Question about Frigidaire ATF6000ES Front Load Washer
Error 30 for the gallery series - Frigidaire ATF6000ES Front Load Washer
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Betty, thank you for allowing me to assist you!
If you are getting an error code E30, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
Posted on Oct 16, 2013
Is there a reset switch when you are gettng an F20 error code
There are no sort of magic "fix my problem reset buttons" on ANY appliance. Please provide me the model number of your product for the definition of your F20 error code & I'll be happy to help you
May 29, 2016 | Frigidaire 30 in. Electric Gallery Series...
F8 error and bottom door locked
Here is Frigidaire's suggestion to your problem:
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
Jul 26, 2011 | Frigidaire 30 in. Electric Gallery Series...
New gallery series frigidaire side by side. 'fridge temp set at 37 degrees, but temp drops to 30 degrees. Everytime I reset to 37 degrees, it eventually goes back down to 30
If it is new (under one year old) then it is under factory warranty, and is not your problem.
Contact your selling dealer and request a service call. There should be no charges to you. Please post back if we are not on the same page as to the age of the machine. Jack
Nov 01, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
F1 ERROR
Hi. This (f-1) code represents a failed oven control board. Have this damaged board replaced asap, if possible. It has failed. Possible logic chip set failure.
Aug 22, 2009 | Frigidaire 30 in. Electric Gallery Series...
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
Jul 13, 2009 | Frigidaire 30 in. Electric Gallery Series...
F-90 error...nothing will turn on
shut the power off for 30 mins at circuit breaker and then it worked after that.
Jun 05, 2009 | Frigidaire 30 in. Electric Gallery Series...
F10 Error code on double oven.
Sir,
Check out this link
suggest to reset it by shutting off both main breakers to the stove , wait for one minute and switch breakers on again.
Thanks Good Luck
Appreciate to rate as "Fixya"
May 15, 2009 | Frigidaire 30 in. Electric Gallery Series...
-F9- Clean Frididaire Gallery Series
F9 code means Control has detected a problem with the motor door latch assembly Soultion: Check wiring, replace the motor door latch assembly if necessary
May 06, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire ATF6000ES Front Load Washer Logo
51 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
