Question about Roper RAS8445KQ Top Load Washer
New roper wash. Mach. Will not fill on warm wash, but does on hot cycle
  • 364 Answers
This could be a simple fix, where your hoses screw onto the back, ensure that there is a screened washer in place as your cold water is pushing the hot water back through the lines so the hot can't come through with the cold running as well, thats why it will only be hot or cold, scoot down to your white goods center and they will provide you with the correct washer screens for your unit, cost should be no more than about $3 a piece. good luck.
Posted on Oct 14, 2013
catriver
  • 878 Answers
SOURCE: Washer won't drain
Mustache, sounds like you have a broken lid switch. No spin, no drain usually a sign of this. Check to see if the actuator is making the lid switch, or the switch itself is bad. Part number for the switch is 8318084. Catriver, post back.
Posted on Jul 30, 2006
SOURCE: ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Posted on Apr 12, 2008
SOURCE: Roper washer wont empty
the pump is not working
Posted on Oct 28, 2008
  • 132 Answers
SOURCE: Roper washing machine not going through rinse cycle.
Good Morning,
Sounds like your cold water valve is not opening. If you are handy with a Multimeter check the selector switch that you use to set your cold water for good continuity when you activate it. You should have a good steady reading on the meter. If the meter is fluctuating or has no reading at all the switch is bad. If the switch checks out good, check to see if there is voltage to the cold water valve terminals when the machine is calling for cold water. If there is no voltage, you will have to locate the relay or source that supplies this voltage and replace it. If there is voltage the valve is faulty and needs to be replaced.
I hope I helped you today.
Posted on Mar 26, 2009
jsrock516
  • 5911 Answers
SOURCE: Washer fills with water then does nothing
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Posted on May 27, 2009
Roper washer new will not fill with warm water on rinse cycle it fills and spins
if its only a new machine make sure transport bolts have been removed
Apr 09, 2014 | Roper Washing Machines
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
Jan 07, 2014 | Roper Washing Machines
Roper washer fills and washes then will not fill on rinse cycle but goes into washing dry
Run the machine with hot only, and then cold only. Post back your results.
Nov 11, 2012 | Roper Washing Machines
The cold water cycle is not working on my Roper washer top loader heavy duty
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
May 12, 2011 | Roper RAX4232KQ Top Load Washer
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
Have a Roper RAS7133RQ3 top loading washer. Will not fill with water when turned on but will spin and drain when you take it through the cycles.
First, always check for the obvious causes, if you haven't already, we all tend to overlook these.
1. Are water valves open, and if so is there water.
2. Check hose filter screens for plugging, or hoses themselves,
After these possible causes have been ruled out, check machine's inlet for both hot and cold taps for blockage, other wise you most likely have a bad fill valve, which are fairly cheap and simple to replace. If you have hard water, this is your best bet. These valves have two solenoids, one each for hot and cold, one or the other will energize when the temperature selector switch is selected for hot wash or cold wash, if warm wash is selected both solenoids energize to allow both hot and cold water to enter the machine and mix to warm.
Hope this helps
kcomp1863
Jan 10, 2011 | Roper RAS8445KQ Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Roper washer: Slow fill on hot setting
You can really thank the government for this- your washer has a 75/25 split valve (75 cold 25 hot--- so warm is mostly cold) which they mandated for all standard top load machines. In 2010 they are banning manufacting of all standard top loaders. The thermistor is because your machine has a ATC (automatic temperature control) system. It has a computer which monitors water temp for better laundry care. You could possibly have a repairman (this wouldnt be covered under warrany) try to retrofit a older service valve in your machine.
Jan 13, 2008 | Washing Machines
Oct 27, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
85 people viewed this question
Top Roper Washing Machines Experts
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
