Question about FUJIFILM FinePix JV200 / JV205 Digital Camera
Lens won't work.
So, I was recording a video when my camera fell.. I was shocked. It feel right on the lends, breaking it. (Meaning it won't come open) Anyway I can open it back up? I did it like a year and a half ago, just couldn't find a way to get it to work!
    Champion:
  • FUJIFILM Expert
  • 319 Answers
Lens block faulty replace it
Posted on Oct 16, 2013
18-55mm lens wont auto focus
If the lens will focus on manual focus but won;t on auto focus you may have a ribbon connector failure in the lens. This ribbon continually flexis as the lens moves in and out. Over time this can break and will probably need to be replaced. All good camera repair shop should be able to do this for you and this remady is one of the cheaper repairs to photographic equipment
Jan 23, 2014 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Can Aiptek A-HD 720P record footage from old games?
the A-Hd is the only Hi def camcorder of Aiptek to record into the camera the Av input iti s called. the A-hd has a lower gain of the mic meaning all video recording of the actual live footage will be low on older models possably normal on the newer today
the Go-hd does not record any footage into thecamera no AV input it will have a higher gain meaning the sound going into the camera will be too loud there is no medium level
Apr 21, 2017 | Aiptek A-HD 720P Flash Media Camcorder
I have a Nikon N65 and an AF Nikkor lens on it. The lens fell off some time ago, and now it does not lock in place.
The most likely culprit is a broken mount on the lens. Some Nikkor lenses have a plastic mount whose bayonet blades can break off when the camera is subjected to a shock. Since you neglected to specify the lens I don't know if this is the case with yours.
If you have access to another lens, try it. If that one stays on then the problem is with your lens. If that one doesn't stay on then the problem is most likely the mount on the camera itself, which is a more serious problem (unless the mounts on both lenses are broken).
Jun 19, 2012 | Nikon N65 35mm SLR Camera
LENS OPENING BUT NOT SHUTTING
Its seems lens got stuck in the barrel due to external shock caused, Try out following steps-
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once's or twice then it will stuck again.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else contact Olympus, your camera need to be disassembled to get at the focusing ring at Service Center .
I hope this will solve your problem
Thanks..!!
Jul 04, 2011 | Olympus Mju 725 SW Digital Camera
Camera is starting, but i touch the lend zoom from moving out
If you cycle it, power off and back on and the lens comes out properly, don't be concerned, if it doesn't come out right, it has been damaged and will require professional repair. They have tiny plastic gears and electric motors which can jam or break in the lens mechanism
Apr 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My camera fell and the lens is stuck!
Hi there, after fall in the floor , your camera's lens guider is broken & thats why its not able to came out fully & not doing proper focusing. Replace the lens guide pin. After that it will work fine like before. Thanks.
Feb 25, 2010 | Casio Exilim EX-S500 Digital Camera
Sony DCR-DVD403 camcorder - picture won't focus. E:61:10 error.
E61:10 is a lens error code. You have a bad lens unit, but sometimes they can be fixed. The focus and zoom motor worm drives on the zoom lens jam when they get dropped. If your really really carfull you can free them up and fix the lens. Thereis a plastic claw that rides along the worm drive shaft that can get jamed. I've fixed thousands of these but i'm a guru. It can be tricky.
Dec 09, 2008 | Sony Handycam DCR-DVD403 DVD Camcorder
Optic viewer blurred image
Not much that you can do with that, try adjusting the small focus lever on the underside of the viewfinder, as this might fix the blurred image, your lucky that you didn't, break something on the camera.
Jan 05, 2008 | Sony Handycam CCD-TRV37 Camcorder
FUJIFILM FinePix JV200 / JV205 Digital Camera Logo
21 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
