Question about Hitachi 42HDM12 42 in. Plasma Television
Zenith P42w46X: No picture
I do not getting a picture on my Zenith P42w46X, 42 in plasma TV, but I do have sound. I can not access the menu screen. All I get is a snowy screen.
  • coatsman Mar 29, 2008
    YES I AM HAVING SAME PROBLEM WITH MINE AND MINE IS THREE YEARS OLD.IT STARED AS A 5 MINUTE WAIT TO SEE THE SCREEN AT FULL BRIGTNESS NOW I CAN BARLEY SEE THE SCEEN BUT STILL HAS VOLUME.
4 Suggested Answers
markevans
  • 148 Answers
SOURCE: ESA EDTV - 42 inch plasma TV, sound OK no picture.. has vertical lines.
pull plug. allow to reset. try again.
good luck on that, otherwise you need service.
good luck
mark
Posted on Dec 28, 2007
SOURCE: 42edt41a hitachi plasma tv went dark sound ok
sounds like your y and z drive boards over heated and need replacing...
Posted on Jun 03, 2009
Warf135
  • 137 Answers
SOURCE: May a pop noise, now no picture but has sound. it
Sounds like the Invertor for the backlights has blown. if you are lucky and it is just the invertor blown it could cost £50-£150 for a new invertor board, but if you are unlucky then the backlights themselfs have blown too which means the TV is beyond economic repair.
Posted on Apr 05, 2010
Screen flickers, on all channel's the tv is 5 years old
Z-sus boards are the weakpoint on those models of Plasmas. But If you eventually loose your picture entirely, but retain sound it is even more likely your culprit.
Feb 23, 2010 | Zenith P42W46X 42 in. Plasma EDTV
I have no picture but i have sound any suggestions
Replace 6870QZE013C or 6871QYH053A (more likely).
The second is the Y-Sustain board, located to the left of your TV when looking from the back.
This is the one that usually burns and the fuse on it is likely shorted. Do not replace it, it will burn again.
Feb 04, 2010 | Zenith P42W46X 42 in. Plasma EDTV
My Zenith P42W46X 42 inch tv got two black lines vertical lines on the screen the were coming and going away before but they are more stable now.i opened it up and wiggled all the connections arround the...
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable near the black lines. Unplug the ribbon cable and look for black chips on the underside of it, I think they say 100 on them, you need to resolder both ends on each chip. Should fix the black line issue.
Oct 08, 2009 | Zenith P42W46X 42 in. Plasma EDTV
42 zenith plasma picture cutting in and out with good sound.
if you feel the tv is worth fixing id say get it fixed.anyone that comes out to you is going to charge a bit more and it sounds like he knows what hes talking about...
Jan 19, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X - no picture
if the lines covered the entiire screen, fist I would check to see if the TV's menu can be seen. If not then check the buffer boards. Next I would check the logic board
Jan 09, 2009 | Zenith P42W46X 42 in. Plasma EDTV
I have a 50" zenith 10 months i can hear how can i fix this
If the unit is only 10 months old, it should still be under manufacturer's warranty. Call and request warranty service. DO NOT open up the unit as that would void the warranty.
Keep us posted on what is found.
Thanks,
Dan
Aug 20, 2008 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X 42 inch EDTV
common problems with these, usually customers here a loud pop. then the screen goes blank. I would try...
Some of these have a 4 pin test on the control board that you can jump with solder to get test pattern. If you get it to do that then these boards maybe good and would replace the control board. if nothing happens, then
the upper & lower drive also the Ysus and Zsus boards all at the same time.
last could be a defective panel.
hope this helps. p/n are on all the boards.
Jul 22, 2008 | Zenith P42W46X 42 in. Plasma EDTV
Plasma Screen not working only sound
It might be one of the power supplies. There are three in this model. One for the sound, one for the video, and one for the computer components. The video power supply is probably shot. They cost about $200 a peice from LG. If there was a "pop" sound when the video stoped, then it might be one of the circuit boards in the back. Yet again, they are three, each costing around $200 from LG.
Dec 26, 2007 | Zenith P42W46X 42 in. Plasma EDTV
P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Nov 25, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Open Questions:
Hitachi 42HDM12 42 in. Plasma Television Logo
149 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
