saw? Wont take a load, keep turning off and smells hot?
Hi there
You can try the website @ http://www.deltaportercable.com/ to see parts list and find service centers near you .
Delta , Porter Cable and Dewalt are together so you can get parts thru Dewalt parts center .
Hope this help
Aug 31, 2009 | Saws
Saws Logo
99 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
