Question about Dyson DC44 Animal Cordless Vacuum
Brush bar is not spinning on DC44 Dyson - Dyson DC44 Animal Cordless Vacuum
5 Suggested Answers
ukvacfan
  • 328 Answers
SOURCE: Dyson vacuum cleaner-brush bar is frozen
Hi If your Dyson has a brush protection design - i.e. roller bar on the top of the hood on the left hand side then the DYson can't be repaired by you- serviceman or professional care can replace it.
However if the Dyson doesn't have the roller bar on top of the hood, flip the machine over so that the beater brush is facing upwards, locate three/four screw heads that can be undone with a coin and remove the sole plate assembly. This should give you a clean view of the brush bar, drive belt and dirt channel. Ensure everything is clean espcially if the brush bar has lots of hair or threads tightly corded around. Then locate the drive belt and check to see if it has snapped. Grasp the beater bar gently upwards and the belt and brush can then be removed. Fit a new belt on carefully and check the tension as it will be tight.
Posted on Apr 05, 2009
  • 7 Answers
SOURCE: My Dyson Animal 14 beater brush will not turn.
It MAY be a clutch issue. I had a similar problem with my DC07 Animal recently a posted a solution elsewhere on this site, but here's the summary. To reset the clutch on my model, recline the vacuum, turn it on it's side and slowly change the carpet/bare floor knob from one setting to the other about 6 times. This apparently reset the clutch and now it works fine. You may also wish to call DYSON. They're very helpful and walk you through troubleshooting before recommending servicing. Their number is 1-866-693-9766. They'll need your model and serial number (located on bottom of uinit).
Posted on Apr 18, 2009
SOURCE: motorized brush bar not turning on Dyson Vacuum
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
Posted on Oct 04, 2009
  • 3 Answers
SOURCE: Dyson DC14 Brush Bar won't turn
You don't need to take it for repairs, I just corrected the same problem on the phone with a tech. Have the head on your lap, make sure the end nearest the little belt has the rounded side of the bar facing you. The squared off end faces towards the machine. Place your left hand pointy finger under the bar (the 2 inch bar next to the little belt) and lift up, while finessing the loose end of the bar into place, with the rounded part still facing you. Then it sort of snaps into place. Now, replace the face plate. In the upright mode, starting at the carpet dial, switch the dial back and forth between carpet and bare floor, ten times. (the tech actually referred to this as re-setting the vac. LOL) Plug the vac in, incline the hand, and start. It should work. It didn't for me the first time and made a horrible sound. That meant I had to go and repeat the process again, but lo and behold, IT WORKED! When in doubt, call the tech and don't let them get away from you; have them stay on the line until the problem is resolved.
Posted on Oct 10, 2009
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Dyson DC54 brush bar not rotating. Have removed all the hair, cleaned the brush and replaced, still not spinning.
    Brushbar not turning Clutch check - Dyson
    www.dyson.com/...dyson...not.../brushbar-not-turning-clutch-chec...
    DysonBrushbar not turning - Clutch check. Please ensure that your hands are clear of the soleplate and brushbar before completing this test. Clutch check.
    Resetting the brush bar (Official Dyson video) - YouTube
    ? 3:52
    https://www.youtube.com/watch?v=AiKnefEr7ns
    Jan 16, 2014 - Uploaded by AskDyson
    How to clear and reset the brush bar of your Dyson DC41 Mk2, DC55, ... Dyson DC41 Mk2, DC55, DC65, DC66 - Resetting thebrush bar (Official Dyson video) .... Dyson Cinetic DC52, DC54with the Musclehead™ floor tool ...
    Dyson DC44 - Remove & clean the Brush Bar - An owners ...
    ? 4:13
    https://www.youtube.com/watch?v=_0a71p84sp8
    Nov 12, 2012 - Uploaded by Tom Strong Reviews
    Here is the fantastic Dyson Digital Slim Mk2 DC44 Animal. (DC45 in ... Europe) Here I show how to remove and clean the Brush Barof any tr... ... It is and easy operation and one you need to do whenever the brush is not clear.
    Dyson DC54 Support - Turbine head not working properly
    https://www.dyson.com.au/.../dc54/dc54...not.../turbine-head-not-workin...
    Dyson DC54 Support - Turbine head not working properly. ... If you cannot clear an obstruction you may need to remove the brush bar. Use a coin to unlock the ...
    Jan 24, 2016 | Dyson Vacuums
    Carpet brush does not work on dc26
    With this model, the most likely cause is that the brush has become clogged and won't spin freely. Unplug the unit and test spinning the brush bar by hand. If you really can't get spin, follow instructions like these (
    Dyson DC26 DC35 DC36 DC38 DC44 DC45 DC47 Clearing the brush bar Official... that are straight from Dyson). Make sure you get the very ends fiber-free. It should spin better now.
    Good Luck!
    Jul 07, 2014 | Dyson Vacuums
    Dyson dc44 brushbar
    Hello, this is Ava with Think Crucial.
    There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
    First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
    While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
    You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
    https://www.thinkcrucial.com/search?type=product&q=dc44
    I hope this was helpful.
    Ava B.
    Think Crucial Customer Care
    http://www.thinkcrucial.com/
    Jun 17, 2014 | Dyson DC44 Animal Cordless Vacuum
    DC44 Brush spins when not using vacuum
    Hi there, it's Jack at Dyson.
    The issue you've described sounds very odd, and we'd like to take some further details. If a replacement part is needed, we can also confirm if your machine is within our 2-year warranty period.
    When your machine is fully charged and easily to hand, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Our experts will be happy to run you through some quick diagnostic checks to help determine the best course of action.
    Feb 10, 2014 | Dyson DC44 Animal Cordless Vacuum
    Why won't my Dyson DC44 rechargeable vacuum brush attachment not work or pick up anything?
    Hi Kim, it's Jack at Dyson.
    If your DC44's motorised cleaner head doesn't seem to be picking up as well as it should be, it sounds as if there is a blockage somewhere. To check for this, please follow the steps shown in our Support guide: http://www.dyson.co.uk/support/dc44/dc44-animal/maintaining-your-dyson-machine/removing-blockages-from-the-power-floor-tool
    The video I've attached should also help you check for and remove any threads, hair or debris caught around the brush bar.
    If you'd like further help after you've given this a try, please get in touch with us directly so our experts can talk you through some additional troubleshooting checks. You can reach the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1800 239 766 (AU).
    Jan 29, 2014 | Dyson DC44 Animal Cordless Vacuum Handheld...
    BRUSH NOT SPINNING ON A DYSON DC44 ANIMAL
    Hi Veronica,
    Thank you for reaching out. I am sorry to hear your brush bar will not rotate. In light of the detail you provided regarding the spindle there are a few checks we need to complete in order to determine the best solution. Please call our Helpline to speak with an expert.
    US - 1-866-693-9766 or UK - 0800 298 0298
    Best wishes,
    Jessica
    Dec 17, 2013 | Dyson Animal Bagless Cordless Hand Vacuum,...
    Dyson DC44
    Hi Juliet,
    I am sorry to hear you are having difficulty with your brush bar. We recommend taking an opportunity to remove your brush bar and ensure it is free from any debris that might obstruct it. It is also helpful to inspect your cleaner head for any damage. Next, we recommend removing your wand from the main body and attaching your cleaner head directly to the main body of your machine to determine if your brush bar spins.
    If your brush bar spins when the cleaner head is attached to the main body your wand may need to be replaced. If it does not the issue may be with the cleaner head. We recommend calling our Helpline with your findings so we can provide assistance with next steps.
    Best wishes,
    Jessica
    Nov 24, 2013 | Dyson DC44 Animal Digital Slim Cordless...
    Loss of suction
    I'm sorry to hear you've had difficulty with your DC44 Animal. It's normal for air to blow out of the back of the machine - this is where the exhaust air is returned to the room after passing through the cyclone pack.
    However, if your machine doesn't seem to be picking up as well as usual and you've recently washed the filter, this may be due to a blockage. To check the motorised carbon fibre floor tool, wand and bin inlet for any obstructions, please follow the steps shown in our online Support guide:
    http://www.dyson.co.uk/support/dc44/dc44-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual-dc44/no-resolved-redirect-to-check-the-wand/check-wand
    The motorised carbon fibre floor tool is driven by it's own motor, rather than the machine's airflow. If it isn't rotating, the video attached should help you locate anything which could be jamming the brush bar. Make sure you remove any threads or hair from around the brush bar carefully using scissors, taking care to avoid causing any damage to the bristles.
    I'm confident this will resolve the issue, but if you would like some further help you can reach the Dyson customer Helpline directly by calling us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack - Dyson Online Customer Support
    http://www.dyson.com
    Jun 09, 2013 | Dyson DC44 Animal Cordless Vacuum Handheld...
    Dyson DC44 Animal Cordless Vacuum Logo
    6,422 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
