Question about Hotpoint HSM25GFRSA
Freezer compartment warms to 60 degrees for about 20-30 minutes.Had computer board replaced because this was thought to be the reason.Its still happening, would this be a temp.sensor or thermastat problem instead?
    Champion:
  • 210 Answers
Should always change sensor before the board.
Posted on Oct 15, 2013
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: refrigator warm 60 degrees freezer 0
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 09, 2010
I have a Frigidaire side-by-side FRS26Th that was unplugged now plug back up ice maker doesn't work
I thought I saw another post you mention temperatures were warming in freezer and fish food compartment the temperature in the freezer needs to be below 5 degrees Fahrenheit I'm here to help you out if you care to answer Appliance 911 Sea Breeze
Aug 04, 2015 | Frigidaire Refrigerators
Fridge compartments too warm
There are several possibilities on your model. Compressor start components and Adaptive defrost Control. I would like you to pull away from wall and unplug , rempove the cover over compressor and feel the compressor to tell me if warm, hot or too hot to keep your hand there, Waiting for your response, Sea Breeze
Mar 27, 2010 | Jenn-Air JCD2389G Side by Side...
In the back of the freezer there is a ''condenser'' unit that leaks & ice forms along the back of the freezer and bottom. I have opened a drain hole & attached a hose but the water freezes before...
Good day,
First, if ice maker equipped, the fill tube going into the ice maker may be leaking. Shut the water off to the machine, and disconnect the line for now. It can be addressed later.
Although a pain, I would recommend the machine be un plugged for 24 hours and melt and dry out the freezer compartment. If you have a floor fan to blow into the freezer compartment, even better.
Second, There is a limit thermostat clipped to the top of the evaporator. It's a round 1" device.
If I have a problem machine with this problem, I bump the temperature of that tstat 5 degrees.
For example, if it's a 50 degree tstat, I replace it with a 55 degree.
If 55 degree I replace it with a 60 degree. If 60 already, I replace it with a new limit of the same value, since there is nothing above 60 degrees that makes sense. This is to guarantee the old one isn't opening prematurely and not producing enough heat.
As an option, and you might want to wait on this, there are timers that have a longer defrost cycle to aid drainage.
Timers have a defrost cycle that runs between 20 minutes to as high as 35 minutes. Longer is better.
In this case an appliance parts house is your friend.
With the complete model number, ask the counter what cycle your timer has. If your in the 20 minute range, I suggest you go to 30 or 35 minutes. A sharp counter man should be able to find a substitute. GE timers run commonly in the upper range.
I know it sounds like we're trying to kill a flea with a sledge hammer, But in an attempt to make the machine more energy efficient, over the years, they have cut back on defrost time, defrost heater temperature, and heater wattage.
P.S. The timer is mounted in the housing on the top in the fresh food compartment.
Dec 04, 2009 | Refrigerators
My Samsun RS2534ww side by side refridgerator will not maintain temperature on the fridge side. It consistantly warms up to between 50 and 60 degrees despite resetting the thermostat.
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try defrosting the FF as despite common belief these units are not totally frost free.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Nov 06, 2009 | Samsung RS265LABP Side by Side...
Freezer works great, fridge not cold. about 60 degrees in fridge. had repair man look at the fridge, said the mother board, was bad. panel inside freezer iced uped. fridge seem to get better for about 2...
And you are posting because,.......????? You are looking for a second opinion? Don't like the repair estimate?
1. Your freezer is not working great. If it is frosting up, frozen packages will soon beging to soften also.
2. All of the cooling takes place in the freezer compartment. A fan blows air over the coils in the freezer, and directs some of it into the fresh foods side to cool it. When the coils become blocked with frost, the air can no longer flow into the fresh foods compartment. Result is warming of FF area. You may also see freezing in the bottom FF bin, water dispenser not working, FRZ section warm, etc.
3. Manually defrosting the coils will temporarilly solve your problem, but it will reappear in a few days to a week or so. (depending on door openings, ambient temp, etc)
4. The motherboard controls the defrost interval and (although not the most common) certainly can be a cause of defrost failure. If a qualified servicer diagnosed it as such, it most likely is just that.
Sep 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Variance in freezer compartment temperature
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the control board.
Sep 04, 2009 | GE GSS20IEM Side by Side Refrigerator
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Warm Fridge
the defrost timer/ board is getting stuck in defrost and when you unplug it and plug it back in it resets the defrost timer/control board. you may need to replace the defrost timer/control board.
Jun 19, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Upper Fridge Too Warm
We had a warm fridge and super cold freezer.....we unplugged for about 20 minutes and the fridge started to cool down again.... but only for a few days then back to warm.
We ended up unplugging and "defrosting" the whole unit for 24+ hours ....Now it works perfectly again.
I think it happens when one or both of the doors is not shut or sealed all the way and engine works too hard and "freezes" up the fans or some other part of the system.......I am just happy I did not have to buy a new fridge.
Mar 30, 2008 | Maytag MB2262H Stainless Steel Bottom...
Hotpoint HSM25GFRSA Logo
46 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
