How to adjust water level
This is not adjustable. When full, the water level should be: between the very bottom of glass and about 2" up from bottom of glass. Anywhere around that level is fine. If water overfills, your pressure sensor may be bad, or its little hose could be clogged. To check for clog: Remove top (Two 1.5mm Torx screws in rear) ; On right side, see 3" round (brick red) plastic gadget (that's the pressure sensor - that determines water depth) with a few wires connected to it ; Unplug the power cord - for safety ; pull small black tube off pressure sensor and blow into it. If it's not clogged you'll hear bubbling (if there's water in machine) or just hear air going into drum. Pressure sensors very rarely go bad.
