Question about Genie Company Genie Garage Door Opener Safety Sensors Photo Cell Set
Red eye blinks three times and pauses have to hold button to go down what can it be?
Zebra TLP 2844
I don't know if any errors with red blinks for the 2844, but the printer will blink red five times if you power it up with the button held. Is the button possibly stuck down?
Jul 07, 2015 | Zebra Office Equipment & Supplies
HELLO i HAVE THE mITSUBISHI wd60737 AND IT WILL NOT TURN ON. IT BLINKS THREE GREEN LIGHTS LIKE IT GOING TO TURN ON BUT THEN IT BLINKS RED ONCE AND TURNS OF. i TRIED THE HOLD FOR TEN SECONDS RESET THIN
First make sure the filters and vents are clean and the filter cover(s) are properly installed.
Try once more (DO NOT RESET). As soon as the TV shuts down, press the ACTIVITY/ENTER button and the CH Down button on the TV (not the remote control) and hold them for 5 seconds. The Status LED will start blinking an error code. The "normal" code is 12, which would be one blink, pause, then two blinks and a pause. The code is repeated five times. Post your results in the comments; I can look up the code for you.
Jan 03, 2015 | Mitsubishi Televison & Video
Eninge lite blinks fast and wont start
Pull any error codes.
The engine light lights up when you turn the ignition switch on, then goes off. After four seconds, if it comes on again and stays on, there is a present fault code. When it is an historical fault code, it comes on with ignition and goes off then comes on and goes off again. I believe in like 4 second intervals. A historical code will not be removed until a cycle of 50 ignition on/of intervals has passed. In other words, the engine light will continue to light two times when ignition switch is turned on, after 50 on/off cycles have passed the historical codes will no longer affect the engine light when starting.
If you will hold the odometer button on the side of the console down, and turn the ignition on and off, three times I think, waiting for the fuel pump to stop before turning the ignition switch to the off position, and one second until you turn it on again, the third time holding the odometer button down until the engine light begins to blink it will begin to blink in a fast sequence showing the fault codes will follow.
First indication of fault code display is rapidly blinking engine light. After that count the number of times the engine light lights up. There will be a brief pause between digits. If there are multiple codes stored, the rapid blinking will separate each. Once the fault codes begin to repeat, you have gone through all stored codes.
Tips: Have a pencil and paper ready.
Maybe ask a friend to help out. Sometimes a second pair of eyes can be good.
Go through a couple of cycles, so that you are sure you haven't missed any codes.
One example is if it blinks 3 times, pause, the blinks 2 times, that means 32.
Code 32: Rear Fuel Injector
Feb 16, 2014 | 2000 Harley Davidson FLHTCUI Electra Glide...
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
How do i set the date and time on my canon p23 dh v calculator
If you want to set the time, the button that has a picture of the calendar and clock (just to the right of the arrow key) until it shows the time. Then press and hold the date/time set button (just tor the right of the red minus button) for three seconds until it begins to blink. Then use the arrow key and enter appropriate digits and the am/pm button for am or pm. If you need to set the date, press the calendar/clock button again until it shows either the date or the time, and then hold the date/time set button down for three seconds until it begins to blink. Then use the arrow key and enter appropriate digits.
Mar 17, 2010 | Canon P23-DH Calculator
Red blinking light three times pause then three
Make sure that lamp door is fixed securely and pressing lamp door switch as 3 times blinks shows lamp door switch is not On.
May 13, 2009 | Sony KDF-50E2000 50" HDTV
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Red and yellow flashing light
If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
Dec 27, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Pairing s9 headphones w/krzr
OK I managed to get my head set to work. Make sure the unit is charged, press and hold both the 'ON' button (on neck piece) and the "PLAY/PAUSE' button on the right earpiece. Keep holding then the LED should flash Blue three times THEN flash alternate RED and BLUE. You should then be able to Pair the Device. Good luck
Oct 21, 2007 | Motorola Radio Communications
Genie Company Genie Garage Door Opener Safety Sensors Photo Cell Set Logo
59 people viewed this question
Top Genie Company Building Materials Experts
chrisheman
Ian Lulham
Ian Lulham
Level 1 Expert
rdjagger
Are you a Genie Company Building Material Expert? Answer questions, earn points and help others
