Question about Maytag Admiral Top-Freezer Refrigerator
Freezer not cooling below 20degrees, compressor and all fans working, condencer not frozen
    Novelist:
    Scholar:
  • 100 Answers
If the freezer keeps on working, but is not able to go below the desired temperature, you should check if the freezer is able to go this low. If it does, it might be ice-forming inside, which acts merely like a thermic insulator. So if there is ice, remove it carefully. Best is to let the ice melt, by unplugging the power, and put a pan with boiling water inside. Ofcourse you need to remove all stored items / food of the freezere, before you do this. Store them in special bags (those bags with aluminium foil)
Another source can be leakage of the cooling-fluid. This is difficult to tackle, because it means most of the time : look for a new refrigerator.
Posted on Oct 15, 2013
SOURCE: maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Posted on Sep 05, 2009
heatman101
  • 43501 Answers
SOURCE: freezer not working properly
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sdfaghsd
Posted on Sep 29, 2010
  • 2694 Answers
SOURCE: Freezer is not keeping food frozen and water is
is the compressor running?how long has the freezer been melting out?if you open the fridge door,turn the cold control up and listen to see if you hear the compressor start,if it doesn't try tapping on the control with a screw driver,if the control is bad it sticks inside and if you tap it sometimes it will free it and start but it will stop again,just doing this to check what's bad in the fridge,lso there's a timer in the fridge section,look around where the control is,you'll see a hole in the bottom of the console,you can stick a straight bladed screw driver up it and turn it slowly until it clicks,if the compressor starts when it clicks you have a bad timer and it was stuck in defrost,if the compressor is running and the freezer is still melting out you could have a leak in the sealed system a freon leak,you can check this by removing the back inside wall of the freezer,look at the evap coil,if there's just ice on the top instead of an even frost pattern over the whole coil then you have a freon leak,if the fridge has been running and you look at the coil it should have frost covering the whole coil,if ice is just on top it's new refigerator time,get back to me and let me know if the compressor is running,iis the door closing correctly and no rips in the gasket,if it has a light in the freezer push the light switch in and make sure the light is going out,if not the bulb is heating up the freezer,make sure the evap fan is blowing in the freezer and no ice on the back wall of the freezer,has any water been dripping into the fridge from the freezer,if so you have a blocked drain.do some checks and get back to me,if the freezer is melting out it sounds like you have a compressor problem
Posted on Mar 26, 2011
imufo2
  • 3773 Answers
SOURCE: model MFD2561HES recently had new
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 11, 2011
  • 139 Answers
SOURCE: refridge or freezer not cooling
HI welcome to fixya, THe compressor start overload is bad, They had a recall about 1-2 yrs ago. You will need a tech to replace the bad overload. Should be cheaper than a new fridgerator. And this could be under recall. You will need the frist 2 letters in ser/number I hope this helps
Posted on Sep 20, 2011
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
Nov 14, 2013 | Samsung RF265AA Bottom Freezer French Door...
Freezer stays cold but fridge has been warm. I turn the thermostat to off for a day and then everything is ok for a week. Sounds like the fan is frozen solid when fridge doesn't work( no sound) Th
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 11, 2013 | Refrigerators
GE FUF14 14DPHRWH purchased 082105. No problems until today water was dripping out the front corner and food had begun thawing. Fan is running. Located out in the garage on a concrete floor.
I don't knowabout the ONLY solution. Is the drain plugged? If so the condenser could be frozen over and therfore no cooling even though fan, compressor and defroster are working. How is 134 level? 124 WILL run below 55 degrees. Duh, that's what's in your car and it will work before the engine compqartment is warm. It may not work as well because of the coefficient of expansion/contraction but it still does "work."
May 17, 2011 | GE FUF14SVRWW Upright Freezer
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Freezer wont cool
This problem could be cause by a few things. Can you tell me if your condenser is clean? If it is dirty, the heat cannot be rejected. Will you feel the large copper line going to the compressor and tell me if it is cold to the touch? If it is not col and your compressor is running you may be low on refrigerant. Also, is the evaporator frozen over? If your evaporator is frozen over you might be low on refrigerant, or you evap fans may be out.
Feb 15, 2009 | Traulsen Freezer G22013 Freezer, Reach-in,...
Amana Side by Side, freezer not cooling adequately
first make sure the fridge has not frozen over if there is ice on the walls it will screw the system that determines how cold it is up. if this is the case empty the fridge unplug and use a hair dryer to carefully speed up the thawing process. usually this happens during warm and humid seasons.
if this is not the case then see below and you might need a professional appliance service to perform the below unless you are fairly skilled
The temperature control thermostat directs voltage to the compressor, evaporator fan motor, and condenser fan motor (if applicable). If the temperature control thermostat is not working properly, it may cause the refrigerant system to run longer than necessary. As a result, the refrigerator will be too cold. To determine if the thermostat is defective, rotate the thermostat from the lowest setting to the highest setting and listen for a click. If the thermostat clicks, it is not likely defective. If the thermostat does not click, use a multimeter to test the thermostat for continuity. If the temperature control thermostat does not have continuity at any setting, replace it.
The thermistor monitors the air temperature and sends the temperature reading to the control board. The control board then regulates power to the compressor and evaporator fan based on the thermistor readings. If the thermistor is defective, the compressor and evaporator fan may run too frequently. As a result, the refrigerator will be too cool. To determine if the thermistor is defective, test it with a multimeter. The thermistor resistance should change in conjunction with the refrigerator temperature. If the thermistor resistance does not change, or the thermistor does not have continuity, replace the thermistor.
Jan 02, 2018 | Refrigerators
Kenmore refrigerator not cooling
hi thanks for the question if both fans are working no ice build up & no dirt on condencer by the compressor sorry but you need a new compressor thanks the appliance doc
Sep 22, 2008 | Kenmore Refrigerators
Freezer not cooling
remove back panel inside freezer and see if pipework is frozen up and also check fan is working. if pipework frozen up, indicates a fault with the defrost system
Sep 14, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
Clicking noise from compressor and fan runs 24/7
check the grounds to the ref. also check power to the ref. but it sounds like you have a floating ground the only thing else to mke comp.cycle is the relay which is on the comp. itself
Jan 08, 2008 | Kenmore 53092 / 53094 Side by Side...
Maytag Admiral Top-Freezer Refrigerator Logo
49 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
