Question about Electronic Specialties Battery & Starting/Charging System Tester
95 pontiac grand prix wont stay charged new batt,new alt,runs but will drain down till dies
  • 364 Answers
There has to be a drain of some sort, simple things to check, glove box light, trunk light , make sure these ore off when they are closed. worse case scenario.... strter notor is polling, meaning the internal bearings are worn and the magnets are pulling the armature to the inside wall and draining the battery, Replacing the starter may solve the problem if its not the lights. I wish you good luck.
Posted on Oct 14, 2013
    Problem Solver:
  • 15 Answers
Try isolating the circuit. Do you know how to measure current? If not, read this: http://www.fixya.com/support/t21679428-purchased_velleman_dvm850bl_check
Then go to the fuse box and remove all of them, making sure to write down which one goes where. Then go back, plugging in each one back in, and reading the current on the equipment. If there's a current drain, you'll find it and know where it is.
Posted on Nov 22, 2013
I HAVE A SERVICE ENGINE LIGHT ON THE CODE 1361.....(IGNITION COIL LOW VOLTAGE) HOW DO YOU CHECK OR FIX THAT? THIS IS ON A 2002 GRANDPRIX GT
Other than the obvious (radios etc that have been added) I would check the diode in the alt. It is like a one way valve so it will charge but when shut off drain the batt. when bad.
Sep 21, 2014 | 2002 Pontiac Grand Prix
Electrical problems on a 2002 Pontiac grand am
an alternator wont help if you battery is shot or very low charge, charging battery from just alt is not recommended.if you use a jump from a good 12volt source and it stays running more than likely it's your battery
Aug 05, 2014 | 2002 Pontiac Grand Am
Car wont stay charged new alt, new battery, runs for a while but will die after few minutes running
If your Pontiac has some years/miles on it and has the original starter, it may be shorting and causing the heavy drain on the battery
Oct 14, 2013 | Pontiac Grand Prix Cars & Trucks
My jeep grand Cherokee lorado 1998 won't start. If
are the inside of the battery terms dirty,corroided? do you know if motor alt is charging batt? how long did it run when you put new batt in? if it lasted about two days, its proubly not charging, also make sure nothing is being left on draining batt down, to check that, leave batt nuhooked pos side over night.
Feb 19, 2013 | Cars & Trucks
06 pontiac grand prix wont start no clicking when you turn the key over even jump starting the battery, has dash lights & radio & parking lights. battery tested good. put a used starter & altinator on
Used parts such as starters and altinators don't last. It might **** but it sounds like you need to buy a new starter,altinator, and battery. Or just start with buying one at a time.
Dec 06, 2011 | 2006 Pontiac Grand Prix
Low or bad voltage i replaced the alt and batt is good dash gauges are not working check engine light was on before the issue and dont come on now.will run if i jump the batt but then just drains.not...
are you sure the alt. is good
how long does it take to drain down
have the alt rechecked by auto store they do it for free
does it die even if its running meaning you are just using the life of the battery then it dies then its your alt.
poormansdvd@yahoo.com if you need further trouble shooting
Mar 10, 2010 | Mazda B4000 Cars & Trucks
Electronic Specialties  Battery & Starting/Charging System Tester Logo
120 people viewed this question
Top Electronic Specialties Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Electronic Specialties Measuring Tool and Sensor Expert? Answer questions, earn points and help others
